Class 710 LO
Discussion in 'Traction & Rolling Stock' started by AlanFry1, 23 Apr 2017.
  1. plcd1
    plcd1 Member
    788
    23 May 2015
    And it appears to be the case that driver training has picked up recently anyway. The Willesden - Barking paths have been used much more over the last week or so. All four return paths were used today for example. Given the sparse public service there may be scope, units and drivers permitting, to run more training paths on the GOBLIN. We shall see what happens.
  2. plcd1
    plcd1 Member
    788
    23 May 2015
    Eh? They've had to assess the test and technical evidence that Bombardier have submitted. I think 5 weeks turnround is pretty decent to be honest. The fact Bombardier have taken 15 months longer than expected to get to this point does not require the regulator to run about as if their pants are on fire.
  3. Grumpy
    Grumpy Member
    617
    8 Nov 2010
    The fact that manufacturers would be seeking clearance for their new units wouldn't be a surprise to ORR. They have known this class was coming for years. Surely ORR and the manufacturers have an ongoing dialogue throughout the design and development of new units with ORR's requirements clearly laid out. There should be an ongoing trickle of information to ORR throughout the testing phase as each requirement is met, with the communication on 4 March being just the last piece of the jigsaw-not the entire box to be started from the beginning.
    Irrespective of the time taken by Bombardier to reach this point, then I would hope that the regulator would give the impression that he, as a public servant, had been running around as if his pants were on fire if only for the benefit of the poor tax paying users of Goblin.
  4. Roast Veg
    Roast Veg Member
    651
    28 Oct 2016
    This is not how projects are delivered. Even if each system is physically installed with ample time to spare (one would hope), the associated software may be dependent on many other aspects and must be signed off altogether. What's the point of getting the ORR down to look at a few nuts and bolts when the train hasn't even met internal requirements?
  5. Brissle Girl
    Brissle Girl Member
    178
    17 Jul 2018
    I would have thought after the recent concern about the cosiness between the safety regulator and Boeing there would be no appetite within the ORR to do anything other than go through the proper process in a thorough and independent manner. As it should be of course.
  6. samuelmorris
    samuelmorris Established Member
    3,650
    18 Jul 2013
    Brentwood, Essex
    For all the processes on modern stock to be assessed, 5 weeks to verify that they are all satisfactory, or what remedial work needs to be taken, doesn't seem unreasonable to me.
  7. Trailfinder
    Trailfinder Member
    60
    15 Jan 2015
    They should sit in the stock while they carry out their assessment, perhaps they would then carry it out quicker.
  8. PizzaKing52
    PizzaKing52 New Member
    3
    11 Apr 2019
    When and where is the best time to see a Class 710 train on testing?
  9. twpsaesneg
    twpsaesneg Member
    317
    21 Jul 2009
    Unless there is a magic box of highly skilled rolling stock assurance engineers that the ORR can open in times of emergency, I'd suggest that there's not much the ORR can do to expedite the process. Unless of course you expect their staff to work overtime and weekends because Bombardier have dropped the ball?
  10. plcd1
    plcd1 Member
    788
    23 May 2015
    They now appear to be running several times a day between Willesden Junction low level bay platform and Barking. M-F there are 4 return paths at roughly 3 hour intervals and it now looks as if all 4 are being used. Previously they rarely did more than 2 return trips. On realtimetrains.com (RTT) look for train IDs 3Z01/02/03/04/05/06/07/08 if you search at a station on the GOBLIN. I use Blackhorse Rd but only because it's nearby. I am assuming it is the same unit that goes back and forth but I haven't been out to look recently. There is usually a Thunderbird loco running behind the 710.
    There are also paths at weekends (same codes) but the use of those has been a little more variable. I assume that's down to the number of drivers available at weekends.
    The overnight mileage paths between Wembley and Milton Keynes weren't used much last week but a train was out last night according to RTT.
  11. rebmcr
    rebmcr Established Member
    2,847
    15 Nov 2011
    Does that have a path booked, or will the signaller just manually input 9Z01 etc? There seems to be nothing in RTT today.
  12. gc1982
    gc1982 Member
    31
    23 May 2009
    If this still required, now that they have been approved?
  13. greatkingrat
    greatkingrat Established Member
    2,106
    20 Jan 2011
  14. plcd1
    plcd1 Member
    788
    23 May 2015
    It certainly has had in the past. Paths weren't there today for some reason but it did run. I've no real idea how paths, esp late notice or temporary ones, are put into systems. If nothing else being able to watch trains whizzing about on online signal diagrams helps me appreciate the skill that signallers have in keeping things moving and coping with trains running out of their normal slots.
    All 4 return trips ran today for the 710s so it looks like a more concerted effort is being made.
  15. ijmad
    ijmad Established Member
    1,145
    7 Jan 2016
    @RidingTheGoblin on twitter saying that the coupling issue needs to be ironed out before passenger service, due to the possibility of chaos if one fails and can't be rescued.
  16. reddragon
    reddragon Member
    784
    24 Mar 2016
    Churn (closed)
    Rail 877 states that they have been cleared for entry into traffic on April 11 subject to 13 conditions!
  17. 87015
    87015 Established Member
    4,259
    3 Mar 2006
    GEML/WCML/SR
    As usual, this is completely made up.
  18. 59CosG95
    59CosG95 Established Member
    3,841
    18 Aug 2013
    WIM/PBO
    April the 11th? That was 15 days ago!
  19. 87015
    4,259
    3 Mar 2006
    GEML/WCML/SR
    ORR passenger cert, sure it was on here at the time.
  20. hwl
    hwl Established Member
    3,878
    5 Feb 2012
    They obviously didn't read the ORR letter - emergency unit mechanical coupling is fine...
    The entry into service plan appears to be getting all the drivers trained up first (not copying GTR thinking!) then starting the 710 in service hence looking like end of May /early June.
    Presumably another software drop in that time too.
  21. ijmad
    1,145
    7 Jan 2016
    I figured as much. :E
  22. superjohn
    superjohn Member
    53
    11 Mar 2011
  23. delticdave
    delticdave Member
    232
    14 Apr 2017
    Westbound surely?
  24. superjohn
    superjohn Member
    53
    11 Mar 2011
    Yep, my mistake. I was heading eastbound bound at the time!
    Post has been updated.
  25. Class 170101
    Class 170101 Established Member
    5,064
    1 Mar 2014
  26. greatkingrat
    2,106
    20 Jan 2011
    These training trips have been running for weeks - this is nothing new.
  27. swt_passenger
    swt_passenger Veteran Member
    20,163
    You’re right. First mentioned in this thread 2 months ago, around post #1183.
  28. THarris1303
    THarris1303 On Moderation
    51
    9 Apr 2019
    Any idea what ramifications the delays have for the new GA timetable rollout?
  29. BlyRF
    BlyRF Member
    51
    30 Jul 2018
    No idea, but i’m keen to know of any new news, been quiet lately
  30. 47421
    47421 Member
    407
    7 Feb 2012
    london
    See the other threads re GA. In short under Franchise Agreement GA said would be limited improvements in May 19 (eg Norwich Camb extended to Stansted Apt, LivSt Ipswich semi fast extended to Norwich) and rewrite May 20. The May 19 changes are not happening other than the 2 up 2 down Norwich in 90 services.
    The rewrite now Dec 20 earliest and some promised changes eg Ipswich to Peterborough already been abandoned UFN.
    Delay not just cus new trains late, rumour is that GA bid from 2016 not deliverable in the post Thameslink timetable fiasco era.
Share This Page
