Class 314 Withdrawals
Discussion in 'Traction & Rolling Stock' started by ash39, 19 Oct 2017.
  1. 303032
    303032 Member
    266
    12 Feb 2012
    South Lanarkshire
    From 15.20 onwards the Newton service via Queen’s Park is usually a 314 that comes from Corkerhill. The 15.15 inner circle service is usually a 318/320.
  2. hexagon789
    hexagon789 Established Member
    7,146
    2 Sep 2016
    Extra peak services as on Mon-Fri then?
  3. youngac
    youngac Member
    309
    8 Sep 2017
    I think overall capacity on the North Clyde and possibly Argyle lines is set to be reduced as a result of 318s/320s being cascaded to replace the remaining 314s next month.
  4. hexagon789
    7,146
    2 Sep 2016
    As in more 3-car off-peak?
  5. youngac
    youngac Member
    309
    8 Sep 2017
    I think so.
  6. NorthClyde320
    NorthClyde320 Member
    162
    30 Jun 2019
    North of Glasgow
    What would the likelihood be of ScotRail getting a few more 321's for conversion, say 402/5/19? This would also help with the forthcoming 320 modifications being started next year.
  7. hexagon789
    7,146
    2 Sep 2016
    I thought the 385s were intended to provide sufficient cover overall for 314 withdrawal. Doesn't say much for that if post-314s they have to reduce Argyle Line diagrams down to 3-car.
  8. snookertam
    snookertam Member
    379
    22 Sep 2018
    What is the basis for this? What will the remaining 385s be doing?
  9. youngac
    youngac Member
    309
    8 Sep 2017
    My thinking was that the remaining 385s would be used to strengthen Alloa/Dunblane/Stirling services to 6 cars in order to allow a full 8 car service on E - G via Falkirk.
  10. snookertam
    snookertam Member
    379
    22 Sep 2018
    Those services run as 6 cars during the peaks anyway, and there’s 4 car units to come off the Cumbernauld service too. Unless something has changed recently there’s enough 385s to go round so no need to reduce capacity on the north Clyde routes by stealing 320s.
  11. Scotrail314209
    Scotrail314209 Member
    290
    1 Feb 2017
    I think stealing 318/320 from Argyle would be a bad move as a lot of services are busy when they have 3 carriages. I think more 320 conversion would be viable as Northern have a few coming off lease soon.
  12. Ryazan
    Ryazan Member
    12
    22 Aug 2019
    Whifflet
    What modifications??
  13. stantheman
    stantheman Member
    92
    17 Nov 2017
    Does anyone know when the 318s are planned for withdrawal
  14. SC318250
    SC318250 Member
    504
    4 Jun 2011
    I would think you are talking at least 2026/2027 when they are 40 years old.
  15. ScottDarg
    ScottDarg Member
    590
    27 Apr 2017
    South Lanarkshire
    It's heavy maintenance rather than modifications.
    Brodie Engineering (Kilmarnock) will be doing Time Based Overhaul (TBOX) work on the Class 320/3 fleet starting from January 2020 and running to the end of 2021. See this release: https://brodie-engineering.co.uk/ne...rsholt-rails-fleet-of-class-320-vehicles.html
  16. Colin M
    Colin M Member
    549
    28 Dec 2010
    I'd be very surprised if the 318s and 320s weren't replaced at the same time, possibly even the god awful 334s as well as they will be nearly 30 years old by the time the 318/320s are withdrawn. Personally I'd like to see something along the lines of the Class 700s but in fixed 6 car formations being the chosen type to replace them.
  17. Scotrail314209
    290
    1 Feb 2017
    I think the 334s will be around for at least a decade after, giving that they are a modern EMU
  18. NorthClyde320
    162
    30 Jun 2019
    North of Glasgow
    If the remaining 318/320 diagrams on weekdays on Lanark/Gourock/Wemyss Bay/Paisley Canal are replaced by 380/385's that could free up 5 or 6 318/320's to replace the remaining 5 314 diagrams allowing the Argyle lines to remain as they are capacity wise. If they were to reduce capacity that would seem like a step backwards.
  19. Colin M
    Colin M Member
    549
    28 Dec 2010
    No doubt they will but I for one would love to see the back of them, hateful things.
  20. alangla
    alangla Member
    722
    11 Apr 2018
    What do you not like, if you don’t mind me asking? The aircon upgrade seems to have improved the ambience a bit & the 2+2 vehicles are fairly comfortable. They do appear to have a bit of an allergy to very cold weather though
  21. Colin M
    Colin M Member
    549
    28 Dec 2010
    I've never been a fan of them since they were introduced. Too many squeaks, rattles, jolts etc... Some of them sound like the bogies are ready to fall off. Fair enough, the 303s they replaced were also full of squeaks, rattles etc but they were 40 years old so it was expected but for a train that then was brand new to be the same put me right off them. Compared to the 380s and 385s they already feel quite dated.
  22. snookertam
    snookertam Member
    379
    22 Sep 2018
    There will be a certain amount of diagram changes to deal with the withdrawal of the 314s, however there are more than a few class 318 or 320 diagrams that throughout the course of a day, work both Inverclyde and Cathcart services. Units have worked both lines interchangeably for years and it would take a massive overhaul of diagrams to completely end that practice, so there's little point in swapping out class 320s from the Inverclydes - possibly more so from the remaining Lanark 6 car.
    This means that class 380s and/or 385s will probably be seen more on the Cathcart routes after the timetable change, particularly during the day.
  23. alangla
    alangla Member
    722
    11 Apr 2018
    Fair enough. They are knocking on for 20 years old though. Definitely mid-life or just beyond it
  24. Scotrail314209
    290
    1 Feb 2017
    The squeaks have calmed down a little bit thankfully, but I find them generally comfy units.
    If only some of them went back to Inverclyde to replace a 314. :(
  25. yorkie
    yorkie Forum Staff Staff Member Administrator
    45,401
    Just a gentle reminder this thread is to discuss Class 314 withdrawals; please create another thread if you wish to discuss anything else (or use an existing one if there is one), thanks
  26. youngac
    youngac Member
    309
    8 Sep 2017
    202, 214 and 216 were working today’s daytime duties.
  27. NorthClyde320
    162
    30 Jun 2019
    North of Glasgow
    Thanks for explaining, it will be interesting to see what happens with the December timetable change and the 314 withdrawls anyway.
  28. youngac
    youngac Member
    309
    8 Sep 2017
    205, 209 and 214 today.
  29. JModulo
    JModulo Member
    353
    17 Nov 2013
    67A
    210 back out today. Last I recall was late October?
  30. gka472l
    gka472l Member
    166
    29 Apr 2016
    Would anyone on here be able to list what departures 314's normally work from Glasgow Central on a weekday (next Monday to be specific....) around 0930-1000 please? Day trip up there for a last 314 trip amongst other stuff....quite happy with just a Cathcart circle run.
    Many thanks!
Share This Page
