NotATrainspott
- Joined
- 2 Feb 2013
- Messages
- 3,223
The Space Train proposals for the Victoria line had the fourth-rail electrification system replaced with a conductor bar on the roof of the tunnels, which allowed the supply voltage to be safely increased to 1.5kV with its resulting efficiency benefits.
Since the subsurface lines have much more vertical headroom than any of the Tube lines, and have roughly the same loading gauge as any of the normal lines in the country, would it be possible for these lines to be converted to use a similar system?
They're increasing the fourth-rail voltage up to 750V from 630V as part of the SSR renewal program because the S-Stock draw more power and can do regenerative braking. Beyond this there isn't much more they can safely put through the fourth rails due to the inherent safety issues of putting that much voltage within easy reach of passengers and track workers.
I imagine it would be unlikely the S-Stock would be converted to OHLE operation as they would require a pantograph well somewhere and presumably major changes to their power systems (at least to allow 1.5kV DC operation, but allowing them to work under 25kV AC would be very advantageous as well so they can share track with an electrified Chiltern line) so it would be their successors which would be the first trains capable of it.
The amount of energy wasted by 750V third-rail on the NR network is significant enough to warrant the conversion of it to 25kV OHLE; London Underground is going to have to do something similar at some point as well presumably.
