D365
- Joined
- 29 Jun 2012
- Messages
- 11,457
Following on from this discussion:
Yep I've heard this story too, I wouldn't be surprised if this has happened at multiple different companies.
To continue on from the post above: I'm not sure how many people here have come across the "3-2-1 backup rule"; I would definitely recommend following this strategy.
If you have six minutes spare, this video explains it rather nicely.
Thanks for the recommendation, up till now I've mostly been a Mac user but am in need of an easy Windows backup solution.
Related to this is making sure that, when possible, the backup locations are not permanently connected to each other. Encryption viruses can spread through connections. Equally an incorrectly run delete command can do the same. There is a famous story, I don't know if it's true, of a company having it's backup storage linked to the main system and someone ran a command that is equivalent to delete all and deleted their main system and backup.
I guess it all boils down to what form of backup you are after. If its simply having duplicates of the data so that should the main location fail or you accidentally delete a file then using an external drive, be that attached to the network, or plugged in when needed is OK. If the data is more valuable then some form of remote back up is needed. These days you can get USB sticks that have 512GB or more capacity so you could always get one of these and keep that in your car. However a backup is only as good as the last time the data was backed up, so if you forget to bring it in and run the backup software then it somewhat defeats the object.
As for software, have a look at Macrim reflect https://www.macrium.com/reflectfree the free version is ideal for making drive images, both full, incremental or differential
