Class 442s - Now at the end of the road and to be withdrawn permanently
theironroad
21 Nov 2014
I don't believe they were ever supposed to re-enter service on SWR with the original traction motors - the retractioning project has been delayed.
The plan from the outset was to introduce them all with DC traction. Once all 9 X 10-442 formations were in service, 7 out and about each day, 1 spare and 1 in maintenance then the plan was to withdraw them one by one to retraction.
Obviously the whole project is way behind but I believe the retractioning is still going to happen, though crew conversion training for drivers will then have to be undertaken.
456WWWM
19 Feb 2020
Bournemouth
Took the 18:48 from Waterloo to Bournemouth today, stuck around after a work event for a few hours to catch a plastic piggy for the first time.
I like the paint job on the exterior, they look better than the class 444s at the moment until they've been repainted from the SWT livery. Quieter ride than the 444s but as others have said the seats are not as good. The USB charging is pitifully slow which is a shame, and I also noticed that some carriages are abnormally warm.
winks
11 Jun 2009
Caught the 21.12 from Clapham this evening (delayed by 14 mins) presumably by the interference with signalling. They seem to lose so much in dwell times and slow acceleration I can’t see how these units will ever be on time
theironroad
21 Nov 2014
Why did you presume it was signal interference? AFAIK, there's not been a issue with 442 and signals for weeks now.
However, the inbound working that forms the 2105 didn't arrive into Waterloo until 2110, so there was a late start. The inbound service was delayed from haslemere inwards following a stopping service which also stops at CLJ .
The 442s certainly still have some issues, but signal interference isn't really one of them at the moment.
theironroad
21 Nov 2014
Apparently the thermostats have been reduced from 21 to 20c but it's fair to say that some of the carriages are still too warm. However, it's a 10 car and there's probably a suitably variation in each carriage to suit everyone.
Dibbo4025
21 Mar 2018
From my observations they will keep time if they're given a clear run - as in terminal starter off at least a minute before departure and the least restrictive aspects on the fastest path (which on some trains esp up trains just before Guildford requires other services to be out of their paths) - and a following wind they can just hold time but on such a busy network this just doesn't happen.
pompeyfan
24 Jan 2012
There was disruptive youths (AGAIN) at Farncombe which blocked the down line for 30 minutes, as a result crews and stock were out of place causing some displacement, including onto the 2105 off of Waterloo.
Thumper1127
19 Jan 2019
Let’s hope that if they are caught and prosecuted they don’t get the pathetic £4.80 fine plus £36 victim surcharge metered out recently to a guy for trespassing at New Milton!
theironroad
21 Nov 2014
Not helped by a long standing 20mph temporary speed restriction just London side of Guildford on mainline which means a long slow drag out of Guildford.
Numerous other speed restrictions across the network all add to these delays and as people know the acceleration on 442 has never been great, so recovering from every emergency or temporary speed restriction or restrictive signalling is a challenge even when rail is dry. 442 are more sensitive to poor railhead conditions and that means even slower recovery. If an up train is more than a few minutes late presenting at Woking jnc then it's lost its pathway and the rot just gets worse and before you know it it's 10-15 late into Waterloo.
Thumper1127
19 Jan 2019
The 0714 Portsmouth to Waterloo yesterday ran well all the way to Woking junction yesterday when it was stymied by what looked, real time (I was watching) as a regulation error. The up Bournemouth was running a few minutes late which would have put about another minute or so on it but after that had cleared it just sat at the junction. The down Alton was allowed to proceed first. Unless there was an actual signalling or points issue this was a significant regulation error as there was ample time for the 0714 to cross. 1 min late at the junction, 8 late into Woking.
theironroad
21 Nov 2014
Not really surprised, I've not looked but wouldn't be surprised if the down Alton then sat at brookwood for ages.
I certainly don't want to have a go at signallers, especially as Woking and the junction are busy places, but some of the decisions that happen there are a bit odd. The pigs, any pig will fly before the long hoped for flyover ever happens at Woking jnc.
Thumper1127
19 Jan 2019
No, me neither re having a go at Signallers in general, there can often be tough calls to make but this would seem to be a bit of a howler. The Alton was booked to stand at Woking for 4 mins and my guess is that the signalman pulled off for it having overlooked this, blocking the up Pompey line. I doubt he/she will make the same mistake again in a hurry! Apologies to all if I’ve interpreted this wrongly but watching it real time certainly seemed to suggest this was the case and the RTT records seem to support it.
Back on topic I’m hoping to get my second 442 trip next week. Will post findings.
winks
11 Jun 2009
Well the automated station announcer at Clapham said the train was delay due to a fault with the signalling equipment yet all other trains seemed Ok
Bigfoot
2 Dec 2013
There was a points failure on the up slow at New Malden, everything was put onto the up fast which delayed inbound services. Signalling faults are a huge range of things, not all is caused by the 442.
The Ham
6 Jul 2012
That's acceptable if the victim surcharge is the amount for every victim of the incident, as that would run to tens if not hundreds of thousands of pounds given the number of passengers involved...
physics34
1 Dec 2013
Without me havent to look through everything can someone quickly tell me roughly what time the 442s leave clapham on the way down to portsmouth.... between 09.00 and 12.00. Thanks
spark001uk
20 Aug 2010
The only 442 which stops at Clapham is 9B69; the 2105 Waterloo to Poole.
So if you want a Pompey 442 you'll have to get it from Waterloo I'm afraid.
Thumper1127
19 Jan 2019
Feel a bit guilty that my earlier response was curt but I was in a rush. Weekdays out of Waterloo:
0800, 0830, 0930, 1230, 1300, 1700, 1715, 1730. Suggest pick from Waterloo or go from Clapham to Woking and pick up from there (but not the 1715 which goes via Cobham).
pompeyfan
24 Jan 2012
Eventually when the 9Gxx service starts running as 442s on Sunday they’re Waterloo, Clapham, Guildford, Havant so should make a fine sight squealing through Petersfield and Haslemere.
K.o.R
6 Dec 2017
As in non-stop Guildford-Havant? I remember the "super-fast" services, way back when.
I have a question: Along the ends of the carriages, where the end is joined to the roof, there is what looks like a very very poorly-done weld, or what would happen if you painted a line of paint remover across the paintwork. What's that all about?
Is it some sort of a sealant between separate sections, where the cab front can be removed in one piece?
K.o.R
6 Dec 2017
I don't recall seeing it on the cab ends; this is only on the normal coach ends (all of them).
It looks like where two pieces are joined, but it just looks so badly done and very out of place on what is, overall, a pretty well-finished vehicle.
I just went back to the fairly recent pic of the smashed window in post #4898. That join also seems to fit your description?
physics34
1 Dec 2013
Thanks everyone for the info... got the 12.30 (12.55) from woking and the return from PortsmouthHbr. Good to ride a 442 again. Smart and comfortable as usual.. although the USB ports didnt work
winks
11 Jun 2009
What’s the top speed potentially these units can get up to running the Waterloo to Poole route ? I know their top speed is 100mph in theory but what’s the highest section of the route for speed ?
