Crewe based LM guards going to EUS
Discussion in 'Allocations, Diagrams & Timetables' started by gray1404, 19 May 2015.
Thread Status:
  1. gray1404
    gray1404 Established Member
    3,301
    3 Mar 2014
    Merseyside
    Do Crewe based LM guards get as far as EUS on their Trent Valley Line services? Or do they only take them as far as MKC before a crew change?
    Assuming it would be a MKC or EUS based guard that would take the service the rest of the way to EUS. I've heard Crewe guards don't do South of MKC and wondered why this is?
    Rail Forums
  3. NSE
    NSE Established Member
    1,231
    3 Mar 2010
    The return journey I made from Euston to Stafford the guard changed at Northampton both ways. It was a while ago though.
  4. MidnightFlyer
    MidnightFlyer Veteran Member
    12,714
    16 May 2010
    A minor detail but aren't traincrew based at Bletchley and not Keynes?
  5. plastictaffy
    plastictaffy Established Member
    1,088
    18 Nov 2012
    Unfortunately, Maps has stopped.
    No. Crewe Guards sign as far as Milton Keynes, both via Weedon, and via Northampton. Strangely, Crewe drivers sign only as far as Rugby. Link one Northampton guards sign Crewe, and one or two trains are worked throughout, from Euston, by the Northampton man. I have the diagrams if you're wanting to know which ones.......
    Bletchley Guards bring most of the fliers to and from Milton Keynes, with Watford having one or two, and Northampton having a couple.
    The reason they don't sign it is that they've never had a need to, with three depots south of Rugby that all sign as far as Euston, let alone the RMT having a dicky fit if it was sanctioned. There was a hare-brained scheme to get Crewe to sign Euston last year - they were going to sign the fast lines only, apparently........
  6. Urban Gateline
    Urban Gateline Established Member
    1,515
    8 Mar 2011
    and also the fact that there are no Euston based LM Traincrew!
  7. DarloRich
    DarloRich Veteran Member
    17,933
    Work - Fenny Stratford(MK) Home - Darlington
    Bletchley and Northanmpton.
    Dont crew changes most often happen at Northampton (for the loop services) and MK for the fasts?
  8. plastictaffy
    1,088
    18 Nov 2012
    Yes, but, as I previously stated, there are one or two that go all the way from Euston to Crewe with a Northampton Guard. There's only a couple of Crewes that go via Northampton, one dead early that starts there and a couple in the evening peak. All sunday Crewes go that way though. Bletchley Guards usually hand over at MKC, although they do/did have one job that goes via Weedon as far as Rugby - probably for route knowledge.
Thread Status:
Share This Page
