Class 745 Stadler FLIRTs
ashkeba
13 May 2019
Yes, but isn't it operationally a better way of increasing capacity at Ipswich station by not having units stabling for up to 20 minutes in platforms and having to cross over the main running lines. The Ipswich stopper creates a pathing headache as it has to run wrong line through Ipswich Tunnel before crossing to the up main> This is one of the services that slows down the Nin90 down service through Ipswich.
For those of us unfamiliar with Ipswich layout, why does the stopper have to run wrong line through the tunnel?
chubs
30 Oct 2012
It’s not a rumour. One of the franchise obligations in the bid was to extend the Ipswich stopper to Norwich. Like the Liverpool St - Lowestoft through service, there is a realistic chance it never happens and get silently axed.
The rumour is around what (if any) stock will operate it.
We all know it is part of the franchise agreement.
Railperf
30 Oct 2017
Actually..i have been corrected...apparently the Ipswich stopper to London has been retimed to depart 11.48 to avoid 'slowing down' the Norwich in 90. To the delight of many it now has 6 min waiting time at Colchester instead. Lol.
Railperf
30 Oct 2017
Is my reading of the new 07.40 NRW to LST diagram correct? It ends up eventually doing the 17:30 NRW to LST..then a couple of LST to SSD (Stansted Airport) turns before retiring at Orient Way for the night? Diagram starts 6th Jan.
trebor79
8 Mar 2018
Don't know where you've seen the diagram, but yes logic says it'll end up on the 1730 NRW to LST. What it does after that I don't know.
Why would they have an jntercity set with buffet and first class doing Stansted runs though?
Railperf
30 Oct 2017
Due in at Liverpool Street P6 at 1917. Next arrival or departure from P6 is the 19.55 to Stansted .. according to RTT.
trebor79
8 Mar 2018
Ah, I see. Well I should think that will get changed, unless it's a 745/1 that's coming into service on 6th...
dk1
2 Oct 2009
East Anglia
It forms the 20:00 Lst-Nrw.
The open data also implies that the 2000 to Norwich is formed of the stock off 1B05 1845 Stansted Airport to London Liverpool Street.
I suggest that the switchover is something for the long term plan which may become effective during the timetable period rather than the way it will work on 6 (or maybe 8) January.
It would be interesting to know whether that is the only switchover scheduled to happen at Liverpool Street rather than Orient Way overnight.
Taylorgb19
30 Mar 2019
I wonder if the Lowestoft to Liverpool Street and 3rd LST to NRW will have trolley service
Bikeman78
26 Apr 2018
The base unit diagrams and platform workings in RTT assume that all the 745s are in service on both routes. There are booked swaps between the routes to rotate the Stansted units to Norwich. At the moment they are being amended week by week to reflect what is actually happening.
306024
23 Jan 2013
East Anglia
.....It would be interesting to know whether that is the only switchover scheduled to happen at Liverpool Street rather than Orient Way overnight.
Just do a Liverpool St location enquiry in RTT, filter LE for Greater Anglia and take a look. The Stansted 745 that goes to Crown Point for maintenance on the 20.00 down must come back the next day with something. It shouldn’t take too long to spot the morning swap.
Bikeman78
26 Apr 2018
0654 arrival from Norwich works 0725 to Stansted; 0708 arrival from Stansted works 0730 to Norwich.
Shunter_69
10 Dec 2014
007 has been accepted into service so assume that’ll be the first one used next week.
LAX54
15 Jan 2008
The email we have states 745007
1P15 0740
1P18 1000
1P37 1230
1P38 1500
1P57 1730
1P62 2000
Then to Crown Point.
ashkeba
13 May 2019
007? Dumb luck or revenge on the PR department? Many pun headline possibilities if anything goes wrong : Dr No, Spectre, Never Say Never and some worse ones which surely even the EDP is not crass enough to use.
Hope it doesn't though!
lord rathmore
11 Feb 2012
suffolk
0-0-7, 0-0-7 At ocean eleven And now rude boys have a go wail 'Cause them out of jail Rude boys cannot fail 'Cause them must get bail
(Sorry all, couldn't resist opportunity to quote a reggae classic!)
LAX54
15 Jan 2008
1P15 0740
1P18 1000
1P37 1230
1P38 1500
1P57 1730
1P62 2000
Then to Crown Point
from 08.01.2020
LAX54
15 Jan 2008
1Y39 passes Halifax Junction at 1150, whilst on the down 9P90 passes there at 1153
In the evening, the GE service that got in the way of the 1900 Ni90 at Ipswich, now terminates at Colchester.
Grumbler
27 Mar 2015
Q: How was the ride?
A: Shaken not stirred..
rdlover777
4 Feb 2014
Kent
Richard Clinnick on twitter just tweeted about how 745007 should enter full revenue service this week.
There *should* be a @greaterangliaCl.745/0 in traffic this week. Expected that 745007 will be the first to carry passengers. If the diagram stays true, then when it should do: 0740/1230/1730 from Norwich and 1000/1500 from London. Diagram says Stansted, but that won't happen.
