D365
- Joined
- 29 Jun 2012
- Messages
- 11,459
I presume the arrangements with the trolleys will also remain the same with the 365s.
365s are trolley-compatible?
What kind of luxury is this?!
It depends at bit on the guards discrestion. On a peak time commuter train the guard may well check tickets in both sets. But on a weekend night or football/rugby day when the chances of trouble or passcom alarms are much higher the guard may well choose to remain in the rear 3 set. The guards are quite good at making the call on what to do.
there would also be a visible BTP presence to nip anything in the bud.on a weekend night or football/rugby day when the chances of trouble are much higher...
Some do but not generally. If a passcom was to be activated in the rear set and both the driver (obviously ) and guard were in the front it would require a line blockage to enable the guard to return to the rear set to reset. Delays and pain in the bum. 1 member of staff in each set and a is well.
on the odd occasion I've travelled to/from a game there's been a presence. I accept it would not be standard procedure but if there's intel that suggests possible trouble they would make their presence felt.Not likely. They don't travel on trains generally. Tbe vast majority of trains I drive have no police presence.
Depends where it is. On the up South or down North at Haymarket as an example then yes. Other locations maybe not.Would they really take a line blockage for that? It's no different to the driver using an SPT as long as you stay cess side and use the train as protection.
It doesnt. The majority of passengers on this route board or alight at Edinburgh or Glasgow both of which have ticket barriers. There isn't a great deal of ticket fraud on this route
They had trolleys when introduced between Cambridge and London. I think that ramsgate route had them as well.
I had a feeling there might have been, but I’ve certainly not seen it in my lifetime
With both termini having the relevant platforms accessed past the buffer stops, having gangways between units should help distribute passengers down the train. But they've managed without them on the 170s so they should be able to do so for a few months longer on the 365s.Some do but not generally. If a passcom was to be activated in the rear set and both the driver (obviously ) and guard were in the front it would require a line blockage to enable the guard to return to the rear set to reset. Delays and pain in the bum. 1 member of staff in each set and a is well.
You mean they're going by ROAD? Sorry if I've missed something. Surely they could be dragged at least as they can't be out of gauge, being the same dimensions as the class 325 mail units, but what's the problem with running them under their own power? This never used to happen under BR (but then nor did many other things).365523 was at Charnock Richard services this morning.
The first two units went by road. The third unit was dragged via the WCML. I think all further units are being dragged.You mean they're going by ROAD? Sorry if I've missed something. Surely they could be dragged at least as they can't be out of gauge, being the same dimensions as the class 325 mail units, but what's the problem with running them under their own power? This never used to happen under BR (but then nor did many other things).
I stand corrected, didn't realise that 517 also went by road!Three units went by road - 523, 513 and 517. 525 was the fourth and was the first to be dragged up the WCML.
And likely they started on the route clearance within Scotland first, and only after that was done started trying to get a better plan for moving them north. Because, again, without the route clearance in Scotland they can't do anything, and moving them there are obvious alternatives (see: those that came by road).The first couple of units were taken by road, although latterly they've been dragged up the WCML. They aren't the same dimensions as the 325s - the 325s are 319s with Networker cabs rather than pure networkers. It's also worth noting that the advantage of taking them by road is that they could go straight away and get into service sooner. Assuming route clearance began at the same time as the plans came about, the fact that the first unit was only dragged up recently gives an idea of how long it takes to sort it out, in the mean time a number of units have gone up and started training drivers on them. Who cares if a few trains go up by road if it means that they get into service sooner, I'm sure the people who'll benefit from the additional capacity on the Edinburgh - Glasgow line don't care one iota.
... but what's the problem with running them under their own power? This never used to happen under BR (but then nor did many other things).
I remember them in 2005-2006 on weekends, doing no business.I think they disappeared around the time national express took over WAGN after they bought out prism. So at least 15 years ago.
Speaking of WAGN. Anyone remember the local vandals changing the “thank you for travelling WAGN for free”. Same problem exists in Scotland. Short journeys between unstaffed station passengers take their chance and travel in front set. In fact it is worse up thier as no penalty fare scheme exists, so you can legitimately wait for the guard.
Yes I know you should buy before you board. But unless things have changed recently TVMs don’t take cash and the ticket office staff often have other priorities.
I think therein lies the problem. Although I am basically a supporter of privatisation, one of the things that appears to have been lost is standardisation in areas like gauging.BR didn't operate the Class 365s, so I don't know how you can suggest that. The Class 325s, as Domh45 points out, are Class 319 derivatives rather than 465 derivatives. Any comparison between the Class 325 and Class 365 is like chalk and cheese.
So presumably the size of the 365 was very much decided by BR, given the lead times...
