Class 387 First Class provision
387star
Often wondered why TL 387s have a large first class area with a different seat fabric design with the privacy screen door always being open.... First class is only provided at the cab most end of the coach
The Gatwick express 387/2s are identical and make full use of the first class space with the sliding door being closed
I did wonder if the first class provision had GWR in mind but they were built before it was known they were transferring hence southern colours?
Or is it because they wanted flexibility
Anyone know?
Of course the seats as we all know are identical to standard
AM9
13 May 2014
St Albans
... I did wonder if the first class provision had GWR in mind but they were built before it was known they were transferring hence southern colours? ...
Don't you mean, they were built before it was known by members of this forum that they were transferring? They aren't in Southern colours anyway. If anything, the doors look just like GWR colours and white is remarkably similar to Southeastern, C2C, maybe others. The seats will need recovering soon into their new deployment so what part of their delivered colour scheme looks like a long term commitment to Southern who I believe were acting as a procuring organisation on behalf of the DfT.
westcoaster
4 Dec 2006
DTOS A or B
The door is left open on TL services, so people can see through to see available std class seats. As the divider is fully frosted, it stops critical overcrowding in the half coach.
387star
thanks but not really answering the question as to why the divider is there rather thanat the position of a 377/4
Your wrong
Doors are southern green
And I meant the southern colours in the interior
Southeastern is going blue now and C2C likewise AGA only went white as their framchises were due to change
Isn't the divider at exactly the same location as it is placed on a class 379 unit? The point is that first class is at one end of the unit rather than at both ends on a 377/4.
Whether the designer of the 379 thought that the provision of first class was about right and that settled the position of the divider for future builds is a question only they could answer.
Fincra5
6 Jun 2009
Anyone know?
Because they're all just built to the same spec (Cheaper AFAIK) on the modular design of the 387...
If you look at 377/6-7 you'll see the same layout. On the 6 series the 1st Class was in the larger part of the divide near the cab but seems to have been moved to the smaller area (near the gangway).
TLK have them open, as pointed out, the whole area isn't FC and therefore invites people to the other area.
AM9
13 May 2014
St Albans
... And I meant the southern colours in the interior
The 387s when ordered were a short-term fix to get over the DfT's delays in ordering the class 700s. The 377/6 and 377/7s were the last Electrostars ordered for GTR services until the Gatwick Express 387/2s. Electrostars delivered from the 377/6 &7 batches are different in many ways from the 375s and 377/1 to 377/5s. When delivered, they weren't even software compatible with the earlier stock according to postings here at that time. The 379s and 387s were also of the newer design systems. So with a modular interior design, it is not surprising that they are similar to each other and rather different to the earlier Electrostars. With such a modular design, the fixed structures inside are left as standard, and TOCs will just play tunes on the seat cover colours.
As the 29 class 387s were destined for ultimate use on OLE lines, (GWML, MML or Kings Cross outer suburban post Thameslink Programme, they were ordered in 'vanilla' paint scheme and as far as I am aware, there are no Soutern EMUs or DMUs painted thus. The green on the doors is of no consequence as it can be changed much more easily than the whole gerrn ends of other Southern coaches. There is no equivalent for interiors so the 377/6 & 377/7 schemes which had just passed through the factory were used. Clearly this pleased GTR as they were proudly telling everybody on Thameslink routes that they had new trains (which looked similar to but better than the blue/pink exterior 377/5s that were loaned when FCC required more capacity).
Interiors get changed fairly quickly, usually as part of a branding exercise (I've travelled on several 319s since they were 'refreshed' for Northern and they do look sufficiently fresh and Northen'ish for passengers there to see them as their own). Just look at the myriad of liveries both outside and in, that the current Thameslink trains have:
319s in FCC blue/pink
319/2s in Southern greens
319s in white with blue doors
319s in white with pink doors
377/2s in Southern Green
377/5s in FCC blue/pink
387/1s in white with green doors
387/2s in Gatwick Express red
and from next month, 700s in white/grey, (until the marketeers paint them something else)
At the end of the day, colours don't make any real difference to passengers, - it's only the enthusiasts and the marketeers who really care.
In 18 months, the 29 Class387s will be plying GWML routes with whatever colurs GWR want to use to claim that they are 'brand' new.
TEW
16 May 2008
The 387/2s I've seen in service on Gatwick Express duties have First Class in this area too.
