Class 442s - Now at the end of the road and to be withdrawn permanently
VEP3417
27 Jun 2011
Hampshire
be nice if they where to sell little mementos off before they started scrapping the rest of them, who dosnt want a guards van slam door style twist door handle :lol:
Mollman
21 Sep 2016
Also known as the Explodey AC Traction...?
I still honestly don't see the point in re-tractioning something that only realistically has a lifespan of another 2 - 5 years.
It is the usual issue with the railways. Re-tractioning was all the rage when DfT favoured price over quality with the 321s expected to last another 10 years. Now new stock counts towards a successful bid the lifespan of re-tractioned units is a lot shorter than expected.
fgwrich
15 Apr 2009
Between Edinburgh and Exeter
And the modification to the GW HST Fleet. Some of those TC Conversions were less than 3 years old when they went for storage, now they're heading for scrap.
I don’t think it’s that black and white. With the SWR Franchise you had both fleet replacement of 455s with brand new (havying just been retractioned), and reintroduction of elderly 442s (still being retractioned). So both sides of the argument in one bid?
Mollman
21 Sep 2016
I see your point and I did think about that. It comes back to money in some respects. Replacing the 455/456s with 5/10 coach emus made sense but they probably couldn't then justify new emus from Portsmouth fasts so 442s were the obvious solution - retractioned to give extended service.
theironroad
21 Nov 2014
Video on my phone of one going into Fratton depot. There was another already in there
When was this?
Given that the 450's are able to be converted to use OHLE then it's entirely possible for Northern to use them as a replacement for their current EMU's.
(Runs and hides after suggesting that cast offs from the South should be used in the North!)
More seriously though they could be useful for routes which have a mix of 3rd rail/OHLE.
The 444's could be useful for the likes of XC on their Southampton to Manchester services with some extra wires. Likewise, GWR could find the 450's useful for Reading/Gatwick services with some wires.
Wouldn’t it be easier all round to just buy new stock for XC, such as the bimode IETs that are suggested every couple of months?
D365
29 Jun 2012
For those that haven't seen it, there's a discussion about potential options for replacement of the SWR mainline fleet here. :D
444045
25 Apr 2020
Dorset
Class 442 units that they got AC traction motors fitted are 2402, 2415 & 2419. All 3 units now currently at Wolverton.
Don Steedy
28 Jul 2018
It was not 2416. It was 2419.
And it was not being rewired at Bournemouth. And nothing to do with the cabs.
2419 is having some further modifications which will then be carried out to the other three AC units, and then the other 14 units as part of their traction conversion.
There is a separate work package regarding the cabs.
pigs bay
29 Sep 2018
Can anyone give any insight to the fate of the 442's now back at Eastleigh, and does any one know why only the motor coaches of 2405 and 2424 have been scrapped leaving them basically a state of like a 'new' 4 TC
Phil Scott
21 Aug 2017
I thought one of the driving coaches from 2401 had been designated for preservation. Could be mistaken though.
VEP3417
27 Jun 2011
Hampshire
looking at RTT looks like from the 15th theyre starting extensive daily testing again, about 10 times a day from bournemouth to staines up loop and back
i only checked from the 15th to the 30th but testing goes into next month but i didnt check that far ahead
spark001uk
20 Aug 2010
If you're referring to the 5Qxx workings, it was discussed a couple of months back that they are more likely to be test paths for the 701s, delivery of which has been delayed. As for why they aren't showing on RTT until the 15th, that's probably because they are currently getting set as planned cancellation, but this is generally only done a couple of weeks ahead. If you select the CAN switch on RTT and search again for today you'll see them.
gimmea50anyday
8 Jan 2013
Back Cab
I’m sure it was mentioned further up that some reformations are taking place to create some better condition units, the trailers will also go in due course once component recovery takes place. I suspect the motors have gone first because of the higher value metals in the control equipment
Nym
2 Mar 2007
Somewhere, not in London
Or perhaps Asbesdos issues?
I'm not sure if the line breakers etc would have still been ACM, but it has to be suspected as such.
cjmillsnun
13 Feb 2011
I doubt such a late build (even with reused traction equipment) would have an asbestos issue. Even if they did line breakers could be removed as a whole assembly and placed aside before wholesale scrapping begins.
VEP3417
27 Jun 2011
Hampshire
ahh yes just seen about half of them are cancelled, diddnt know about the 701s when do they start to be tested?
444045
25 Apr 2020
Dorset
Neither 5O86 1018 Derby RTC to Bournemouth Depot nor 010N 1048 Eastleigh Works to Bournemouth Depot have departed yet.
spark001uk
20 Aug 2010
5086 now running as 5F95 and left Derby 177 minutes late
It vanished for a while, but looks like it went via Leicester/Nuneaton. Back on track now, passing Water Orton (1505).
palmersears
20 Sep 2011
Incident at Tamworth has shut the lines through the high-level platforms, so it was sent the long way round.
spark001uk
20 Aug 2010
Ah yes, I see that now. Showing as fire svc attending 6E54 Kingsbury - Immingham oil, hot wheelsets apparently.
