Sorry to bring an old forum post up, but could Northern use them on Northern Connect? They are already planning to use refurbished 158s on some routes so these would probably be more suitable.
Northern need to find a number of "class 170-equivalent" units by a certain future date (I don't recall the details). If the 175s are deemed to be 170-equivalent then they could be an option. Whether Northern wants a(nother) temperamental micro-fleet is another thing altogether...
As I've pointed out numerous times on numerous threads 175s are no more temperamental then any other contemporary unit. The perception of them being unreliable is very outdated - after 20 years based in the same maintenance depot they've had their kinks worked out by and large.
That said, the issue of whether or not they count as "170 equivalent" may be decided by what kind of routes they work. Those end doors aren't great for suburban work.
Particularly if they go anywhere near Picc P13/14.
Very true. That's one location where the differences between 170s and 185s are readily visible!
Rush hour congestion/from Chester tends to be at Oxford Rd not PiccadillyParticularly if they go anywhere near Picc P13/14.
I'm sure the 175s will find a new home, I hear if it's a diesel, can have its guage adjusted, and is a bit more intercity than their existing fleet. Some random operator called Iarnród Éireann will have them apparently lol
yeah, Cummins N14s, which I believe only 175s have. The non-rail version is in some DAF lorries, but not sure if it's possible to rebuild the non-rail version into the rail version...? The MTU 6H series is the base engine in 172s and 195s/196s. Those classes also have ZF mechanical gearboxes rather than the Voith mechanical transmissions of 175s.Class 175's use Cummins engines, so not the same as 195's.
or even 175 not 170!I guess that's a typo and you mean 175 not 185
I've not known different classes using the same engines but different transmission type out of hydraulic or mechanical gearbox (168s/170s/171s have Voith hydraulic transmission but with MTU 6R series engines, not 6H series. They may seem similar but a 6H was tried out in a 170 and it didn't take well to it, in a sort of fiery way.) I've only known different classes using the same engines but different transmission type out of hydraulic or electric transmission (Cummins QSK19s in hydraulic transmission 180s/185s and electric transmission 220s/221s/222s).
158s all have the same transmission (except 158834) with three different types of engine.yeah, Cummins N14s, which I believe only 175s have. The non-rail version is in some DAF lorries, but not sure if it's possible to rebuild the non-rail version into the rail version...? The MTU 6H series is the base engine in 172s and 195s/196s. Those classes also have ZF mechanical gearboxes rather than the Voith mechanical transmissions of 175s.
I agree totally!GWR on 3+2 formations for the Cardiff Pompey services I think would be a great fit!
Better than a turbo combo too.
Would be a dream, but probably never going to happen. Would also be good on long distance regional services between Cardiff/Bristol and Devon and Cornwall too. But also never going to happen!I agree totally!
ah yes, forgot about that! fitted in 2015There's always 158834, the only TfW 158 with a 4 speed Voith DIWA transmission. It was fitted as a trial some 4 or 5 years ago and is still going strong, despite it never being extended to any other units.
very true!158s all have the same transmission (except 158834) with three different types of engine.
It may be unlikely but definitely not impossible.Would be a dream, but probably never going to happen. Would also be good on long distance regional services between Cardiff/Bristol and Devon and Cornwall too. But also never going to happen!
age isn't everything. they're a cost-cut build. however the work Alstom have just started doing to them may significantly prolong their livesI can't see them being withdrawn anytime soon I think they could move to other operators if they are surplus to requirements at Transport for Wales, they are much newer than a lot of stock used by other operators and they have 100mph top speed which is more than the sprinter and pacers can do.
I know the person who created the NW Coast Railway website I should ask him if there are any updates.
By my reckoning Northern started the franchise with 11 types (142/144/150/153/155/156/158/319/321-2/323/333). I would not class 321 and 322 as different types - from a maintenance perspective they're identical.At this moment in time, I highly doubt Northern would want the surplus 175s. They currently operate 16 different classes. Part of the plan to reduce the subsidy is to rationalise the fleet types and which will reduce maintenance costs and improve efficiency.
By 2022, the hope is this will be halved to about 8. The requirement for 22 additional DMUs at Northern will (most logically) be achieved by taking WMTs 23 170s once the new 196s are in service.
The only way Northern would be interested in the 175 is if the new Northern trains become a victim of their own success and enticed new passengers. Judging by the TransPennine Express and Manchester Metrolink I wouldn't put this past it happening but for now it's a long shot.
