Class 175 to GWR
The exile
31 Mar 2010
Somerset
GWR only has 5 x 3car 158s (and I think only one is a true unit, not a 3car with 3cabs reformed from 1.5 x 2car units)
The Cardiff-Portsmouth service has 8 diagrams so not clear how these really help when usually only 3 (or 4) of 8 diagrams are currently formed with 158s. It will still leave a number of workings with suburban turbos rather than medium distance stock. The long journeys to Weymouth are normally the turbos too.
Well 6 (or 7) from 8 is better than 3 (or 4).
As for the Weymouth line, there obviously are people making the full journey (particularly in summer), but I’m sure the proportion making short intermediate journeys is high - though I accept that that is probably less true the further south you get.
GoneSouth
17 Dec 2018
Couldn’t you say the same for Cardiff to Portsmouth?
Lots of shorter journeys rather than end to end travellers. Cardiff to Bristol (not dissimilar to Gloucester to Bristol with its turbos), Bath to Bristol, a 20 minute hop, Wiltshire towns into Bath and Bristol, again not great long distances. How many people are doing Newport or Cardiff to Portsmouth?
If you could refurb the interior of the turbos to match the 158s with 2x2 plus tables we’d all be a lot happier
Towers
30 Aug 2021
That was discussed a while back when they first started heading off for refreshing; it isn’t feasible to remove the 3+2 interiors due to assorted fixtures under the floor.
nw1
9 Aug 2013
Might the transfer out of 80x mean the return of the through Bedwyn service?
The exile
31 Mar 2010
Somerset
The comment I was responding to was that the turbos are not suitable for Cardiff - Portsmouth work - presumably because they are more suited to short hop work. The major issue is that the Portsmouth- Cardiff is neither fish nor fowl. The 158s (when not crush-loaded) are ideal for the longer distance traffic but completely unsuited for a route with a high churn.
D6975
26 Nov 2009
Bristol
I live in Bristol and I can confirm that on arrival at Temple Meads these services have a major turnover of pax in both directions. Typically 75%+ of them get off at TM. Furthermore, in the Southbound direction many of those who have come from S Wales get off at Bath.
HamworthyGoods
15 Jan 2019
4 from 5 of the 3 car 158s diagrammed for traffic, the 5th is a maintenance unit.
Currently 4 out of 8 Portsmouth circuits are booked 4 car 158s.
The cascade of the 3 car 158s allows 2 additional circuits to go to class 158 operation taking you up to 6 from 8.
There’s also a 158 used on the Salisbury circuits and another one on the Worcester circuits. These two units pair up to make the 7th Portsmouth circuit 158s.
The 8th circuit remains turbos as previous discussed.
dciuk
1 May 2018
That’s not on the NDL (North Downs Line) though.
Although NDL could also be interpreted as North Devon Line
I presume you mean up to 6 from the current 4. If the hybrid 3 cars were split back into 2 cars would that not make an additional 6x2 car units which when used as 4 car units would give 3 diagrams instead of 2 meaning with the units coming off of Worcester and Salisbury circuits all the Cardiff to Portsmouth could be covered by the 158's in 4 car formation and very occassionally a 5 car might turn up when the remaining 3 car is being used
Clarence Yard
18 Dec 2014
No, he means 6 out of the 8 circuits. The 7th unit is the pairing as described and the 8th is still a Turbo.
So there will be 4 x 5 car 158 diagrams and 3 x 4 car 158 diagrams on the route. That is a daily diagram requirement for Pompey-Cardiff of 4 x 3 car 158 units and 10 x 2 car 158 units
moley
12 Jun 2011
If it’s true that those 4 of the 5 3 car 158s are all driving cars, why not reform the 4 of them to as 2 car 158s and have all 8 diagrams run by 158s?
HamworthyGoods
15 Jan 2019
Because the capacity of a 4 car 158 is not enough for some services. It would also take a lot of work to reinstate all the current blocked in cabs, stopping units for a time which would be unhelpful. You’d also be left with a single 3 car set.
A 4 car 158 doesn’t have that many more seats than a 3 car 166.
Take a busy train like the 07.27 Cardiff to Pompey as far as Bristol it’s booked a 5 car 16x formation for a reason.
As noted above this uses the entire 158 fleet, if there was no booked 16x to Portsmouth then Fratton depot would lose traction knowledge and means in the event of a shortage of 158s it would be impossible to provide 16x substitutions which is very risky.
Doomotron
25 Jun 2018
Kent
It's also worth noting that if only one three coach unit was left, it would create a big headache for those making the diagrams. I presume it's why Southern has been busy reforming most of their 171s to be the same length.
It's also linked to GWRs crazy policy of not doing a few platform extensions (some of which are just a few metres, although others nearer 20m) to allow flexibility of 3x2car or 2x3car as options.
A 6car 158 is only 8m longer than the 5car IETs currently being used on some local services in the west.
Although the 175s are too small a fleet to displace enough to allow some busy trains to become 6car.
RPI
6 Dec 2010
The 5 car IET'S have selective door opening though.
HamworthyGoods
15 Jan 2019
Platform extensions require business cases, business cases that are unlikely to achieve the required threshold!
Lurcheroo
21 Sep 2021
Wales
Is that GWR or NR ?
Wilts Wanderer
21 Nov 2016
Presumably there is also a desire/need to maintain Class 16x competency at Fratton depot, which provides a significant number of crews for the Cardiff-Pompey route. They could still maintain it through diagramming if the route lost its final 16x circuit but this would increase complexity and probably wouldn’t provide regular opportunities for couple/uncouple, shunting and other elements that are key to maintaining competency?
(For example this was a problem with the Southern ‘hire’ drivers on the NDL who never had the opportunity to run units in multiple, so on the odd occasion it was necessary it became a problem to do it.)
Do Turbos and 158s not already have SDO? They do at least have local door operation capability for Avoncliff and some of GWR's request stops. I presume 175s will at least need this capability given they will end up on routes with request stops, including the Tarka line where I believe there are a few.
158760
23 Sep 2023
Wiltshire
They have local door operation controlled by the guard. If you look on the platform at these stations (Avoncliff, Dilton Marsh, Thornford and Chetnole spring to mind) there are signs that say release local door only. Iirc the Turbos had to be fitted with panels in the saloon capable of this as part of their move west.
craigybagel
25 Oct 2012
GWR's 158s and Turbos lack SDO, they only have local open. The same is true of 175s, though they do also have a unit deselect function when in multiple.
wickham
3 Feb 2021
Knaphill
Has a date been announced for when GWR will receive the 175s, bearing in mind that they are still trundeling off to Ely ?
HamworthyGoods
15 Jan 2019
Indeed, the cl175s have the same unit deselect function that SWR’s cl159s do.
simonmpoulton
25 Jun 2011
This is what irritates me about the leasing model - these units are over 20 years old so surely Angel Trains has made the money back on them by now but yet these units still have to be leased at cost!
If we could get with nationalisation that the current gov is talking about to a position where new units were leased for a certain number of years and then ownership passes to the national operator after then we wouldn't have these issues - stock which has passed into public ownership could be moved around the network and used where needed without the worry of agreeing a new lease for £x per year.
I'm not suggesting that we get rid of the leasing model completely as it isn't reasonable to expect the government to fund new rolling stock upfront but there must be a better way of doing this!
