Collision and derailment at Neville Hill Depot (13/11)
Discussion in 'UK Railway Discussion' started by Class455, 13 Nov 2019.
  1. Class455
    Class455 Member
    1,029
    19 May 2016
    Within the last hour, there has been a collision and a derailment between a HST which was 43300 and an Azuma which is 800 109 according to various Facebook groups. There is considerable damage to both loco and unit, I just hope that nobody was hurt as a result.
    LNER Twitter has confirmed that as a result of this incident, the 23:33 London Kings Cross to Leeds has been cancelled (they had originally mentioned the derailment but they have since deleted the tweet in question)
    https://twitter.com/LNER/status/1194751289948884993
    Rail Forums
  3. dk1
    dk1 Established Member
    7,897
    2 Oct 2009
    East Anglia
    Looks pretty bad. Trying to get my head around how its happened.
  4. Bevan Price
    Bevan Price Established Member
    4,491
    22 Apr 2010
    Hope that nobody was badly hurt.
  5. 55002
    55002 Member
    49
    16 Aug 2019
    Ldn
    Slightly concerning that the newer “Azuma” has derailed in what I assume was a low speed accident.
  6. PG
    PG Member
    643
    Firstly I hope there are no injuries.
    Newness doesn't alter laws of physics... heavy object (Class 43) hits lighter object (Class 800) or vice versa, and the lighter one can move more including in this case derailing.
  7. bengley
    bengley Established Member
    1,174
    18 May 2008
    Just to state some facts:
    This line is technically the Down Hull Goods at this point and is regularly used permissively by trains (more than one train moving in the section at once) entering the depot.
  8. theblackwatch
    theblackwatch Emeritus Moderator
    10,210
    15 Feb 2006
    Many thanks for that, I'm sure most (like me) weren't aware of that fact.
  9. LowLevel
    LowLevel Established Member
    3,785
    26 Oct 2013
    There's been many bumps on or around Neville Hill over the years, I'm sure it won't be the last. Happily it seems no one injured.
  10. Crossover
    Crossover Established Member
    7,898
    4 Jun 2009
    Just seen this elsewhere myself - the way the Azuma looks to have sort of concertinaed is a bit of a feat! Feels like it may have some hallmarks of the Plymouth collision of a few years ago
  11. PG
    PG Member
    643
    Is that the one where a driver had been permissively signalled into a platform that was already occupied but due to it not being a 'normal operating movement' and approached on a curve didn't realise which line they were directed onto?
    IIRC the RAIB report mentioned deficiencies in FGW driver training as one of underlying causes, though I am not saying that that necessarily applies in this case since the facts are not yet known.
  12. Llama
    Llama Established Member
    1,438
    29 Apr 2014
    The driver had a poor understanding of how permissive working actually worked in that Plymouth incident if I remember rightly.
    Looking at pictures I've seen of this evening's prang it looks like the impact speed might've been a bit higher than at Plymouth. Permissible speed into the DHGL is 15mph.
  13. big all
    big all On Moderation
    747
    23 Sep 2018
    redhill
    to be fair the the interaction between a heavy hst motor coach off perhaps 70 tonnes would be very different to a perhaps 40 tonnes coach also you only need a perhaps few inches above the normal buffer level off a hst for them to override the hst even at near zero speed
  14. Mintona
    Mintona Established Member
    3,195
    8 Jan 2006
    South West
    Would the Azuma normally be on electric mode at this point, does anybody know?
  15. richw
    richw Established Member
    8,363
    10 Jun 2010
    Liskeard
    2+9 hst is approx 410 Tons, 9 car Azuma 431 ton. However you’re correct that the heavier object hit a stationary lighter object. If the HST has its parking brake applied the energy had to go somewhere and that was back through the azuma. 15 mph speed limit I believe at this location
  16. Finfanero
    Finfanero Member
    128
    27 Sep 2014
    Snaith
    Good Morning,
    https://www.lner.co.uk/travel-infor...isruption-id=23860B61A6A4447FA7AC375C7CF836CB
    More details here & Picture here
    https://twitter.com/stuartthomas/status/1194763023224918016
    https://twitter.com/Clinnick1/status/1194860088596537349
    https://twitter.com/JoshBlinman/status/1194847616699420673
  17. ohgoditsjames
    ohgoditsjames Member
    222
    16 Jun 2019
    Sheffield & Shipley
    The 6.38 Shipley to KX was cancelled this morning so I assume it has something to do with this?
    Noticed on twitter that no one was injured which is good news.
  18. Trainguy90
    Trainguy90 Member
    105
    8 Sep 2016
    Guessing they don’t couple up then
  19. Failed Unit
    Failed Unit Established Member
    7,493
    26 Jan 2009
    Central Belt
    yep. Has seriously hit the Lincoln service as well. I guess the 800/2 are stuck in NL.
    I guess this does show an advantage in short sets as LNER will be 9 coaches short for a while. Rather than 5 if it was a pair. I suspect the HST stock will be back in service tomorrow with another power car.
    Be interesting to see the cause.
  20. 158747
    158747 Member
    210
    5 Aug 2010
    Trowbridge
    Possibly poor rail adhesion?
  21. rdlover777
    rdlover777 Member
    336
    4 Feb 2014
    Kent
    Pic of the nose of the 800
    [​IMG]
  22. wilsontown
    wilsontown Member
    65
    11 Feb 2012
    Went past this on the way to work this morning, a bit of a mess. It also looked there was a bogie further down the train that was derailed. Going to take a while to sort out I imagine.
  23. ainsworth74
    ainsworth74 Forum Staff Staff Member Global Moderator
    21,175
    Depends on if they're confident that there's no damage to the Mk3s! Personally I'd have thought that the Mk3s will need to go through a full exam before they can be put back into service to make sure there's no structural damage.
  24. Bayum
    Bayum Established Member
    1,902
    21 Mar 2008
  25. Mitchell Hurd
    Mitchell Hurd Member
    869
    28 Oct 2017
    I'm rather baffled at quite a collision here.
    Hopefully HST set NL65 is spare somewhere. Or if the coaches aren't affected, then 2 power cars off NL65 will be of great use.
    If it was me, I wouldn't be too bothered about fixing the HST as they're being withdrawn soon anyway. Providing LNER services can manage without an HST in this case.
    That aside, thank goodness there were no injuries!
  26. ohgoditsjames
    222
    16 Jun 2019
    Sheffield & Shipley
    That looks horrendous! I suspect there will be damage to the undercarriage and frame too
  27. Failed Unit
    7,493
    26 Jan 2009
    Central Belt
    the power car possibly won’t be fixed but the coaches may be heading to EMR.
    the Azuma will be missed of course as it is a hybrid. So one less to get away from the wires. I know in daily service they have Hybrids (and HSTs) operating entire diagrams under the wires, so it will probably only be in issue when diversions are required.
    suspect the damage looks worse then it is because it is a crumple zone. But will be surprised if it isn’t away getting fixed until spring.
  28. RichT54
    RichT54 Member
    126
    6 Jun 2018
    Berkshire
    Do TOCs have insurance to cover this sort of incident, or do they have to fund repairs or replacements themselves?
  29. hexagon789
    hexagon789 Established Member
    7,148
    2 Sep 2016
    Damage to 800109 said to be significant on 4-cars; on the HST 43300 will likely not re-enter service, 43308 on the other end is undamaged.
  30. Tom Maddox
    Tom Maddox Member
    505
    14 Apr 2019
    Frodsham
    From Facebook:
Share This Page
