Coventry to Haymarket; weekend of 12/13 November
Eagle
20 Feb 2011
Leamingrad / Blanfrancisco
I'm almost certainly going to be visiting a certain someone in Edinburgh weekend after next. And as you can imagine I want as much time up there as possible :D
So with this in mind, I want a return with railcard (advances are fine) from Coventry to Haymarket on the weekend of 12/13 November. I can't get to Coventry station before 08.30 on the Saturday, but otherwise would prefer as much time as possible. I can find the following:
  • On the Saturday, leaving Coventry at 09.42 and arriving Haymarket at 14.16, advance costs £26.40
  • On the Sunday, leaving Haymarket at 18.57 and arriving Coventry at 23.20, advance costs £32.35
  • Total: £58.75
Can you beat this?
(Disclaimer: I'm not going to be able to confirm till tomorrow or the day after so I'm hoping the cheap advances will stick around for 24 hours or so...)
bb21
Emeritus Moderator
4 Feb 2010
Naughty weekend? :-P
Wouldn't you prefer to come back Monday morning? The Off-Peak Return is unrestricted after 0500 and comes in at £73.15 only.
Eagle
20 Feb 2011
9am lecture on Monday. Boo.
Why Haymarket?
I'm getting a lift and Haymarket's more conveniently sited for that.
Also it reduces my journey time by 7 minutes each way :D
scotsman
6 Jul 2010
Nup. 4 each way. 5 if you're unlcuky.
SS4
30 Jan 2011
09:42 COV-PRE = £10.55 (a 1151)
11:53 PRE - HYM = £11.90 (a 1416)
18:57 HYM - PRE = £14.85 (a 2115)
21:17 PRE- COV = £13.85 (a 2320)
Total = £51.15
Although they appear to be tight connections they should be the same train (I'll eat my hat if they're not)
Eagle
20 Feb 2011
They are clearly through trains, because they're the services I specified in the OP (besides, I'm not sure the WCML can cope with two-minute headways between IC services just now...) :P
bb21
Emeritus Moderator
4 Feb 2010
Can't do any better with APs.
You can get a cheaper flexible ticket though. The Off-Peak Return from Rugby is only £68 and unrestricted after 0415. Valid via Coventry clearly. Whether the additional £10 is worth it as insurance in case you miss your booked train is up to you.
Edit: Now it looks like £17 rather than £10.
Eagle
20 Feb 2011
I've booked the split at Preston. It seems the reason only these trains had cheap advances left is they were Pendolinos (and I've managed to get declassified first class reservations for both halves on the way up :D—and the way down is a through service so all kinds of win).
