Class 701 'Aventra' trains for South Western Railway
pigs bay
29 Sep 2018
I think the class 701 would look better with the front of the Class 730. At least when 2x5 are coupled together you can walk thru' them!!
RealTrains07
28 Feb 2019
Are they coupling 2x5 units. I thought the 10 car units were meant remove that factor
I don’t think the exact purpose for the 60/30 split of 10/5 car has ever been explained in detail, as Goldfish says they all need to be 10 car in the peaks, so will probably remain 10 car all day on weekdays.
Do they still run short “red trains” on some inner suburban routes on Sundays? Maybe that’s why. Another point made a while back was that there may be a more practical reason, perhaps there’s a depot somewhere that 10 car trains just don’t fit.
Ethano92
26 Jun 2017
Some weekends you do get 4 car trains on every route except the Kingston loop and shepperton line. Don't really know why as 4 cars isn't adequate a lot of the time even on a Saturday. Not that anyone is left behind but the trains get more full than you'd expect/want/should be for weekends.
TEW
16 May 2008
There are 5-car diagrams on the Windsor side at present on Weekdays. That includes diagrams at peak times that are away from the main peak flow. The 1652 and 1922 Waterloo to Weybridge for example are booked 5 cars.
Goldfish62
14 Feb 2010
The Reading line is 100% 8/10 coaches at weekends. It certainly couldn't cope with five car trains, unless the proposed 4tph all day every day service is ever introduced.
hwl
5 Feb 2012
The proposed future increase in via Chertsey Loop shuttle services (is this stil the long term plan?) would certainly fit as an explanation for some 5 car originally.
A 5cars delivered first will also help with introduction in service especially before Feltham is delivered etc.
The proposed future increase in via Chertsey Loop shuttle services (is this stil the long term plan?) would certainly fit as an explanation for some 5 car originally...
I’m almost certain Chertsey shuttles (ie Weybridge <> Virginia Water only) got ruled out after that “post franchise award reconsultation”, in favour of retaining existing through Waterloo to Weybridge services.
But surely even if there had been intended to have a few more different short services that didn’t ever reach Waterloo, 30 would still be far too many?
TEW
16 May 2008
30 5-car 701s matches exactly the number of 707s, which out of the Suburban fleet are (or at least were until May 2019, not sure if it is still the case) the only fleet to run as single units on Weekdays.
Bessie
30 Oct 2017
Does anyone have an update on 701 construction progress? When can we expect to see the first unit out on test?
43055
8 Mar 2018
I haven't seen anything yet but more of the side panels and I think roofs have arrived.
whhistle
30 Dec 2010
Isn't the aim not to couple them?
IE, order enough carriages per train that you don't have to think about running two trains?
Because visability with a stupid gangway is terrible.
I think this may have been part of the delay for the Scotrail units.
TrainBoy98
19 Mar 2012
Worthing
Should've just kept the 458s as original with their wonderful stowable gangways :lol:
All seriousness though, could this be proper option in future or does the concept just kind of, not work?
pompeyfan
24 Jan 2012
Seems to work on the 380s. The 5 car 701s will attach and detach during the day, no different from the 707s, Thames Turbos, 150/1s and so on.
RealTrains07
28 Feb 2019
Issue still remains of the guard having to get out of 1 5 car unit and swap to another instead of simply being able to walk through
hwl
5 Feb 2012
60 of the fleet will be 10 car so no need to join in regular service.
30 of the fleet will be 5 car some of which will be running as 5 car so may be only 9-10 trains with 2x 5car units in service on weekdays?
Yes, that seems about right. But exactly why this specific ratio of 10 and 5 car 701s has been chosen has never really been specifically explained - the question has been raised quite a few times now.
My suspicion is that there’s still going to be a limitation on stabling siding length somewhere on the existing network, and/or that the numbers are to allow for certain routes to operate with short trains all day on Sundays.
The guards on 701 operated routes are not commercial, they don’t really need to be seen in both units. They have the lack of gangways with 455/456 combos already.
theking
30 Sep 2011
Probably a long shot but does anyone know why they went for a whole different version of the aventra rather than the standard cab like 345/710/720?.
Surely a lot more risk for them rather than taking a product that's already been tested.
Elshad
23 Oct 2018
The 345/710/720 cabs are each slightly different as well. The headlight shape, valance around coupler etc. are different. Aventra doesn’t seem very consistent.
I suspect that if you’re ordering 750 vehicles you can probably get what you ask for, within reason. I’d expect any issues would be far more likely to do with software than minor metal bashing (or GRP moulding) differences...
theking
30 Sep 2011
I know the 345/710 have quite a lot of electrics in the cab wall so the cab is quite long seems like the 701's have more of a tight electrostar cab.
This is what I meant with risks because surely redesigning that introduced some risks.
hwl
5 Feb 2012
So they could squeeze an extra row of seats in a 20m driving car bodyshell.
