Constant severe overcrowding on SWT caused by missing carriages
GodAtum
11 Dec 2009
The 1800 and 1834 from Guildford - Waterloo used to be 10 cars. there was always just enough room for everyone. Now they are halved causing constant severe overcrowding in what should be a pleasant journey. Does anyone know if SWT are planning to give back the missing carriages?
Even 1st class is full, and the guard cannot do anything as there is nowhere else for people to move.
2P60 (1800) and 2P62 (1834) are both diagrammed as 5.444 from Portsmouth Harbour since Dec 2015 so it doesn't seem temporary.
2P62 also seems to have been a 5.444 in the previous Dec 2014 timetable.
jopsuk
13 May 2008
The carriages are presumably at that time being used services out of Waterloo. Didn't you have a thread about this a month or two ago?
Anyway, once the Class 707 fleet starts to be delivered there will be a pretty major shake up of allocations I'd have thought, as they will be 30 five car units coming in with no loss of any other units. It'll release a whole load of 450s for SWML use the 458/5s move onto Reading duties.
jopsuk
13 May 2008
I think for SWT the forum-mandatory modifications are restoration of the 1st class compartments and the snugg.:lol:
Alternatively, retraction with AC motors and fit a 444-eqsque interior, upgrading the coupler, control system and cab to be Desiro-compatible <D
(how does the OP know both services are overcrowded every day?)
Kite159
27 Jan 2014
West of Andover
Although come 707 introduction, releasing more 450s, I'm sure a pair of 450s in place of a single 444 will increase seating, and also moaning about 450s appearing on an outer suburban service in lieu of the 444s ;)
HarleyDavidson
23 Aug 2014
Not helped either by the damage inflicted by a duff juice rail on Monday night.
Perhaps if you used a modicum of common sense, you'd use either the service before or after if you know that those trains are 5 car formations.
TEW
16 May 2008
2P60, 1645 Portsmouth Harbour-London Waterloo was always pretty busy service from Guildford onwards as a 10-car 444. I did think it would lead to overcrowding when I saw it had been reduced to a 5-car. It now joins with another 444 arriving from Poole to form the 1900 Waterloo-Portsmouth Harbour, rather than the whole train forming that service. The service before from Guildford, the 1747 has been reduced from a 12-car 450 to 8-car 450 too, but shouldn't have too big an issue on that train.
Or if time to spare could take a Waterloo via Effingham train. Recently had carriage to myself almost all the way to Waterloo at that time.
hassaanhc
5 Jan 2014
Southall
The issue here appears to be not wanting to use fasts that aren't a 444, let alone a stopper! :lol: similar happens on the Windsor lines to/from Richmond and Twickenham, where the difference in times is less than 10 minutes rather than the 15-30 minutes here.
The Ham
6 Jul 2012
There are a lot of people for whom that is not an option, not that the routing of trains shows it, as there are significant numbers of people who head west from Woking having got off a train from Guildford. (The opposite is also true).
GodAtum
11 Dec 2009
There is also an issue with bike space. Many people park their bikes in the vestible at the ends of the carriages which on a 444 is a very tight space.
HarleyDavidson
23 Aug 2014
Bike spaces are clearly marked. They are strictly prohibited behind the drivers cab because the doors which secure the leading driving cab are linked to the emergency plungers in the cab and may open without warning and are an emergency exit for the driver.
And yes I will sling any cyclist out of there too, whether they like it or not.
Art.49 NRCoC.
Any Train Company may refuse to accept an item of luggage, an article, an animal or a cycle, even though it meets the requirements set out in Condition 47 and 48 and Appendix B, if, in the opinion of its staff:
(a) it may cause injury, inconvenience or a nuisance or it may cause damage to property;
(b) there is not enough room for it;
(c) the loading or unloading may cause delay to trains; or
(d) it is not carried or packaged in a suitable manner.
So in the case of putting it behind a cab, a & b apply, as for a vestibule, a,b & c apply.
Personally I'd like to see a complete ban between 0600 & 1000 and 1600 & 2000 for all cycles except folding ones. And a fare of £5 per single journey.
The Ham
6 Jul 2012
That will be fine as long as SWT guarantees that for normal daily usage that there are sufficient (number and quality as defined by ATOC's guidance on cycles at stations) cycle storage at all stations.
The problem when they extended the cycle ban out to Basingstoke was they didn't add any extra cycle parking, which was often insufficient prior to the ban.
HarleyDavidson
23 Aug 2014
It's guidance, not obligatory. Guildford's commuters are lazy.
They've been given a secure compound for which they have to pay to use, most won't, so they use the ones on the former mail dock and the ones outside the crew block which took 3 valuable parking spaces from the staff car park.
There can be a considerable number of spaces in the bike racks (all of which have CCTV) and yet they will constantly chain their bikes to the railings and in the staff/traincrew walking route rather than go the extra 10m to the big bike racks outside the crew block!
Locking a bike to the railings on the walking route gets the bike lock cut with a Dremel disc cutter/saw/bolt cutter and the bike put into secure storage with a penalty of £20, they then of course also have to pay for a new lock. There's also a considerable number of spaces on the up side under the passimeter bridge, but again they're too lazy to go there, yet there's at least another 20 spaces there during
The Ham
6 Jul 2012
I want thinking of Guildford station. I was thinking of my home station where the buck racks are too close to each other acording to the guidance, that means that since of the possible spaces aren't used, but that is so people can still access their bikes to unlock them.
It gives the impression that there are spare spacers when practically there are not.
Also I was thinking of during the early days of the cycle ban where places like Farnborough Main had insufficient cycle parking and Southampton Airport Parkway had at best what could have been described as "token cycle parking" which was always full.
The point I was making was that BEFORE any new restrictions came into force that SWT would need to ensure that there was adequate numbers of spaces (bikes chained to railings count as occupying a proper space) of an adequate quality (I.e. all the spaces are usable), with premium (paid for spaces) not counting towards the total number (but then nor do cycles stored there).
P.S. can you provide details of how to apply for the secure cycle parking at Guildford as I don't seem to be able to find details online, which probably doesn't help people to use it.
jopsuk
13 May 2008
Paul180
3 Jan 2010
Do you mind I am from Surrey
Art.49 NRCoC.
What about Rail Gourmet person who has put there trolley next to the cab door just lik on the train I am on at the moment?
theironroad
21 Nov 2014
Generally the rail gourmet staff are OK and the trolley is mostly in the door area, and with most of them not their too long. Most people don't put bikex behind the door, but the odd one or two have and fully blocked the cab door and will be asked to move it.
HarleyDavidson
23 Aug 2014
And those that refuse will find their bike forcefully removed and dumped unceremoniously on the platform (done that) or the train doesn't move (done that too).
Quite simple really, you don't block my doors and actually you're committing an offence by blocking any door with a green egress handle on it, as that's an emergency exit and I'm quite sure that any lawyer would have an absolute field day with claims in the event of an incident or accident where people are injured due to a cyclist blocking one.Sue the cyclist?
Not disagreeing with the gist of this, however on many routes served by trains which don't have designated cycle areas (eg 317s, 365s) the official guidance is for cycles to be stored in doorways, which of course have egress handles.
It's not ideal that I can potentially turn up at my local station, ask where to store my cycle and be told "in the doorways", then when I turn up at Waterloo do the same thing and potentially get told off.
Paul180
3 Jan 2010
I am pretty sure that all SWT stock has designated cycle areas.
All well and good, however the passengers just sees it as 'the railway' and 'this train'.
And, of course, on a DOO train (which unfortunately may well turn out to be the way of the future) you might as well say anything goes. The driver has little idea nor care what's going on behind him. (Except when a problem person or people choose to make a nuisance right behind the cab - it grates how people have up to 250m of train yet *have* to position themselves and make a racket right behind the driver's cab, those doors are on most trains surprisingly thin and poor fitting).
SpacePhoenix
18 Mar 2014
What sort of % of the passenger doors on a typical unit will have the green egress handles? I wouldn't be surprised if some units have them at every passenger door
The Ham
6 Jul 2012
As far as I am aware all of SWT's trains have them at every door.
Which leads to a interesting dilemma, if having a cycle in a doorway (emergency exit) is always a safety issue that means that cyclists should not block the doors or a oassageway to the soors until the train is stopped at the station (or AR least traveling slowly). However when getting on/off at stations it is best to get cycles off first (or at least nit the last person off anyway), yet to do so would mean that they would have to block the emergency exit.
Also, IIRC the metro (red) trains at SWT only have cycle/pram areas within doorways and as such are bit like the Desros which have cycle storage areas away from the doors.
TEW
16 May 2008
455s and 456s have designated flexible spaces which can be used for cycles or pushchairs, which don't block the doors. They are located next to the wheelchair space. In both driving vehicles of a 455 and one drivimg vehicle of a 456.
HarleyDavidson
23 Aug 2014
And with a relatively few exceptions, most cyclists ignore the big white sign on the side of the units telling them where the storage space is and just plonk it in any doorway or as recently appeared on a couple of trains (one SW, one SN), they park their bikes on a SEAT! <(
I even found two in the toilets to avoid detection during the peak periods, they were needless to say ejected... <D
Dr_Paul
3 Sep 2013
A good point. The last time I took my bike on the train was a year or so back on an up Reading service from Richmond to Clapham Junction, 458 stock, at about 17.00. The train was crowded, I couldn't get my bike in the official back spaces so I stood in the least crowded vestibule I could find. In short, I was a right nuisance, and I've not taken my bike on the train since.
Bikes are barred from down services from Waterloo in the evening rush hour (as they are up with up services in the morning rush hour), but up services are getting pretty stuffed these days at rush hour, and sometimes even outwith rush hour and at weekends, and bikes do take up a lot of space and are awkward to manoeuvre about. Also, other passengers may get grease on their clothing from the bike chain if the train is crowded.
A £5 bike charge might be a good idea, but it's only fair that there must be some way that if someone pays it, his or her bike will be found a suitable space.
HarleyDavidson
23 Aug 2014
Perhaps they should consult with Nederlandse Spoorwegen to see how they do it and administer the costs etc.
