Collision and derailment at Neville Hill Depot (13/11)
Discussion in 'UK Railway Discussion' started by Class455, 13 Nov 2019.
  1. fgwrich
    fgwrich Established Member
    5,270
    15 Apr 2009
    Between Edinburgh and Exeter
    It's not just the way that it's derailed that's a concern, but also for the way the Dellner inter car connectors (couplings) acted attributing to the derailment.
  2. Bevan Price
    Bevan Price Established Member
    4,494
    22 Apr 2010
    If the HST was stationary, then the brakes would need to have been on -- the line from Leeds Marsh Lane towards Neville Hill is uphill with a gradient slightly steeper than 1 in 300.
  3. Llama
    Llama Established Member
    1,439
    29 Apr 2014
    I'd have thought that the couplings within each set would be semi-permanent bar couplers as most stock is these days, usually with a deformation/collapsible mounting at one end. May still be made by Dellner but they won't be 'autocouplers' as they are on the outer ends of the unit.
  4. Bezza49
    Bezza49 Member
    51
    21 Nov 2018
    Euxton
    :D
    I saw them in my initial Spotting career from 1992 to 1999, but not in my new one since 2016 :)
  5. High Dyke
    High Dyke Established Member
    2,186
    1 Jan 2013
    Yellabelly Country
    That was the problem... ATE (Hitachi) wanted to move it under its own power, but sources at LNER say it isn't fit for movement by rail.
  6. PG
    PG Member
    644
    I'd say let ATE do as they wish as they'll be the ones who'll be fixing any additional damage they cause - LNER can then say 'we told you...'
    Only winners are likely to be the lawyers when it ends up in court!
  7. Elecman
    Elecman Established Member
    1,900
    31 Dec 2013
    Lancashire
    Providing someone is brave enough to sign a fitness to run certificate
  8. High Dyke
    2,186
    1 Jan 2013
    Yellabelly Country
    It all depends on what damage is caused...If it's to infrastructure then Network Rail wouldn't be impressed. Equally, if the unit was moved by rail and then subsequently has an issue en-route; then imagine the delays that could be incurred. The finger of blame would need to point somewhere.
  9. Ploughman
    Ploughman Established Member
    2,358
    15 Jan 2010
    Is there Low Loader access into Neville Hill or at a nearby access point?
    Maybe down the bottom of the hill at the old stone terminal.
  10. 800002
    800002 Member
    556
    19 Jun 2019
    Who owns the train set? Presumably ATE (Hitachi).... So presumably its those call as to what they want to do with it?
    Is ATE (Hitachi) in a position to do this themselves, or are they reliant upon an operator (LNER or otherwise) to perform such a duty prior to that party moving the trainset on the national network?
    A very good question indeed. Presumably, it is possible to detach all of the units on the depot inorder to transport them via road?
    Failing that and it needs to go via the national network, such possibilities could of course include a severe speed restriction, causing much more disruption...
  11. Dren Ahmeti
    Dren Ahmeti Member
    351
    17 Oct 2017
    Bristol
    If something like that had to run under a 8X headcode, it would be run at night, or outside of the peaks.
  12. eastdyke
    eastdyke Established Member
    1,699
    25 Jan 2010
    East Midlands
    Is that with reference to the unit involved in the PHBT incident though?
  13. High Dyke
    2,186
    1 Jan 2013
    Yellabelly Country
    Yes, it was.
  14. eastdyke
    1,699
    25 Jan 2010
    East Midlands
    Thanks.
  15. Speed43125
    Speed43125 Member
    237
    20 Jul 2019
    PHBT? could you elaborate what that is?
  16. High Dyke
    2,186
    1 Jan 2013
    Yellabelly Country
    Person Hit By a Train.
  17. Speed43125
    Speed43125 Member
    237
    20 Jul 2019
    Ah, Okay thanks!
  18. Leeds1970
    Leeds1970 Member
    29
    13 Nov 2014
    normal trucks delivering power units/wheel sets can access however something like one of the Alleyleys trucks would be a definite no.. the turn from Osmonthorpe lane onto York road has a sharp hump and a dip --
  19. eastdyke
    1,699
    25 Jan 2010
    East Midlands
    Very sorry, should have clarified :oops:
    Thanks to @High Dyke :cake:
  20. PG
    PG Member
    644
    Ah I see, I was referring to the one derailed on the DHGL.
    Any news yet on what is happening with that one?
  21. eastdyke
    1,699
    25 Jan 2010
    East Midlands
    I don't have any info.
    But having been derailed, for whatever reason (collision, trackwork or train), I would presume it unlikely that everybody would be happy for route ECML back to Newton Aycliffe :|
  22. Grumpy Git
    Grumpy Git Member
    475
    13 Oct 2019
    Earth (for now)
    What joy to have such a fragmented railway. The only people who benefit from such incidents are the lawyers.
  23. 1D53
    1D53 Established Member
    2,537
    2 Apr 2006
    Noted some of the vehicles in the formation having wheelskates fitted on Neville Hill this afternoon.
  24. PG
    PG Member
    644
    Pardon my ignorance but how far can rolling stock travel on wheelskates? Around the corner or somewhat further distances?
  25. JN114
    JN114 Established Member
    2,189
    28 Jun 2005
    As far as you like, it just has to be done at very low speed; so that speed makes it prohibitive.
  26. PG
    PG Member
    644
    Thanks for answering that for me.
    Seems likely if ATE want 800109 back to Newton Aycliffe it'll have to go by road then - unless they crawl up the ECML on 25th Dec!
  27. M60lad
    M60lad Member
    427
    31 May 2011
    If it has to travel by road then how will they get the train onto the truck considering (if I haven't read it wrong) its already been said on here that one of the now famous Alleyleys trucks won't fit down the road to Neville Hill? Surely moving it away by road if one of their trucks can't get access is going to prove difficult
  28. DarloRich
    DarloRich Veteran Member
    23,221
    Work - Fenny Stratford(MK) Home - Darlington
    you would just break the journey up into chunks and do it over night, subject to possessions. It would take quite a while mind!
    move it somewhere where a truck can easily access the railway.
    What are you on about?
  29. 800001
    800001 Member
    574
    24 Oct 2015
    Neville Hill to Midland Road depot, good road access, or even back to Doncaster depot over night, may still take a few nights and stops in loops to get it there, but again Doncaster Iep depot has good road access.
  30. syorksdeano
    syorksdeano Member
    527
    7 Jan 2011
    Why can't they just move it to Doncaster anyway as I thought that that was a maintenance depot?
    Obviously it needs more than a bit of tape to fix it, but surely it would easier
Share This Page
