Door failure as per usualAnd right on cue, 031 has just broken down on 2U31 (never even left Waterloo)
I wonder how it managed to call at Datchet which can no longer accommodate an 8-455It looks like a pair of 455s made what these days is an unusual trip to Windsor this morning, deputising for a 701 (same diagram as 2U31)
Realtime Trains | 2U21 0933 London Waterloo to Windsor & Eton Riverside | 11/12/2024
Real-time train running information for 2U21 0933 departure from London Waterloo to Windsor & Eton Riverside on 11/12/2024. From Realtime Trains, an independent source of train running info for Great Britain.www.realtimetrains.co.uk
It says NR which means no report, so skippedI wonder how it managed to call at Datchet which can no longer accommodate an 8-455
Presumably it just skipped it?
The same is being found on SWR as when Thameslink introduced long single units replacing formations consisting of 2 or 3 units. Previously you'd run a short formation if there was a unit failure - the service would still run. Now the service is cancelled. It makes issues more noticeable.
That explains a lot, when I looked at RTT this morning it was only showing 1x 10 car service from Windsor. 701031 must have been a swap at some pointIt looks like a pair of 455s made what these days is an unusual trip to Windsor this morning, deputising for a 701 (same diagram as 2U31)
It means no report which means it didn’t stop in section for enough time.NR does not always means skipped, although it usually does. But in this instance 2U21 arrived at Windsor when it was supposed to have been at Datchet so could not have called there.
701031 has been in and out of service all day.And right on cue, 031 has just broken down on 2U31 (never even left Waterloo)
At Clapham Junction this morning if I remember correctly this was announced as due to shortage of train crew?2U11 (0703 ex Waterloo) cancelled "planning error")
Well, a failure to roster a crew would count as a planning error!At Clapham Junction this morning if I remember correctly this was announced as due to shortage of train crew?
3 new diagrams then, albeit not on the same dayCan confirm that the Shepperton 701 diagram will be starting from next week. 2H08 05:43 off Teddington is the first working
Also a 701 on the Shepperton line this Saturday, it's on whatever circuit 2H27 is.
Found 2 sets out on this sunday coming as well, on the Kingston Rounder / Shepperton diagram and a Windsor diagram. 2K09 and 2U39 are examples.
That seems to start with 2H12 0641 Wat-Shepperton, 2H11 0742 Shepperton - Waterloo, and repeat every 2 hoursCan confirm that the Shepperton 701 diagram will be starting from next week. 2H08 05:43 off Teddington is the first working
2K09 is 0718 Waterloo-Wimbledon- Richmond- Waterloo, thenFound 2 sets out on this sunday coming as well, on the Kingston Rounder / Shepperton diagram and a Windsor diagram. 2K09 and 2U39 are examples.
If these come to pass, they will be the first calls by a 701 at Queenstown, Wandsworth Town, Barnes, Mortlake, North Sheen, St Margarets and Strawberry Hill
Presumably there is still the option of bringing in full DCO at a later date.A poor & short sighted decision by those in charge, particularly as the time, money & effort invested in obtaining the agreements, hardware, training & additional staff flexibility all appear to have been wasted.
The other advantage of having a formation of 2 or 3 units coupled together is that you can bring what is effectively 2 or 3 possible trains on/off depots all at once.The same is being found on SWR as when Thameslink introduced long single units replacing formations consisting of 2 or 3 units. Previously you'd run a short formation if there was a unit failure - the service would still run. Now the service is cancelled. It makes issues more noticeable.
It is sort of admitting defeat, will be much harder to implement in the future. There's no time like the present in my opinion .Presumably there is still the option of bringing in full DCO at a later date.
You only require one driver to move the set.
2H11 being swapped to a 701 is promising, since it regularly runs 15 minutes late, as a 10 car 458.That seems to start with 2H12 0641 Wat-Shepperton, 2H11 0742 Shepperton - Waterloo, and repeat every 2 hours
Yes, a Dorking/ Guildford via Epsom/ Hampton Court diagram.Is the 10 car 458 being redeployed on a diagram that's currently 8 car?
Indeed, particularly after enduring the month long strike it’ll be interesting if we ever hear an official version from a Minister, DFT or the TOCIt is sort of admitting defeat,
I’m not sure we will hear anything from FirstGroup/MTR before May, other than further rollout phases as they progress. After May, it’ll all be up to DfT Operator Ltd!be interesting if we ever hear an official version from a Minister, DFT or the TOC
That would be time consuming, disruptive and of little obvious benefit. The ‘paperwork’ to approve stations for DCO would likely all need doing again, drivers would need releasing for more training, etc. Very unlikely to be worth the hassle if the trains are running fine with guards who will remain on board anyway.Presumably there is still the option of bringing in full DCO at a later date.
If recent posts are accurate hardly any stations got fully cleared for DCO anyway meaning there weren’t sufficient stops for trainees to get easily passed out, hence it was dropped.The ‘paperwork’ to approve stations for DCO would likely all need doing again,
