Compulsory Reservations- Poll
Do you agree or disagree with the introduction of compulsory reservations on Inter-City trains?
  • Agree
  • Disagree
  • Indifferent
Results are only viewable after voting.
A system of pay as you go "local" or commuting journeys combined with compulsory reservation intercity sounds great in theory but falls down in practice when you don't have a separation between short and long distance services or operator. Why should a less than one hour commute into London or Manchester for example on a season or PAYG be turn up and go but the same time and distance for a commute on the same ticket type now require reservations elsewhere in the country due to the lack of capacity of the operator concerned?
You'd also have the "Reading issue" - canny Reading commuters would reserve all the seats and nobody would be able to book a journey from Penzance. The only solution I could see for that would be season ticket holders only being able to pick up a seat on arrival at the station, but that would be awkward too. In essence as you say it only really works if your IC services don't carry a significant number of local passengers.
Clearly that will work for HS2 as it's effectively laid on top of the (slowed down) existing service, but it would certainly be an issue for XC and GWR, unless paths could be found for say a 4tph 12-car Reading-Slough-Paddington service to take all the commuters and ban them entirely from the 80x.
stuu
2 Sep 2011
I (used to) regularly catch the XC 1749 from Bristol to Taunton, as do at least 100 other commuters on an average day. Virtually none of those people get a seat, so in this potential future would none of them be able to use this train? As others have said, XC has this issue across it's network. Equally GWR "intercity" services are part of the offering between Bristol and Bath, Weston, Bristol Parkway etc. How would that work?
Seems to create more problems than it solves for me. Reserved/non-reserved carriages make more sense, but not great when there is only a 4-car voyager or whatever
takno
I can't find any officially posted guidance from LNER on this when your connection to the LNER service is delayed. Or perhaps for the passenger to have the choice of next available service, new reservation or full refund (not delay repay dependent on time delayed, more if service you have reservation on is cancelled automatic full refund.)
They've been leaving a quite spectacularly large chunk of every train unused for that eventuality. Platform stuff just direct you to the appropriate carriage and generally trust you to be able to space yourselves out around the coach.
None of what LNER have been doing would work at all with anything like normal numbers of travellers - they'd be turning hundreds of people away every day. The reality of compulsory reservations on an overcrowded railway isn't "it's going to be a bit more expensive", its "why don't you find yourself a nice bench to sleep on because we aren't getting you home tonight" and "not a bench in the station, sir, we close the station at midnight".
Bevan Price
22 Apr 2010
In practice most people behave themselves, and the odd few not doing doesn't cause a major problem. This is similar to pick up/set down only services at MKC - if the train wasn't checked on boarding at Euston (rare these days) you will tend to see one or two canny commuters getting off a northbound at MKC, but it's only one or two so it doesn't cause a great issue.
There are other options, I suppose:
  1. Change Penalty Fares legislation so a Penalty Fare of £20 applies to boarding a reservation-only service without a reservation;
  2. Move to "global fares", i.e. you don't issue any tickets without a reservation, like Eurostar or airlines;
  3. Impose a charge for on-board "issue of reservations" (on the basis that if there aren't any to sell you you will be chucked off at the next station).
Euston is a special case - there are barriers where tickets & reservations can be checked before you get on the platform.
At various times in the past, some long-distance trains to Manchester were "set down only" at Stockport. That did not stop passengers for Manchester piling onto those trains when they called at Stockport. A similar situation will exist at any other station lacking controlled access to individual platforms.
It wouldn't overly matter if they did, either - the reason for this being in the timetable was so they could leave early towards Manchester if they arrived early at Stockport. This was only removed when VT noticed that they could make a few extra quid with dedicated fares.
The other way round you might want to stop it and could do with boarding checks at Piccadilly if you wanted (give or take people sneaking via the footbridge), as the Avanti platforms are barriered separately from the others.
squizzler
4 Jan 2017
Jersey, Channel Islands
I am a little confused when I read forum members holding forth about how they would rather stand than have a guaranteed seat waiting for them on the train. Many of the same members frequently hold forth about the quality of seating provided on new trains. Surely if train seats are regarded as making or breaking the enjoyment of train travel (an oft expressed view) then having to spend a lengthy trip without a chair at all must be purgatory, and measures to prevent such an occurrence would be supported?
Maybe they're saying some seats are so purgatorial that it's preferable to stand?
Time for an advert for Grammer? :)
There are seats that are worse than standing, such as the middle of the 3 side of 3+2 in UK loading gauge or most seats on a 150/2 or 153 in which I physically can't sit down, but whatever I might think of Fainsa's finest I'd still rather sit on one than stand for 3 hours. So I think that debate only really applies to purely local/commuter trains, which are not compulsory reservation in the vast majority of the world and are not proposed to be as such - indeed the UK is pretty unusual in having Advance fares on them at all.
BayPaul
11 Jul 2019
I think they are saying (and why I voted against) is that they would prefer to have to stand than to not be able to get on a train at all, if all the seats are taken. People can already reserve seats on these services if they don't want to stand, so there are really no benefits to this policy as far as I can see.
What you're forgetting is that even sitting on a full-and-standing train is really unpleasant. It's hot, it's stuffy, you can't get to the bog/buffet/the trolley can't get to you, you can't get to your bag to get stuff out, it's stressful getting on and off etc. It is not a quality InterCity travelling experience. Add to that that you may have to end up giving up your seat anyway if someone needs it more than you, and the whole situation is just pretty rubbish.
To be fair I find this extremely rare on the WCML (basically just Friday evenings, and that has been sorted out by removing ticket restrictions), but it sounds like the ECML might perhaps have more of a capacity issue than that, and XC definitely does, though XC would be sorted out by simply biting the bullet and ordering enough 80x to double the capacity, which has been roughly how far off the mark it has been ever since the idiocy of Operation Pumpkin something like 15 years ago now (and then repeated shortly after with TPE and the 185s, too).
plugwash
29 May 2015
Pretty sure that is not the case, IIRC at the concourse end there is a barrier between the medium and high numbered platforms but no barrier between the low and medium numbered platforms.
And of course there are no barriers at all at the footbridge end.
Yes, there is. The low-numbered ones are gated but with a separate set of gates controlled by TPE and a glass wall between the two bits, unless they have removed that very recently.
There aren't, but most people wouldn't think to do that, and again if the odd one or two do it's not going to cause a major headache, refer to my comment about MKC commuters above.
southern442
20 May 2013
Not only that, but if you ask people "do you want a seat with nobody else standing near you" of course they're going to say yes (and if you could be so kind as to throw in free refreshments and a footrub they probably would also say yes to those too). It could never possibly be them that is refused travel because they were too slow to book and all the trains are ""full"", that'd only ever happen to other people
If people really do want to travel without the rest of the public then they can take their car, or pay the increased fares
From a political point of view I always say that the public knows best, but not from a railway point of view. (If my memory serves me correctly, there was a whole BBC documentary about a group of passengers who wanted to take over southeastern and their whole mantra was to guarantee a seat for everyone during the rush hour or something) and when you have such a complex operation such as this, it's best not to consult the public.
Interestingly, before Thalys had a big falling-out with DB, they used to have one coach that they wouldn't issue reservations in that extended into Germany (i.e. past Aachen Hbf or whatever the other border crossings were), and that coach was available for local journeys using DB walk-up tickets (I think ICE price level, but might be wrong). You could viably do something like that - I don't know loadings on the ECML, but using a WCML example you might well save one coach on the Scottish services for journeys between Crewe and Carlisle where Avanti provide the local service for local journeys, but those seats could be reserved for Euston-Crewe and Carlisle-Glasgow where the train doesn't serve that role.
I think I'd probably loosen that up a little for the UK - i.e. have several coaches of purely reservations and nobody else is allowed in unless there is enough spare seating space, and then several coaches that are unreserved (or at least, you can reserve some seats but everyone else comes in too). Although if you go too far down that route you end up creating what is essentially first class all over again.
Yes, I've proposed that before, it would offer an element of "the best of both worlds" in that it would be possible to reserve up to right before departure even at intermediates, and if no reservations were left you'd know how busy it was and so would be able to decide accordingly if you preferred to almost certainly stand or try a different one. Part of the problem is that if travelling walk-up you've really got no decent indication of how busy a train is until it's there in the platform, so you can't even decide if waiting for the next one is sensible because that might be worse - and even real-time loading data won't be any use there unless it's already on the way.
Domh245
6 Apr 2013
nowhere
Very true, although I was thinking more about the "thee not me" phenomenon that polling tends to produce (see also Covid restrictions which seem to enjoy massive support in polling but don't seem to be so well followed - especially masks which apparently had widespread support before being made mandatory in supermarkets but you'd never have guessed that by counting the number of masks you saw before that point) - People will obviously want a railway where they've got a guaranteed seat and nobody standing in their vicinity (or perhaps even sitting next to them) but they'll change their tone as soon as they're the ones being denied travel because the train is full
superalbs
3 Jul 2014
Exeter
So, compulsory reservation, unless there's room, in which case you can go in without a reservation, otherwise you have to stand in another carriage? Mad.
I presume that people who want this to happen have never fallen victim to these wretched schemes, not here nor abroad?
southern442
20 May 2013
I'm not saying I want this to happen, I'm just suggesting it as a potential compromise. I'm sure you'd prefer this system to not being able to get in the train at all.
david1212
9 Apr 2020
Midlands
Generally at the time of booking I do not want to be committed to specific trains nor excluded. If I have to stand that is the risk I take.
I am fine with a proportion of seats being reserveable but only to those holding full fare tickets for the journey i.e. anytime then Saver and off peak when valid and season tickets. They should never be available with any form of discounted ticket. Futher the latter of course should only be available with a quota on services with loads well below capacity.
dosxuk
2 Jan 2011
If the system could guarantee a seat that met all your requirements (direction, window/aisle/middle, power socket, luggage rack nearby, actually having a window, near the toilet, opposite the disabled bay your grandmother is traveling in, etc) and guarantee you the space (so no sharing a table with the business person reading his broadsheet newspaper, someone who's bought the entire KFC menu to snack on and the parent with baby and toddler who don't want to sit still) then I can guarantee I will sit in that seat.
Without those guarantee's there are times I'm going to ignore the seat I've been told to sit in and go stand in a vestibule or find a better unoccupied seat.
I don't care if I'm cluttering up the train or ruining someone's ambience by standing in the vestibule when I've been allocated the non-window-window seat and I'd be trapped in there by the student bringing 17 bags full of washing back to mum's. Especially if I'm only going to be on there for half an hour, standing is preferable.
Many of these arguments about the ambience of intercity travel on this thread just seem to me to be a complaint from business travelers who can't expense their first class tickets any more and won't pay for it themselves and want the whole train to be like they're used to traveling. I just want to see them constantly stuck in the middle of three seats on a damp 321 next to the doors as a result of compulsory reservations, I suspect they'd soon come around to the idea of standing sometimes being preferable!
Roast Veg
28 Oct 2016
Not quite - it comes from once-a-year holidaymakers who want the delights of an airline experience.
It comes from lots of people who don't find crowded trains a pleasant travelling experience.
I'm an "indifferent" TBH. It has big downsides but also big upsides. I'm quite looking forward to seeing how it works for First East Coast, and one side of me does wonder if the experiments that is doing with a totally different model is one reason it got the go-ahead despite being potentially more abstractive than other OAO proposals.
A Challenge
24 Sep 2016
As an experiment by First it will probably work, as their service is designed for it (no opportunity for short journeys, not likely to end up taking passengers in event if disruption, not already being used by commuters and having similar parallel services), but it is also for those reasons a bad reflection of whether it will work on the rest of the network, but that is what will be forgotten when deciding if it is a success.
D6130
12 Jan 2021
West Yorkshire/Tuscany
Well, one scenario that could arise would be that you'd be automatically allocated a seat on a following service and e-mailed that automatically, if you were using an e-ticket? Won't suit everyone, but there's a lot of good stuff that can ensue if you know when people are going to travel. I've mentioned being able to make effective decisions on holding connections based on who will get disrupted before, too.
Does anyone know how it works in disruption on SNCF, FS etc?
On railways such as SNCF and Eurostar, in the case of a missed connection you would be permitted to travel on the next available service and as has been mentioned upthread, if there are no unoccupied seats available, there are tip-up seats in the door vestibules, plus most TGV units have a rather claustrophobic non-reservable second class "kiosque" compartment at either end of the train - ideal for a family with noisy kids! On the two occasions when we missed connections into compulsory reservation trains in Italy - once from France and once from Slovenia - we approached the Frecciarossa train managers before boarding at Milano Cle and Venezia SL; were directed to unoccupied seats, but when they came round to check tickets we were charged the 11 Euro on-train reservation fee each, because the delayed trains were not theirs.
Possibly true - indeed, short-train OAOs would do well to do this because it makes best use of their limited capacity - but I don't think it's a case of "the whole concept works" vs "it doesn't", but more to analyse the lessons from it about a year in (say) and inform developments from it.
A Challenge
24 Sep 2016
The current OAOs have had a buy on board policy for years though, so I assume that works for them (do they get a higher percentage of the ticket if bought on board on the basis it shows the passenger user their service, rather than say Northern or LNER?)
It means they don't have to pay commission to the selling ticket office, indeed. Of course what they'd probably like even better is for you to buy it from them on your phone.
NorthernSpirit
21 Jun 2013
I very much doubt season ticket purchases will resume to any degree of normality ever again, but theoretically:
1) Majority of people (vast majority) with season tickets will travel on the same services to and from work, and will be able to pre-book a seat well in advance, days if not weeks, even months. There should be a refundable deposit for this in my view, although how you reclaim it (tapping in?) is anyone's guess.
2) If the worse happens and you can't book a seat e.g. because you've finished work late AND there's zero capacity left on a InterCity service, then on those rare occasions you can get the slow train home.
How would 2 work betwen lets say Leeds and Brighouse, when the only option is the slow train (the Leeds to Wigan service). Most of the office wollers in Leeds live either in the posh flats at Mill Royd Mill or in the new builds on Lillands Lane (which can be seen from the railway line when heading towards Sowerby Bridge) or at Bailliff Bridge (once delivered a parcel to one who reconised me). Would they have to queue up at the ticket machines at Brighouse as there is no ticket office to buy a set time reservation where flexibility is thrown out the window or could they simply think screw this I'll resort to using my private vehicle from now on?
Having a no reservation no ride policy sounds too dictatory, too regimental to me.
One of the two jobs that I do I have to be flexible, which means reservations simply will not work as I could be called out and expected to arrive within 24 hours of the intital call out. This won't change if I get a promotion or not, I'm still expected to do the job.
I'd scrap first class and would rather make the business travellers put up with a knackered class 150 with broken seats, no sockets, the interior lights strobing and no table. They'd soon change their tune, if they want first class why not opt to use the car.
I prefer standing even if they are seats available.
Tazi Hupefi
1 Apr 2018
Nottinghamshire
This policy, in my view, is only relevant to InterCity style services.
Local trains, slow trains etc would and should continue to be unreserved.
I get the point some InterCity trains facilitate (in a small number of cases it seems), a local service, but I'm unsympathetic in those circumstances, as long as self service ticket machines, mobile apps etc allow a free reservation until minutes before departure.
Hadders
27 Apr 2011
The 'small number' of cases where inter-city trains provide local services includes (in no particular order):
Grantham to Newark
Newark to Doncaster
Didcot to Swindon
Swindon to Bath
Swindon to Bristol Parkway
Westbury, Castle Cary to Taunton
Crewe to Warrington
Warrington to Wigan
Bedford to Wellingborough
Wellingborough to Kettering
Kettering to Market Harborough
Market Harborough to Leicester
Derby to Chesterfield
Derby to Sheffield
Chesterfield to Derby
There will be many more.
What happens if someone turns up at the station to make a local journey only to find the that all the trains for the rest of the day are fully reserved? This is especially relevent if it's the return leg as they cannot exactly abandon the journey. Trust me, this would cause many more problems than it solves.
BJames
27 Jan 2018
I'm trying to see both sides and I understand that people like @Tazi Hupefi want to have a seat, but also want people around them to not stand. So that's your preference - as you've said, companies are looking to upgrade people to first class for a better experience. Why not do something like make first class reservations compulsory, and allow standard class passengers to do what they want? No-one wants to pay for first class and not get a seat so provisions are already in place for that. Just because you don't want people to stand doesn't mean that it isn't practical. Nobody wants to stand for hours on end, but if it means getting somewhere quicker they will, regardless of what they say here.
Upthread it was mentioned that if a train is cancelled or delayed you could be allowed to board the next service without a compulsory reservation. That completely takes away the argument that everyone should have a reservation - what does the TOC do if the trains for the rest of the day are fully booked? Lay on coaches for everyone? What's the point when there's a perfectly functioning way of getting the passengers to their destination - the train due in with standing room? In the first class scenario as above, you can sit in standard and get refunded any extra costs, or opt to wait for the next train with first class seating if it really matters that much to you.
