Cooking facilities in drivers cabs? Really?
Discussion in 'Traction & Rolling Stock' started by Harlesden, 2 Nov 2011.
Thread Status:
  1. Registered users do not see these banners - join or log in today!
    Rail Forums
  2. Pacerpilot
    Pacerpilot Member
    332
    7 Jun 2010
    66s still have a hotplate.
  3. MidnightFlyer
    MidnightFlyer Veteran Member
    12,827
    16 May 2010
    Hang on, I've got the wrong end of the stick here...
  4. MidnightFlyer
    12,827
    16 May 2010
    Are we asking do they have them in modern traction or old traction?
    Pretty poor OP...
  5. sprinterguy
    sprinterguy Established Member
    10,490
    4 Mar 2010
    Macclesfield
    Class 37s and 40s and their ilk did indeed used to have a small stove for the drivers' convenience, but to suggest that this somehow made the cab of these locos a better working environment (Draughty, primitive in design) than that of the modern, air conditioned, ergonomically designed cocoon of a Voyager/Meridian cab is quite frankly ludicrous.
  6. Mojo
    Mojo Forum Staff Staff Member Administrator
    17,221
    7 Aug 2005
    0035
    And of course drivers on modern MUs can have the Train Manager or Host bring them a cup of tea already made :smile:
    Obviously units without such facilities excepted, but examples given were Vomits/Mermaids/etc.
  7. Royston Vasey
    Royston Vasey Established Member
    1,515
    14 May 2008
    Cambridge
    Erm, it is well known that there is or was an electric hotplate in at least one cab of many diesel locos for the heating of water/drinks. Hardly cooking but I've heard anecdotes that they could and were used for heating food as well. I understand even the class 66 does.
    Your reply to the OP was hardly Charles Dickens, and incorrect to boot.
  8. MidnightFlyer
    12,827
    16 May 2010
    But 221s don't have such facilities in the cab...
  9. table38
    table38 Established Member
    1,812
    Stalybridge
    Class 40s had a hotplate but it was in the engine compartment, and perhaps appropriately a toilet at the "No.2" end :)
  10. Royston Vasey
    1,515
    14 May 2008
    Cambridge
    Why delete your accurate post then? :lol:
  11. phil8715
    phil8715 Member
    266
    19 Aug 2007
    Class 47's certainly had them.
    Sent from my GT-P1010 using Tapatalk
  12. MidnightFlyer
    12,827
    16 May 2010
    Because I got the wrong end of the stick, I thought he meant do 221s etc have them, not is what is written underneath true?
  13. Wyvern
    Wyvern Established Member
    1,573
    27 Oct 2009
    In the past, freight trains would spend long periods waiting in goods loops.
    This happened less as wagons were able to travel at a higher speed and more able to fit in with passenger speeds. Most of the goods loops were removed. From custom and practice, locos stiill had stoves until the introduction of the 66s.
  14. district
    district Member
    1,045
    4 Aug 2011
    SE16
    Another absolute gem from Yahoo Answers...
    Just like this!
  15. ChiefPlanner
    ChiefPlanner Established Member
    5,680
    6 Sep 2011
    Herts
    08 shunters had a Belling type cooker pad - usually used as a heater
  16. Minilad
    Minilad Established Member
    4,317
    26 Feb 2011
    Anywhere B link goes
    I can categorically state 220s and 221s have no in cab cooking / warming / heating facilities !!
    But the galley at the first class end does have a microwave !
  17. Old Timer
    Old Timer Established Member
    3,704
    24 Aug 2009
    As anyone will tell you, the Class 47 cooking rings were designed to rattle !
  18. Flywaver
    Flywaver Member
    190
    10 Nov 2009
    Lol Old Timer. So true! They were great for cab heat...
  19. Old Timer
    3,704
    24 Aug 2009
    A photo of a crew enjoying the fruits of the cooker !
    The date : Aug 1979
    The location : Up Slow line at the south end of Ampthill Tunnel
    The job : OHL staff were installing the registration equipment in preparation to run the OHL inside the tunnel. The 08 has just arrived and collected the men and is about to set back into the tunnel.
    The red banner flags (on both lines) simply denoted the limit of the worksite. Not in the Rule Book at that time but the application of common sense at a time when there was no official marking of the limits of each work site. Worksite marker boards emerged from 1985 onwards following a number of accidents/incidents where trains had run into work sites and collided with other trains or equipment
    Flywaver
    You will remember how the cooker kettle/pot guards on 47s used to increase their vibration in proportion to the amount of power applied ? :lol: :lol:
  20. IanXC
    IanXC Emeritus Moderator
    5,731
    18 Dec 2009
    It would be great if that transpired to be the origin of that phrase!
  21. AlterEgo
    AlterEgo Veteran Member
    12,123
    No longer here
    Quite off topic I know, but the USAF C-130J Hercules aircraft have a microwave on the flight deck!
    They took great pleasure in showing it off when I visited the Hurricane Hunters in Mississippi a few years back.
  22. Waldgrun
    Waldgrun Member
    266
    13 Oct 2011
    Don't forget that all BR standard class steam engines had the capability for cooking and hot water.:p
    Fry up on the shovel and Billy Can placed above the firebox door! (For those too young to remember!)
  23. Rugd1022
    Rugd1022 Member
    565
    19 Feb 2010
    Rugby
    During the Winter months I often use the hotplate on our 66s as a cab heater, it's much better than the hot air heaters as they tend to make you drousy. I still use the hotplate to boil water for my tea, using my old mash can, and they're handy for heating up tins of soup as well.
    On a ballast job you have more time to make a proper meal, if you can be bothered to carry all the kit that is.
  24. OuterDistant
    OuterDistant Member
    441
    25 Oct 2010
    South Cheshire
  25. pinkpanther
    pinkpanther Member
    133
    10 Jul 2009
    Bournemouth
    33012 has a hotplate (with obligatory kettle) just inside the engine room at one end.
    Although it probably doesn't get used very often at Swanage (too much tea floating around from other sources!), according to the 71A group news page it came in rather handy recently at the NYMR gala.
  26. Cherry_Picker
    Cherry_Picker Established Member
    2,675
    18 Apr 2011
    There is a hotplate in a mark 3 DVT. Dunno whether they still work or not, but they are there.
  27. Yew
    Yew Established Member
    3,370
    12 Mar 2011
    Most british tanks have a kettle (im guessing a hotplate and kettle, rather than an integrated unit)
  28. Hydro
    Hydro Established Member
    2,204
    5 Mar 2007
    A lot of military vehicles have what is known as a BV, or boiling vessel. Not quite a kettle/hotplate combo.
  29. 9K43
    9K43 Member
    558
    1 May 2010
    Class 40's were ice boxes on wheels, the doors fitted where they touched and the windows kept slipping down.
    They were full of expanding foam to stop the hurricane of cold air which blew in through every nook and cranny of these engines,
    As someone remarked, the stove was in the middle of the engine compartment.
    Before leaving HM, I placed a can of boiling water on such a stove to go class6 to Manchester.
    On arriving at the location after about 45 mins running, I went for my boiling can, but alas it was full of cold water by this time.
    The comedian who decided that the mashing ring was in the engine compartment, ought to spend the rest of his days riding about in such an engines gasping for a quick brew.
  30. sbt
    sbt Member
    268
    12 Oct 2011
    BV's, not just for making tea...
    Battered examples of the earlier model:
    http://www.fv432.co.uk/wwwfv432couk/ces/boilingvessel.htm
    Data Sheet for the current model, describing all the various stuff you can do with it:
    http://www.armedforces-int.com/article/fv706656-cookingboiling-vessel.html
    The US now has their own version, from the same UK manufacturer as ours.
    They are not just a luxury. Whilst I wouln't want to overstate things, on current ops they minimise stop time for food etc. in an environment where being on the move equals survival and hydration is vital.
    On the railways I imagine that a properly fed and watered railwayman is a more comfortable and alert, and therefore safer, railwayman.
    BVs for all cabs and vans? :)
Thread Status:
Share This Page
