Create your own rosters with BVE Launcher
eezypeazy
4 Jul 2005
As you may have seen elsewhere, Alistair Campbell has produced a nifty little program.
BVE Launcher was originally designed to launch routes regardless of where they are stored (such as on a CD, for example).
However, it can also be used to create your own Duty Roster. You can join together your favourite runs, in whichever order you please, and drive them in that order, one after the other. Your Roster is saved as a small batch file - very easy to share via email with your friends! Why not challenge them to drive it?
It gives me great pleasure to be able to host this program. Click on the image below to visit my site and get a copy.
Regards
eezypeazy
Mojo
7 Aug 2005
Isn't he a Labour Party spin doctor? :p
Sturdjos
27 Jan 2006
Can it also be used for BVE 2?
Also, can you make it so (without BRR Route Randomiser) you can run trains to real time (or your computer clock?)
eezypeazy
4 Jul 2005
Yes, it can be used for BVE 2.
No, it doesn't allow you to change the timetable - it simply strings together existing routes. However, there is a Timetable Editor tool that allows route timetables to be edited relatively easily (although it doesn't produce the BVE 4 display bitmap). Sadly, the Timetable Editor tool is offline, and my attempts to contact the author have so far failed.
eezypeazy
eezypeazy
4 Jul 2005
nutter said:
I can't get it to work :cry:. It says 'invalid filename' when I try and launch BVE (2or4). It looks like I haven't installed it right. Please help
You need to specify the path to the BVE 2 and BVE 4 programs.. try that...
eezypeazy
nutter
13 Nov 2005
Albrighton, Nr. Wolves, Shrops
eezypeazy
Done that. But now when I try and run BVE 2 or 4 (BVE 2 wont start at all) i don't get any response when I click to start BVE, it just exists without notification
BVE2 won't start up with Route randomiser either, and when I try and start it on it's own it says the parimeter is incorrect.
I don't use route randomiser with BVE4 but BVE4 works on it's own without any add-on programs
eezypeazy
4 Jul 2005
Then I don't think that your problem is with BVE Launcher.
I suspect that you've not installed your versions of BVE to the default locations. Have a look here http://forums.atomic-systems.com/viewtopic.php?t=53710&sid=8b6eed468b9af02be8773e949b354d56 for a guide to where the default locations are.
BVE Launcher has been downloaded 43 times since last night, and this is the first report of a problem.
Route Randomiser can be worth using with BVE 4, because it enables you to easily swap trains, without editing route files.
Regards
eezypeazy
