Class 701 'Aventra' trains for South Western Railway
Metal_gee_man
28 Oct 2017
When are these going to enter service now covid-19 has delayed things and which class of the current suburban stock is disappearing first from SWR?
I'm sure it'll be the first stock that has a new home the class 707s, SouthEastern are almost gagging for them already
WWTownEnth
21 Mar 2014
I read somewhere that the DoT had mandated that order of withdrawal was as follows:
8 car 455 formations
8 car 450 formations
10 car 455+456 formations
10 car 458 formations
10 car 707 formations
not sure if that’s still the case.....
pompeyfan
24 Jan 2012
I don’t think anyone knows any more, but certainly replacing any 8 car services with 10 gives an instant uplift. I would however imagine they’ll go on routes with poor timekeeping to begin with though as hopefully dwell times will be reduced and improve punctuality. Look at how guard operated 707s fixed the shepperton line overnight.
Goldfish62
14 Feb 2010
How recent is that?
Immediately pre-Covid the official plan was still:
458 first
455/456
707 last
TEW
16 May 2008
Back in February this was the plan for introduction by route, but it could well have changed again.
Reading
Dorking and Hampton Court
Kingston Loop
Hounslow Loop & Weybridge
Woking, Guildford & Chessington
Windsor
Shepperton
theironroad
21 Nov 2014
I'd imagine that changes as the programme is going to be running way behind and the 707s are lined up for new work already and the 455/6 I believe are going for scrap. I could understand getting rid of 8 cars first when there was serious overcrowding, but obviously that's not the case now.
RealTrains07
28 Feb 2019
That was the case when the original timetable for 701 introduction was still the plan but now of course its a bit up in the air. Withdrawal wise it would make sense for the 707s to go first as they have a home and the 455/6s go last as they will most likely end up on the scrap pile
London Trains
9 Oct 2017
I'd give a quick guess and say the order is:
707s (Southeastern are in dire need)
458s
4/8 car 455s
455+456 formations
450s (run more as 12 car)
TRAX
2 Dec 2015
France
I did note from several videos that the first unit has a few wheel flats already. I Hope this isn't going to be a common theme with these "Aventra's", though as it uses the Flexx Eco bogie it wouldn't surprise me. (It's not a fun ride when your sat above one of them with a wheelflat)
Where do you hear this ?
Domh245
6 Apr 2013
nowhere
Trailing bogie of the second coach has a noticeably different sound, you can hear it more clearly in these videos (timestamped)
One of the leading brake force vehicles also has a bit of a flat which doesn't help!
TRAX
2 Dec 2015
France
Ah yes indeed.
But do bear in mind that this is one of the test trains, so I would expect that this would wear a few parts in the process, wheels included.
james60059
6 Jul 2006
Hinckley
It was delayed outside of East Midlands Parkway for a bit because of an axle issue, and also at Loughborough.
Bayum
21 Mar 2008
Also sounds like there’s another in the second to last vehicle of the 701
Goldfish62
14 Feb 2010
I'm told that the unit has no seats in it. If true, then it's the same as the first pair of 458s which were delivered for testing. They also had incomplete livery being white with red cabs.
WSnook37025
13 Oct 2010
did anyone catch the coach numbers? cant find any reference to them yet, and all the YT vids arent clear enough
Certain Alton diagrams which see 444 on them. My regular Alton train was always a 444. Or can't they replace 450 diagrams so they can replace 444 to strengthen other services.
There’s been no 444s to Alton for a while now, there’s none in the Dec 2018 or May 2019 carriage working notices, may have been earlier.
It’s previously been discussed that if the 442s enter service as planned all 444 and 450 operated services will effectively be at full length. The 458/5 will not be needed.
but this is still not really the place to discuss 458/5s...
TrainTube
24 Sep 2018
It does have seats in it, ive got video proof. I beleive the unit was used in a demonstration at Litchurch lane of the 701 stock, people were walking through and sitting on the seats.
Goldfish62
14 Feb 2010
Thanks. The one used for the media launch was a 5-car unit.
TRAX
2 Dec 2015
France
Aren't all trains snakes (sort of) ?
Why the constant need for nicknames ?
Mikey C
11 Feb 2013
Following on from the unofficial codes 4DES and 5DES for the 450 and 444, perhaps these will be the 5ADV and 10ADV!
