Could/Should all the Sub-Surface lines merge into one line eventually?
Discussion in 'London Underground' started by NorthKent1989, 29 Aug 2017.
  1. philthetube
    philthetube Established Member
    1,853
    5 Jan 2016
    Wow, you are easily annoyed <(
  2. Dr_Intoxicated
    Dr_Intoxicated Member
    361
    5 Jan 2014
    Yes imagine how the District line must upset them
  3. edwin_m
    edwin_m Veteran Member
    17,017
    Given it's being split, two of the several royal couples that have divorced would be more appropriate.
  4. cjp
    cjp Member
    1,060
    28 Jan 2012
    In front of a computer
    Fixed.
  5. Antman
    Antman Established Member
    6,235
    3 May 2013
    Is it? I thought the big stumbling block was the overcrowding it would cause at Camden Town with so many people changing trains?
  6. rebmcr
    rebmcr Established Member
    2,947
    15 Nov 2011
    Cambridge
    You are correct, it is dependent on the Camden Town rebuild.
    Two consultations on proposals for this had failed in the last decade or so; the third currently seems to be progressing well.
  7. Antman
    6,235
    3 May 2013
    Good news, I hope it all goes ahead.
  8. Antman
    6,235
    3 May 2013
    Wow, rather pointless posting:roll:!
    Clearly having two separate Northern Lines through Central London is a recipe for confusion.
  9. Dr_Intoxicated
    361
    5 Jan 2014
    Might they not rename one of them at the point they were separated? This would be easy once the northern destinations of the two branches are constant.
  10. David Emmott
    David Emmott Member
    866
    26 Nov 2015
    It's always seemed odd to me that the tube line which runs the furthest south should be called 'Northern'. Not unlike the Northern line of Merseyrail, although the Wirral extends more southerly.
  11. Busaholic
    Busaholic Established Member
    8,651
    7 Jun 2014
    To have called it 'Southern' might equally be considered odd in High Barnet. apart from the name already being appropriated.:) Actually, it's a bit like Oxford Street leading to Oxford (eventually).
  12. tranzitjim
    tranzitjim Member
    209
    4 Jun 2013
    Australia
    Now that three of the lines, all share the identical fleet of rolling stock, for the first time in their lives, I guess we can make any rearrangements we would like to do.
    Even with the S8 on the Met line, can include the Met line in any shakeup we want.
  13. LU_timetabler
    LU_timetabler Member
    113
    5 Feb 2017
    No we can't Met's S8's are not permitted to operate in passenger service anywhere where they already don't around the Circle due to short platforms.
  14. cjp
    cjp Member
    1,060
    28 Jan 2012
    With SDO surely that is "not permitted at the moment "?
  15. tranzitjim
    tranzitjim Member
    209
    4 Jun 2013
    Australia
    I guess there is little works needed to extend some platforms to handle 8 car S8 trains if we need to extend them as such. In any case, can we not use S7 trains on some Met runs?
  16. Peter Mugridge
    Peter Mugridge Established Member
    10,521
    8 Apr 2010
    Epsom
    There are some terminus stations where S8s would be outside the starter signal. Wimbledon is an example.
  17. cjp
    cjp Member
    1,060
    28 Jan 2012
    I never thought of that :oops:
    Repeater signal like a fog one but beyond the starter?
    Or simply not worth the effort to standardise trains?
  18. Dstock7080
    Dstock7080 Established Member
    1,533
    17 Feb 2010
    West London
    Depots, sidings, terminal stations have had much work adapting from C & D Stock to the longer S7 Stock.
    A great deal of work would be required to make this happen again for S8 Stock, i.e. Baker Street pfms.5&6 require the last 3 doors (1car) of an S7 Stock to remain closed, this would be 6 doors (2 rear cars) to remain closed for an S8.
    Several District Line stations already require 1 or 2 doors both at front and rear of an S7 train to remain closed.
  19. edwin_m
    17,017
    Many, probably most, termini have pointwork immediately beyond the platform ends. If the train couldn't clear this on the way in then it probably wouldn't be able to get out again and even if it could it would block some other moves before it did so. The same is true of some through stations.
  20. cjp
    cjp Member
    1,060
    28 Jan 2012
    Something else I had not thought of :oops:.
    Perhaps bit like being able to land land in a small field OK but it being too short to take off again?. :)
    I will stick with the day job and leave tube things to the experts!"
  21. rebmcr
    2,947
    15 Nov 2011
    Cambridge
    S8's already use SDO on some platforms in Zone 1. They'd have to use even higher levels elsewhere — and I'm not sure at what threshold having large numbers of doors locked out becomes a safety issue.
  22. tranzitjim
    tranzitjim Member
    209
    4 Jun 2013
    Australia
    For as long as you have an auto lockout feature on all those doors, there should not be any safety matter. It is a convenience matter, as people would need to walk through one or two lengths of carriage in order to get off.
    I do trust the S stock all have an automatic detector, which would automatically lock the door out when it detects there are no platform at that door?
  23. TFN
    TFN Member
    97
    17 Aug 2017
    There's also another minor issue of installing the "Door not in use" indicator on all the doors in the 2nd and 7th cars of the S8. I'm not sure if they have them already, I never travel on the metropolitan line.
  24. edwin_m
    17,017
    At some point SDO becomes counter-productive because of the distance people have to walk through the train (which may be packed) to get to a working door and the aggravation of people missing their stop because of it. It would also the evacuation time somewhat if a train had to be emptied at a platform through fewer doors, but evacation at a platform would still be a lot quicker than in a tunnel so that's probably not much of a concern.
  25. gallafent
    gallafent Member
    252
    23 Dec 2010
    This reminds me that I was surprised that the red “door not in use” indicators on S7s running Circlesmith trains do not seem to light up until the moment that the doors are released at the station with short platforms, leading (since people weren't listening to the announcements, or were foreign, or hearing-impaired, etc.) to a stampede for the doors that work, and an unnecessary increase in dwell time to allow those people to leave the train.
    Why, I wondered, do those lights not illuminate as soon as the train leaves the previous station, … or of not then, then at least 30s (say) before arrival at the short platform? Ideally, they'd blink a few times too, to attract attention. Time for a software update I'd say.
  26. rebmcr
    2,947
    15 Nov 2011
    Cambridge
    There is an audio announcement with a corresponding PIS visual message at the previous station.
    I believe the at-door indicators are interlocked with detection of the platform beacon.
  27. TFN
    TFN Member
    97
    17 Aug 2017
    Honestly I forgot they even existed until this thread reminded me of them. They aren't exactly easy to see being directly above the door. I wish they could have installed red lights where the white door lights are, and when the train is at a short platform, the red lights can start flashing. I don't know if that would be effective.
    Currently I find it very amusing when I'm in the last car at Gloucester Road and I see people running for other doors.
  28. rebmcr
    2,947
    15 Nov 2011
    Cambridge
    I don't know whether flashing would be appropriate, I would associate that with "please wait, the door opening sequence is proceeding". Solid red with an accompanying eye-level 'Door not in use' indicator would be great, though.
  29. edwin_m
    17,017
    One thing the Underground lacks that many other metros have is arrows that light up to show the side the platform will be on at the next stop. If they had them they could have something like a red cross with an arrow pointing down the train for areas where the doors won't open.
  30. rebmcr
    2,947
    15 Nov 2011
    Cambridge
    Maybe after the 4LM signalling is complete, certainly not before on the SSL.
Share This Page
