ryan125hst
Having had my first ride on a Class 195 yesterday, I have a couple of technical questions that I am hoping someone can provide the answer to.
Firstly, they have a 6 Speed ZF EcoLife transmission. What speed do they typical change up to each gear at? I am aware it varies depending upon the throttle setting, gradient etc, but I'm just after a rough idea of when they change up to each gear. Pacers and 75 mph Sprinters have a hydraulic transmission and change up at approximately 45 mph and Class 158's change up at 55 mph (according to a couple of other threads). I am interested in seeing how the gearing on the 195's compares.
Secondly, what is that sound of a motor starting up that you can hear inside them? I had heard it on videos of them (and also on the 331's) and thought it was the air compressor. Hearing it onboard yesterday, it sounded like the air conditioning fans started up as there was a definite increase in fan noise from the roof immediately afterwards. However, it didn't seem to last long and it was only about 10 degrees so the air con wasn't really needed. Does anyone know what this noise is?
