Class 93 Tri-mode Loco
800001
24 Oct 2015
Reports that 93003 has arrived in the country and has left the Docks heading for Worksop.
Edit 22:15 93003 at Woodhall Services on M1 overnight, continues to worksop tomorrow (Wednesday 7th).
The_Train
2 Jun 2018
They've certainly started to arrive at a good pace now. I guess Stadler got a bit sick of them taking up space at their factory ;)
Bristol
So that's 1, 2, 3 and 6 (4 out of 10) in the country now?
Bobcp
4 Apr 2016
Hinckley, Leicester
Just for the record I viewed 93003 at 08.45 am. on Wednesday May 7th. in the wide load bay at M1, Junction 24 roundabout which is to the south of Woodall Services.
60159
26 Nov 2018
Went past Worksop around 12 today and 03 and 10 were outside the shed. Came back around 14.00 and wasn’t goung to check as still 2 in the same position but 01 and 02.
Strange.
Class15
30 Dec 2021
North London or Mildmay line
Nottingham59
10 Dec 2019
Not seeing any paths as of now on Railcam. Are these tests delayed?
What about this one? Carlisle to Lancaster and back. 14 May only. Trailing load 715t
AndrewE
9 Nov 2015
Ah OK. 715t is an awful lot of weedkiller! lol
maybe not: 100T of trailing loco, at least a couple of bogie tank wagons of water - maybe 3 or 4 - at 100T each, a tank of weedkiller concentrate (50T gross?) and the application vehicle with its power plant, pumps and metering/mixing equipment and the spray nozzles.
It's a long way between Carlisle, Lancaster and Windermere and back again, especially if you are pumping water out all the way... I doubt that they will have fire hoses out at Lancaster for a top-up!
Bristol
It's just a timing load. I'd guess it's TR40 (timing reference 40) and the 715t is a nominal load for the reference loco. If its running with a difference class of loco (and I'm 99% sure the reference loco is setting like a 56) the trailing load would be adjusted proportionally. NR has tables for what each loco class can haul at each timing reference.
60-TR40 has quite good coverage of SRTs around the entire network and is often uused where a specific timing load does not exist for a moment, as trains will usually be able to meet the times comfortably without getting too far ahead of schedule.
