Class 379s or 350s for Corby?
D365
29 Jun 2012
Mod Note: Posts #1 - #15 were originally in this thread.
Could they be used on At Pancras to Corby. Or maybe 350/2s will be used there instead.
What would you have in mind for the 379s in that case?
pt_mad
26 Sep 2011
Nothing is confirmed for Corby, but 379s would be a good solution.
In other news, 365523 was at Charnock Richard services this morning.
can 379s operate at speeds up to 110mph though? The 350/2s are slowly being adapted to 110mph operation.
Ianno87
3 May 2015
379s only officially 100mph. Whether they can be 110mph capable, don't know (no electrostar yet is).
They never see higher than 90mph on their current West Anglia duties.
pt_mad
26 Sep 2011
Parts of the midland mainline are said to be 125mph operation now. So 110mph is certainly gonna be more useful than 100mph stock. And the 350/2s won't need to be converted as by the time LNR lose them the fleet should be 110mph across the board.
class387
9 Oct 2015
387s definitely can do 110mph on GWR.
D365
29 Jun 2012
The 387s are capable by design. I believe one of the 379s was temporarily updated to 110mph as part of the testing process for the former.
pt_mad
26 Sep 2011
I would guess the 350/2s would be preferable as LM won some sort of award for them last year being the most reliable EMU in terms of miles per technical incident in the UK.
Domh245
6 Apr 2013
nowhere
It depends on the lease prices, and how much it'll cost to refit the 350/2s to a more suitable interior.
pt_mad
26 Sep 2011
Good point. It's often reported the maintenance regime Siemens impose on the 350/2s is expensive. And I suppose the Electrostatic already have a suitable interior and wouldn't really need a refit?
gingertom
19 Jun 2017
Kilsyth
anybody know what a 385 is capable of? Traction gear is derived from the javelin and we know what that can do!
gingertom
19 Jun 2017
Kilsyth
designed for 100mph
am aware of their design speed. Just wondering what they are really capable of, bearing in mind what the traction packs' pedigree is. perhaps there is scope for upping to 110+mph should the need arise, and should we ever get some decent stretches of track to deploy it on....
43096
23 Nov 2015
No "said to be" about it. The MML has 125mph stretches that are used at that speed by both 222s and HSTs - fact.
SPADTrap
15 Oct 2012
Where will the sets be maintained and stabled and who will do the maintenance and trips to and from wherever that is? If there is an insistence on Bimodes for the Midland then I can see Corby being worked by Bimodes to keep it simple.
Kite159
27 Jan 2014
West of Andover
Isn't it 125mph for diesels, but a lower speed under the existing wiring?
Agent_Squash
22 Jul 2016
350s would be better IMO - might be some commonality with the 700s which make up the majority of services on the MML anyway. 379s can then have shoes stuck on again and go to Southern.
Roast Veg
28 Oct 2016
There's no real need for commonality, and the difference between Desiros and Desiro Citys is pretty stark. The 379s are much better fitted out internally, and the requirement for running above 100mph on OLE isn't going to be available for some time, given the upgrade work required. The class 379 modifications can be done at a similar time to the infrastructure work.
Agent_Squash
22 Jul 2016
They never had third rail shoes did they?
379s are still capable of using 750V DC, as it would simply feed into the DC bus.
I'd imagine the requirements for certifying a unit for 110mph will cost much more than those to refit the 350s with the interior requirement. The 379s would be much better south of the river on the Southern (where there is the commonality for sure with the 387s) and the 350s north of the river.
Roast Veg
28 Oct 2016
As far as I know (and I could be wide of the mark here) the modifications required to get a 379 up to 110mph are only a pantograph change and a software modification - assuming that the 387 commonality is as true as you suggest. If that's not the case then I would argue that neither units are particularly suitable.
D365
29 Jun 2012
Is there not the stated aim to run twelve car trains to Corby? 110mph with three pantographs has been one of the difficulties when it comes to GWEp. Indeed that’s partially why 110mph is not possible with GN’s 387s.
dk1
2 Oct 2009
East Anglia
Yes. Nothing more than 100mph can be permitted for electric traction between St.Pancras & Bedford. That's another multi £million job for the extra speed.
hooverboy
12 Oct 2017
if they had any brains they would do compulsary purchase of stewartby brickworks.
then you'll have :
1)impetus for getting marston vale east-west rail section going(and wired)
2)clearance of spaghetti sidings at bedford and bletchley...necessary for re-modelling track into bedford station,and enables MK direct loop.
D365
29 Jun 2012
The OHLE upgrade is costed as part of the Corby electrification.
DarloRich
Fenny Stratford
350's are a very good train. You Midland types cant have them. They are ours on LNWR.
then you'll have :
what are you on about? Stewartby is earmarked for a massive housing development. You may as well make the case of using Blethcley depot! BTW What MK direct loop? What "spaghetti" sidings?
