Class 314
Harold
9 Jun 2005
Southampton
hi, sorry to bring up old topic, can't find class 314 anywhere, could someone please send it to my email address haroldbailey1989 (AT) gmail (DOT) com.
Thanks,
harold
SuperSprinter
25 Feb 2011
Essex
I still haven't received any files :( and I really want to try out this unit (and if anyone has the Class 318 too that would be brilliant :D)
Regards
Kris
SuperSprinter
25 Feb 2011
Essex
Sorry, have forwarded it to you
Thankyou very much! :D I don't know if it's just because I am using it in OpenBVE but when I open the throttle it makes a pulsating alarm noise (it isn't AWS or TPWS as when I set throttle to neutral it stops). Any ideas what this could be? or is it an actual warning and if so how do I cancel it :s
Regards
Kris
Jordy
9 Jun 2005
WCML South
That would work, other than that I have no idea - I'm just sending the files, I don't know anything about the train!
SuperSprinter
25 Feb 2011
Essex
I just added a character to the file so it couldn't read it. Very odd though, I am assuming it is OpenBVE having problems with earlier version files, as another example is the Class 350, i plays the first motor sound too fast so it sounds like a house alarm! I don't mean to go off at a tangent but does anyone have the Class 303 and Class 318 units also? And thanks again :) I love the sounds with the Class 314 so congratulations to the author!
Regards
Kris
class313
21 Aug 2009
The problem you are having with the 314 in openbve is solved by pressing CTRL+A, then pressing the AWS cancel button. Then press CTRL+A again to exit AI mode. Hope this helps
SuperSprinter
25 Feb 2011
Essex
Aha I see, I shall try that :), as it was a shame having to rename files and losing some of the sound. Thanks :D
Regards
Kris
