Combination of season + other ticket
Discussion in 'Fares Advice & Policy' started by guilbert, 18 May 2015.
Thread Status:
  1. guilbert
    guilbert Member
    12
    18 May 2015
    I have a Hitchin to London Terminals season ticket so it's fairly clear that I could, for instance, buy an appropriate Hitchin to Peterborough single then take an EC train from King's Cross which is first stop Peterborough.
    But do I actually have to travel through Hitchin, or does the combination of season + single become equivalent to a ticket for the whole journey via any permitted route?
    For instance, if I buy a Hitchin to Cambridge single I could obviously get a non stop train from King's Cross but could I travel from Liverpool Street instead? Or if I buy a London Terminals to Birmingham ticket would I be able to travel from Hitchin to Birmingham via Peterborough?
  2. bb21
    bb21 Moderator Staff Member Moderator
    21,705
    4 Feb 2010
    Yes, no, and no is my understanding of the rules, but I am aware that some forum members think that what you are proposing is permitted based on an alternative reading of Condition 19.
  3. RJ
    RJ Established Member
    6,796
    25 Jun 2005
    Rail replacement bus cab
    I'd propose that those people are categorically wrong. As far as I'm aware, the concept of permitted routes applies to each ticket. Unless there is something unambiguous that states that permitted routes do not apply to each ticket when a combination of tickets is used, I'm quite happy not to accept this alternative reading.
  4. maniacmartin
    maniacmartin Established Member Senior Fares Advisor
    4,903
    15 May 2012
    Purley
    My interpretation is also that you would have to travel via Hitchen in this case
  5. guilbert
    guilbert Member
    12
    18 May 2015
    Thanks for the replies - I suspected it might be a no, although it's not completely clear.
    Condition 19 makes it clear that I don't need to use a train which calls at Hitchin and in general there's no way for a passenger to know whether or not a train will go through a particular station (without stopping) or not (although for the examples I gave it's fairly obvious).
    On the other hand, if the combinations I suggested were acceptable it would open all sorts of revenue allocation problems and it's unlikely the barriers would accept the tickets.
    I'm not hearing that anyone has successfully used it though so probably best avoided!
  6. hairyhandedfool
    hairyhandedfool Established Member
    8,838
    14 Apr 2008
    Condition 19 says that, together, the tickets must cover the entire journey being made, it does not say they should be treated as one ticket.
  7. sheff1
    sheff1 Established Member
    3,328
    24 Dec 2009
    Sheffield
    Revenue allocation and barriers accepting tickets play no part in deciding whether a ticket (or combinations of tickets) are valid via a particular route.
    As said, there are different interpretations of Condition 19, but I would not try to use the 2nd & 3rd pair of tickets as you describe.
Thread Status:
Share This Page
