GW43125
- Joined
- 8 Dec 2014
- Messages
- 2,049
A Christmas tree...
In this context...
A Christmas tree...
If they could get their hands on the remaining 6, would that be enough for all Waterloo-Portsmouth trains to be 2x442?
Nothing like enough, and it's fairly easy to confirm.
There's a 4 tph base timetable planned on a fairly long route, time wise. With the current timetable it takes over 2 hours Portsmouth Harbour to Waterloo, and a typical current cycle of leaving Portsmouth on one trip to leaving on a second is about 4 hours 30 min.
Divide that by 15 mins and you'll need 18 pairs, 36 units, then add on a typical maintenance margin of 10 % and you need about 40 units in your fleet.
The above completely disregards the fact that the stoppers may still have to wait at Haslemere and be overtaken as now - that would only add to requirements.
That's exactly why the 18 trains (9 pairs) - but maybe only 7 pairs available daily, can only cover a proportion of the service, and I predict there will be a majority of Desiros on the day to day service even under First.
I still reckon some of the stoppers will have to be 12.450 to maintain capacity and dwell times for passengers getting on at Guildford and Woking in the peaks.
The fasts are 93 minutes, but units, based on Saturday diagrams, alternate between stoppers and fasts, so currently run stopper up, fast down, fast up, stopper down. If you were to remove inter-working you would increase units required. Based on current timetable, for example, 07:15 up, 09:30 down, 11:45 up, but first only pledged 2+2 on fasts, so this would only require 16 units, plus a few spares.
If they did the sensible thing and looped the Haslemere stopper at Guildford you could take the fast journey time down to ~1h 27, which is where it it used to be.
Still quicker & easier to drive from the Guildford area to the coast than catch the train though.
Why don't they do it then, platform capacity at Guildford isn't usually an issue, put the down 2Pxx in P3 at Guildford and it's out the way.
Because isn't usually isn't the same as isn't at all - if basically anything goes wrong on any route between Guildford and, well, anywhere the station can fill up PDQ. Better for service robustness in disruption to do it at Haslemere where trains are to an extent out of the way
But they're not out the way at all at Haslemere, they're constantly in the way of the fasts or diverted Weymouth services. If the service is up the shoot then trains are going to be delayed regardless.
Here is my video of today's Class 442 drag from Stewarts Lane to Easbourne CS.
https://www.youtube.com/watch?v=1niLvA6pmSo
Does anyone know why a 73 was needed? Can the 442s no longer run under power by Southern?
This was 5Z42 today.
With the layout of the sidings at Eastbourne, 442 402 & 408 would have had to run under their own power at some point during the shunt to move out of the way and allow the 73 to attach to the other 442s (410 & 413, I believe).
I don't imagine that 73 has much of a life left with Southern, does it? Beyond work with the 313s and moves such as the one above, there won't be very much purpose for it in the mid future as far as I can see.
Driver refresh required on 73, So it killed to birds with one stone as the unit was required for exams.
There's probably a good case for changing the couplings and having one or more rescue locos for the more modern GTR stock - especially when it seems to take about 3 hours to react to a failure in the Thameslink core.
I would imagine the 73 to be best put to use by following the 442 stock to its new operator if and when?
Doesn't SWT still make use of a Class 73 loco?
Either way the FSW Class 442s will be converted to Dellner couplings I believe.
They do, but the Bournemouth based 73s aren't SWTs anymore. I'm not sure who owns the two 73s anymore (It used to be the Class 73 locomotive preservation company, then 'Transmart Trains') but these two are only used for the shunting of the 455 vehicles visiting for repaint and overhaul.
Given their near constant thirst for 73s, it wouldn't surprise me if 202 moves across to join the GBRf fleet at some point - It'd probably allow them to convert a /1 to a /9 considering the rather well kept condition 202 is in.
Where are the 442's going to get refurbished/retractioned?
It looks likely to be done at several different locations (one doing repainting, one doing interior mods, one doing retractioning, etc) but nothing has been announced yet. We can probably assume that Bournemouth will be doing something however, based on today's move.
Is Vosseloh Kiepe going to be involved in the 442 re-tractioning?
