Class 484 replacing class 483 on the island line: progress updates
Journeyman
16 Apr 2014
Over Christmas I read numerous website pages about the IOW railway. While a quick search now hasn't found it I saw a photo of a train with a gauging profile attached at a portal of one of the Ryde tunnels. This may have been for a previous idea. If so logic would say this should have been done again adjusted for planned track lowering and / or to determine the current limit and hence determine the adjustment required.
That was part of a mid-eighties plan to use class 503s retired from Merseyrail.
4 Dec 2020
Ashford, Kent
I did see the gaugeing photo on twitter.
Also remember this being on RM Web. It does talk about converting to single line back in 1983/84.
A 503 still exits and it is at Margate, Kent at present.
  • IWR Class 503 Proposal 1983-04-25 -.pdf
19 Aug 2015
Any more news on whether the new trains will actually fit or if the engineers are having to come up with a plan b?
pompeyfan
24 Jan 2012
There has been 2 class 20 locos shuttling between Fareham and Eastleigh the last couple of days, this is apparently in relation to mileage accumulations but I can’t see the connection unless the 484s will be running between Fareham and Eastleigh to get the miles up?
spark001uk
20 Aug 2010
I've seen it said elsewhere that this is the case, the 20s will haul the 484s to Eastleigh, where they are to undergo mainline testing.
How they'll eventually travel to the Island I'm not sure. Presumably by road from Eastleigh, unless they can take the cars off the track anywhere closer, fratton perhaps? Not sure of the layout there since the refurb.
Fareham to Eastleigh is almost an ideal length to simulate Island Line isn’t it, including regular change of direction. A few months back Modern Railways did predict a few 484s having mileage accumulation before going over to the island.
Wyrleybart
29 Mar 2020
South Staffordshire
I have reads somewhere that the class 20s are performing route learning for the driver(s) who will then drive the 484 testing on the Eastleigh-Fareham route. Presume the 20s will eventually use the barrier wagons to haul the 484s to and from testing. Presume the 484s have retained the same (LT) couplers and can probably use the 100t tanks which delivered the Bombardier stock to Neasden.
tnxrail
8 May 2011
Just saw class 484 on the M42 in Birmingham heading in the north direction basically opposite to Isle of Wight not sure where it was going didn't get number or picture as was driving and caught me off guard.
Energy
29 Dec 2018
They will fit......
It suprises me that people think nobody would point out that they wouldn't fit if they didn't, the not fitting problem for rolling stock has been known about for a while, it isn't going to be overlooked...
D365
29 Jun 2012
Exactly. Vivarail have been proposing D-Train for Island Line for several years now. It would be rather embarrassing on their part if the 484s suddenly did not fit.
david1212
9 Apr 2020
Midlands
A possible oversight would be Vivarail comparing the D-train to the steam-era stock together with no fully detailed record of the track bed now. With the LT stock being so much smaller there was no need to be very precise with either initial or subsequent changes.
There are a couple of photos of the 05 shunter at the Pier Head station on Flickr. When D2059 / 03059 was hired from the IoWSR it only worked as far as St Johns.
D365
29 Jun 2012
Possible. I spent some time at Long Marston before the Island Line proposal was public knowledge. They were more than confident that the D-Train would fit. So indeed it would be very embarrassing if this turned out to be false.
Incredibly unlikely, though. While railways have made that sort of error before, e.g. the French EMUs that were too wide and clouted the platforms, in this case it's inconceivable that they wouldn't have done (or had Network Rail do) the necessary gauging work to properly check.
david1212
9 Apr 2020
Midlands
With modern modelling there really would be no excuse for Vivarail supplying incorrect dimensions including the maximum nominal body distance from the rail on a curve of a given radius and the worst case from suspension movement. Likewise with modern measurement methods accurately mapping the current gauging and calculating any changes required ought to be straightforward.
Time will tell if just a false rumour or additional work is required.
DavidGrain
29 Dec 2017
It has already been reported on this thread that the work has been done last year on the track bed where there were problems like under a bridge near Smallbrook Junction. The tunnel has also been 'gauged' some time ago, so I don't know why this has come back again on this thread.
the sniper
4 Sep 2007
It surprises me that people think nobody would point out that they wouldn't fit if they didn't, the not fitting problem for rolling stock has been known about for a while, it isn't going to be overlooked...
But my god, it would be funny if they didn't fit, given how much it's been questioned and talked about over the years!
Mag_seven
1 Sep 2014
here to eternity
Who has said that they won't fit? I'm sure that all the necessary gauging work has been done and if any infringements have been found they will be being dealt with now during the line closure.
pdeaves
14 Sep 2014
Gateway to the South West
I think the question may be rooted in a statement several weeks ago to the effect that some sort of 'surprise' has been found during the works. (I can't find it now specifically looking, don't recall the nature of the so-called surprise and know even less the extent of it).
RichT54
6 Jun 2018
It was in post #973 by @Chris125 which had the following link:
https://twitter.com/SW_Help/status/1348850200434135041
In which there was the following comment:
Hi, there were no initial plans to do this but after further investigation there may be a necessity to lower the track to give enough room for the new units to get through the tunnel.
pdeaves
14 Sep 2014
Thanks RichT54 and Lockwood, that's what I was thinking of. Any further development to answer Stroud Valleys' query? Probably nothing to worry about or we would have heard something else.
A recent news article I saw quoting Adrian Shooter mentioned that some third rail testing was being done at Derby, presumably that would be the relatively short Bombardier test track?
