Someone has recently posted in wnxx that signals are still being tripped. Doesn’t sound good if true...
Sorry to be niave but what is wn?
AIUI they will be 4 x 300kW, so yes. It’s the same traction electronics as the 455 but with the higher powered motors of the Renatus 321s.Are the new traction motors the same power as the old ones (1600hp)?
So... just to be clear, it’s definitely 100% the static converters which are causing the issue? I got the impression - rightly or wrongly - that SWR’s engineers didn’t really know what the problem was and that the static converter was just singled out as being most likely cause.
The new traction package has been proved in its separate elements. As discussed above. However from what I make of what’s been said, those elements have not yet been tested as the ‘whole package’. And that’s before they’ve even been taken out on the track.
Assuming the strike goes ahead, the strike timetable doesn’t utilise the 442s which would give SWR pretty much until January to ‘test and train’. 6 weeks looks pretty dicey for reintroduction of just the one that’s supposed to have the whole package. I suspect it’ll take more than just a good deal of luck to meet the requirements of the new timetable - when it starts properly - without short-forms, cancellations, and turnarounds short of destinations to prevent overcrowding.
Interesting. RTT is showing a 5Q95 1848 Waterloo to Portsmouth Harbour via the New Line on Monday. I’ll do a bit more searching.
why would they choose to test it in the mainline path of 1B95, during the rush hour?
There was a Bournemouth to Clapham Junction move late Friday evening, followed by a few 5Qxx paths back and forth to/from Surbiton. Were they for 442 testing?
https://www.realtimetrains.co.uk/search/detailed/SUR/2019-11-23/0010-0230?stp=S&show=all&order=wtt
Thanks. I noticed there was a third out and back Surbiton trip that was cancelled, I wonder whether that meant early success or early failure...Yes, it would have been. I think this was postponed from the previous Friday/Saturday morning. If the empties then ran to Fratton this would mirror what was meant to happen the previous weekend and would explain why there are units now at Fratton.
Your are right, the empties ran back early to Bournemouth (not Fratton as I assumed). Trying to find out where the units at Fratton came from (possibly Direct from Bournemouth). I’ll have a dig round.
There’s also a 2116 ecs from Poole to Basingstoke and back to Bournemouth on Tuesday (the stock off the 1848 ecs from Waterloo). Interestingly both RTT and the public timetable show the 0628 Southampton Parkway to Waterloo and 1848 Waterloo to Poole as being reinstated from Monday 2nd.
Unless I'm missing something, I can't see a 2116 ECS off Poole on 26/11????
I believe Thumper1127 quoted the wrong day. It is Wednesday.
5Q96 2116 Poole to Basingstoke
5Q97 2303 Basingstoke to Bournemouth TRSMD
