Class 701 'Aventra' trains for South Western Railway
WWTownEnth
21 Mar 2014
One other thing the article in Today’s Railways mentioned was that there is an option on two further 10 car units. It said that this was unlikely to be exercised, however. It will be interesting to see how that plays out because the numbers do seem very tight, given the service increases.
hwl
5 Feb 2012
450s are 50% motored, I believe.
But 450s are software throttled back to 52% of their capability on dc or 350s 75% on ac.
The aventra traction motors are more powerful than the other motors too.
As the 701s will not operate as 12 car they may get a different power restriction. It’s to do with maximum Amps to be drawn.
The 444 have same motors as 450s but are allowed to draw more as will only ever operate as max 2 units coupled
I am not sure what current rules are, but I remember seeing in a book a graph of substation temperature (from decades ago) and how the transformers heat up as a train passes, then cools before next one. By end of rush hour were a lot warmer as cooling time reduced.
In theory trains can draw virtually infinite power if unrestricted, the limitations are to stop it getting too hot and melting the insulation of cables.
The inner suburban substations were replaced a few years ago and voltage changed to nearer 800v at supply (the LSWR had equipped them at 660v, and just 600v on earliest sections). So could get about same power with about 20% fewer amps.
Unrestricted sections used to be nominal 4500 amps, but I think some areas were re-equipped for 6000 amps. Although of course the restriction will be the lowest until the weakest section is brought upto standard. Remember most substations cover pair of tracks so could have multiple trains drawing power together which complicates their sizing
mightyena
13 Aug 2011
I guess always just assumed it was because a 444 has a lower percentage of powered axles compared to a 450, and that they could draw more in order to get roughly similar performance. Given that the two fleets are somewhat interoperable (As far as I'm aware it's possible, if unlikely, that anywhere a 444 is diagrammed, a 450 could turn up or vice versa. Not to mention the 444+450 combos), it would make sense for them to have similar acceleration.
tasky
30 Oct 2018
I suppose there's now a chance these trains will never have their SWR decals applied, if the franchise collapses before delivery.
Meerkat
14 Jul 2018
Isnt SWR one of DfTs long term brands, and the colour scheme isn’t First house colours is it??
Goldfish62
14 Feb 2010
DfT have explicitly stated that the LNER and EMR brands will stay irrespective of franchise holder. They also planned the same for South Eastern Railway and encouraged bidders to develop a transferable brand for South Western, hence SWR.
I don't see the brand changing. There are more pressing things to sort out with the franchise.
hwl
5 Feb 2012
Quite, and one of the reason for transferable brands so less distraction.
dorsetdesiro
30 Oct 2017
Agreed, the small "A First and MTR company" wording to be replaced by something like "operated by DfT or OLR". Like the same & unchanged ScotRail livery having its small FirstGroup logo or wording replaced by Abellio's and it will again in few years time.
What about Avanti West Coast? This seems like a joint First & Trenitalia idea instead of DfT which the latter probably would choose LMS, it is a bit surprising that the DfT allowed a name like AWC to go ahead. Would it still be AWC in the future if another operator (if they're not Italian) takes over?
Then again, I realised the "Greater Anglia" name actually was specified by DfT as it wasn't chosen by Abellio. "Great Eastern Railway" or "Great Anglian Railway" I would've thought to be more like DfT's thing.
Sorry to go OT...
Mikey C
11 Feb 2013
A shame they couldn't have kept the previous "blue" livery as the "standard" livery for SWR as it was far more attractive, but I guess it was considered too "Stagecoachy"
Goldfish62
14 Feb 2010
Sorry to go OT...
Other brands which won't be going anywhere are Merseyrail, Transport for Wales, West Midlands Railway, London North Western Railway.
Arrghh, too OT. Back to the 701s...
It’s all about the traction supply conditions on the routes in the peaks when most trains are at full length for multiple working. The max current allowed ‘per train’ is designed around the 12.450, which will have 6 motored carriages in the whole consist. But the 444 equivalent max length, 10.444, only has 4 motored carriages. It is still allowed to draw a similar total current to the 12.450 to have equal performance.
RealTrains07
28 Feb 2019
Yep, the same set up basically.
Well its bombardier after all. Its far easier and cost saving to have similar set ups. It doesn’t mean much crew wise as they still need training but its not surprising
Bessie
30 Oct 2017
I was on a couple of class 458 Waterloo-Reading services yesterday and noticed that the units had had a deep external clean, both had very clean and shiny yellow ends. Maybe these were planned but could it also mean SWR think they will remain in service a little longer, aka 701 delivery is delayed still further.
hwl
5 Feb 2012
The revised aim is to get the 8car 455 services up to 10car 701 and provide extra capacity first before any 5car stock starts to leave
43096
23 Nov 2015
Shame they haven't bothered to address other issues like some of the graffiti tags which have been around for weeks. Or, indeed, things like blown window seals, especially on the windows with the emergency opening hoppers at the top. These are now commonplace with some now getting water ingress with the resulting "fishtank" between the two window panes. This is a particularly disgusting example:
Goldfish62
14 Feb 2010
Some of the 458s have had a similar external clean. I think it's just an effort to make the fleet look more presentable.
fgwrich
15 Apr 2009
Between Edinburgh and Exeter
While I do agree with you that it's disgusting and does show a sad lack of care and attention, some of those "fishtank" windows can be a little amusing on a long and dull journey. I had a Voyager back a few weeks ago and the added window wave effect did raise a smile or two. I did even tweet a video of it to XC who, somewhat unsurprisingly wasn't that bothered.
Roger B
16 Jun 2018
Gatley
Class 701 (Coach No. 484101 leading) at Cerhenice (Velim Test Track) on 10th February 2020.
https://mark5812.smugmug.com/Trains-2020/February-2020-Czech-Republic/i-TCk5RdB/A
Mark
Great fots. Gotta say Aventras look so much better with a yellow / orange front - those for TfL Crossrail / Elizabeth Line just look washed out. I think the bright front makes them look sharper, more modern, more zippy (and no, I'm not making any reference to a character from Rainbow, and would be grateful in no-one else did either).
Goldfish62
14 Feb 2010
Great fots. Gotta say Aventras look so much better with a yellow / orange front - those for TfL / LO just look washed out. I think the bright front makes them look sharper, more modern, more zippy (and no, I'm not making any reference to a character from Rainbow, and would be grateful in no-one else did either).
The LO ones do have an orange front...
Note also the SWR cab design is different.
43096
23 Nov 2015
Although Bombardier have bungled the Aventra introduction thus far.
I’ll get me coat......
