Class 365s to Scotrail
Discussion in 'Traction & Rolling Stock' started by Class465fan, 19 Mar 2018.
  1. alangla
    alangla Member
    653
    11 Apr 2018
    Yep, plus the flexi-pass as a daily season ticket brigade - you can spot these as they're always scrambling for a pen on the rare occasion a gripper appears on board.
  2. gordonjahn
    gordonjahn Member
    130
    23 Oct 2010
    In fairness, having just arrived back home from the station where there are no trains running, who'd fill it in before a train actually shows up?!? I can't imagine getting your money back/ a replacement on a filled-out but unused paper flexipass is easy or quick. Besides, that'll all be fixed when they're all on Smartcards.
  3. HellaEllie
    HellaEllie Member
    124
    31 May 2015
    Falkirk :D
    any news of more coming?
  4. Chris125
    Chris125 Established Member
    2,417
    12 Nov 2009
    Surely that was something that came about under BR - perhaps the most obvious example are the 165s/166s which exploited the more generous loading gauge of ex-GW routes.
    If anything privatisation has helped - the rolling stock market, and the possibility that fleets may move multiple times during their working life, has given ROSCOs an incentive to procure 'go anywhere' designs like the Electrostar and Turbostar.
  5. fgwrich
    fgwrich Established Member
    5,194
    15 Apr 2009
    Between Edinburgh and Exeter
    I rather agree with you there. Don’t forget that NSE also had a particular habit of specifying electrical couplers to be at a different height or the opposite way around to other BR stock of the era - to quote Chris Green and his team “to not allow Reagional Railways to poach it’s own stock”. Ok, so the 185s May be the only post privatisation DMU that may be difficult to transfer but that’s more down to the specifications they were built for than anything else.
  6. hexagon789
    hexagon789 Established Member
    6,560
    2 Sep 2016
    Privitisation has definitely helped the rolling stock market. Though I do wonder whether we'd have some of the stick we have now if BR still existed.
    Mind you if BR still existed we might have had HSTs in Scotland already including on the E&G, I'm not sure we'd be having the hotchpotch stock situation and the transfer of 365s.
  7. stu99
    stu99 Member
    106
    19 Feb 2016
    Hexham
    Any updates since they were out on the 10th and the 11th? It seams to have gone quiet.
  8. scotraildriver
    scotraildriver Established Member
    1,130
    15 Jun 2009
    Lots of conductor training this week at Eastfield so less movement. Also alot of focus on the modified 385 this week as well.
  9. stu99
    stu99 Member
    106
    19 Feb 2016
    Hexham
    ahh that is good to know, thanks :)
  10. InOban
    InOban Established Member
    2,258
    12 Mar 2017
    Any rumours on the performance of the modified windows?
  11. td97
    td97 Member
    559
    26 Jul 2017
  12. 158_Reason
    158_Reason New Member
    2
    22 May 2018
    I know the step boards have been removed from these 365s for clearance issues, But looking at the videos there's plenty of room at the platforms for these. If you compare the videos of them leaving stations down south and stations up here, there doesn't seem to be any reason for removing them. There@s equipment below the sole bar level which sits above the platforms here the same as it does down south. A bit technical but seems another over reaction by boffs up here. I don't like them without the step boards the doors look an odd shape but I am a fan of 365s overall and i'm pretty sure some clown on the E and G will miss the step and fall over.
  13. Domh245
    Domh245 Established Member
    4,608
    6 Apr 2013
    The stepboards were removed temporarily so that they could get training on them ASAP. Unfortunately looking at it and going "ah, it'll be fine" isn't a particularly fool proof method, so whilst they run the numbers and verify that they won't hit the platform when heavily loaded, on adverse cant, etc, the stepboards come off. With any luck, they go back on as they were, but worst case they need 'shaving' before reattaching.
  14. D365
    D365 Established Member
    6,359
    29 Jun 2012
    You know something that the Network Rail rolling stock engineers don’t? ;)
  15. Highlandspring
    Highlandspring Established Member
    2,392
    14 Oct 2017
    The step boards will have 45mm removed from them before the units can enter service.
  16. gingertom
    gingertom Member
    718
    19 Jun 2017
    Kilsyth
    doesn't sound like an expensive or time-consuming mod.
  17. D365
    6,359
    29 Jun 2012
    Angle grinder will do the trick!
  18. hwl
    hwl Established Member
    4,432
    5 Feb 2012
    Not neatly though.
    Sounds like custom jig for a milling machine time...
  19. cjmillsnun
    cjmillsnun Established Member
    2,990
    13 Feb 2011
    I’m waiting to see what will happen to the 458/5s post SWR. I have a feeling they will sit in sidings unused.
  20. 59CosG95
    59CosG95 Established Member
    4,204
    18 Aug 2013
    WIM/PBO
    Surely that's a question for a separate thread; this thread was set up regarding the transfer of 365s to ScotRail, not 458s to somewhere other than SWR.
  21. urpert
    urpert Member
    896
    1 Dec 2015
    Zone 5 or between Étaples and Rang-du-Fliers
    I'm hoping they will form part of Stagecoach's successful bid for Southeastern :)
  22. 43096
    43096 Established Member
    5,547
    23 Nov 2015
    Which is also nothing to do with ScotRail 365s.
  23. D365
    6,359
    29 Jun 2012
    Discussion of Southeastern/Kent franchise options continues here.
  24. Clansman
    Clansman Established Member
    1,931
    4 Jan 2016
    Already proposed & discussed to death by most members (including myself) in other threads which may interest you should you use the search bar at the top right.
    EDIT: In addition to D365's post, the most recent and relevant thread on 458 speculation and what not can be found here.
  25. 158_Reason
    2
    22 May 2018
    most people on this seem too, so stuck my bit in too. I suppose working for network rail gives me the edge tho.
  26. Far north 37
    Far north 37 Established Member
    1,501
    13 Apr 2011
    Sounds like you dont know much about the fabrication industry i am a fabricator myself and that is a tiny minor job that any skilled fabricator could accomplish leaving the same finish as that of a milling machine in a fraction of the time we build warships oil rigs and giant steel structures in the uk trimming a step board wouldnt exactly be hard.
  27. Jonny
    Jonny Established Member
    2,048
    10 Feb 2011
    Does anyone know which routes the 365s used/will use to come to Scotland?
  28. InOban
    2,258
    12 Mar 2017
    According to much earlier posts the first two came up by road but the third was hauled up the wcml. Haven't heard since. I don't know how many have arrived by now.
  29. ScottDarg
    ScottDarg Member
    574
    27 Apr 2017
    South Lanarkshire
    Only 4 365s in Scotland at the moment.
    The first 3 came up by road (365513, 517 & 523) and the 4th (525) came up via the WCML. There's been no moves since 365525 arrived earlier this month (11/05/18).
    365513 and 523 are at Eastfield. 517 and 525 are still at Springburn I believe.
  30. ScottDarg
    ScottDarg Member
    574
    27 Apr 2017
    South Lanarkshire
    RailEngineer has posted an article today that talks about the start of full electric service between Glasgow Queen St & Edinburgh via Falkirk High using Class 365s: https://www.railengineer.uk/2018/06/01/full-glasgow-to-edinburgh-electric-service-in-july/
Share This Page
