Class 397 TPE "Nova 2" Diagrams
Lengthening them would require a track layout change wouldn't it
Assuming it's only Manchester Airport that's an issue (which is a reasonable assumption as 11-car Pendolinos serve everywhere else it serves other than Lockerbie which I think has a fairly long platform) they could add a second unit at Preston for the WCML bit which tends to be busier. Preston has the platform space and sidings to handle this.
InOban
12 Mar 2017
I thought that the busiest section was between Preston and Manchester.
railways45021
27 Nov 2019
Salford
The platforms certainly look quite long but one or even carriages be off the end that be the problem
Back on topic for this thread (being as it's about diagrams) does anyone know what they are likely to be (cancellations aside) for Saturday? Going to have another attempt.
MDB1images
9 Jun 2018
I was told that this Saturday will see the same diagrams operated as Mon-Fri(can't be fully correct as some of the trains don't run.....)
A tad sceptical that will happen and experience would say might be worth until you see what's allocated as things get altered very late on.
On the other 397 thread (in which I erroneously posted about diagrams confusing it with this one) it was suggested that the Edinburgh diagrams varied from day to day because it's a multi-day circuit for each unit, though?
MDB1images
9 Jun 2018
The Edinburgh diagram is booked the same all week.
The booked Mon- Fri diagrams are....
1M99 06:28 LAN-MIA
1S38 08:07 MIA-EDB
1M97 12:12 EDB-MiA
1S75 16:07 MIA-EDB
1M95 20:11 EDB-MIA
1S35 07:07 MIA-GLC
1M96 11:08 GLC-MIA
1S71 15:07 MIA-GLC
1M94 19:08 GLC-MIA
1S98 23:10 MIA-PRE.
The booked Saturday Glasgow diagram is..
1S30 05:00 MAN-GLC
1M94 09:07 GLC-MIA
1S61 13:07 AIR-GLC
1M92 17:10 GLC-MIA.
As said the plan for tomorrow is to run the Mon-Fri diagram.
On the EDB circuit we don't run 1M95 on a Saturday so the Unit is generally swopped mid shift to get it to Longsight.
It isn't unusual for changes on a Saturday thus the caution advised regardless of what's planned on the Friday for Saturday!!
Today only the Glasgow diagram ran.
Cheers. Shall see what I can find, I suspect I'll need one more go :)
Edit: In case tomorrow is a no-go (which I think it might be, they don't really fit with my journey), are there any on Sundays?
MDB1images
9 Jun 2018
Sunday is.....
1S46 10:10 MIA-EDB
1M99 14:12 EDB-MIA
1S83 18:10 MIA-EDB
1M67 22:10 EDB-MIA.
If the 397 off 1S75 Saturday does go to Polmadie you'll also get...
1M96 11:05 GLC-MIA
1S71 15:10 MIA-GLC
1M94 19:15 GLC-MIA
1S98 23:01 MIA-PRE.
397006 allocated on diagram that begins with 1S35.
398003 allocated on diagram that begins with 1M99(003 will be 1st class at front heading North).
Cheers.
Do you know if they are both still out? I notice that both 1S71 and 1S75 are starting from Preston, if either/both of those are 397s I might be able to catch one for a short ride.
MDB1images
9 Jun 2018
Cheers.
006 100,% was due to.
003 got looped at Abington to get 1M96 in front of 1M97 as it was hoped to put 1M96 passengers on 1M97 when it got spun at Preston so 003 was staying in traffic(believe 1M97 then got delayed at Carlisle so was being spun at Preston).
Thanks very much for all this information. I got a short ride on 1S71 between Penrith and Carlisle. Will post about thoughts on the other thread being as how this one is about diagrams! :)
InvHst
9 Dec 2018
397 diagram today bit of a strange one
0905 Manchester airport to Glasgow was due to be 397005 but terminated at Preston due to crew shortage I should have been on it but had to put up with a 185 instead
skh93
11 Feb 2018
Have any of them been out and about today? And how will todays problems on the line have affected which services they've run?
MDB1images
9 Jun 2018
003 was on 1S35 diagram
005 was on 1S38.l diagram
Both are North side of Hest Bank closure.
cambsy
6 Oct 2011
I’m up in Manchester on Saturday 25th Jan, Are the diagrams the same as in post 218 or have they added any more yet? Thanks
Jamesrob637
12 Aug 2016
Any more diagrams from Monday? There's always a 185 substituting according to Journey Check so TPE really need to get a couple more of these into service.
MDB1images
9 Jun 2018
Both units started on diagram but ended up off diagram on Monday due turnbacks at Carlisle.
397006 ended the day on 1M67 22:12 EDB-MIA.
skh93
11 Feb 2018
Saw this passing BON on its Northbound journey 1S83, strangely it was only displaying Preston not Edinburgh. Anyone know why this was the case?
dk1
2 Oct 2009
East Anglia
WCML was blocked north of Preston following the storm.
Jamesrob637
12 Aug 2016
Are TPE ramping these up from Monday as the full timetable is due to come into effect then?
I know I keep asking but I keep failing to get one :)
Are any out today (presumably on modified diagrams due to the line closure at Carlisle)? Might be nice to grab one between Lancaster/Preston and Manchester if viable. Should be quieter than usual too!
driver9000
13 Jan 2008
The route is open fully and both normal 397 diagrams are out.
J-P_L
7 Sep 2017
11/02/2020
397006
1S35
07:07 MIA-GLC
1M96 11:08 GLC-MIA
1S71 15:07 MIA-GLC
1M94 19:08 GLC-MIA
1S98 23:10 MIA-PRE
397007
1M99
06:28 LAN-MIA
1S38 08:07 MIA-EDB
1M97 12:12 EDB-MIA
1S75 16:07 MIA-EDB
1M95 20:11 EDB-MIA
