YorkshireBear
- Joined
- 23 Jul 2010
- Messages
- 8,686
Says in june 2011 of modern railways that the dft is expected to announce electrification of crewe, and give WCML bidders chance to come up with stratergies to replace voyagers.
Now I know this is far too radical (and stupid) to ever be used in practice, but could they invent some kind of specialist "pilot" loco that supplies power to the train to drive itself?
Euston - Chester & Liverpool 1tph
I was aware it's a little silly! However, I was quietly reasoning (hoping?) that since it's possible to generate enough power to drag the sodding thing anyway, it would be possible to get the thing to power itself. Entirely out there though, I realise.You wanna send nearly 10MW through a Dellner coupler???
Look at the size of the sets of three cables that run between the carriages on 22x units. Double the cross sectional area of that, and then you're close to what would be needed.
Next think of the fact you'd need four powerhaul engines to produce this much power.
Pendos currently use HV transmission across the roof and multiple transformers, where voyages don't use HV transmission, but 1000V 3 phase IIRC.
Yes it's possible, but it's a pain in the arse and wouldn't yeild that much benifit, the problem isn't distributing power along the unit, it can use 1 phase HV. It's getting it from loco to MU.
Hmm, there's now the potential for dual voltage EMUs to run direct services from the Wirral peninsula to Birmingham/ London.
Plus there's one ATW DMU freed up by this (the hourly Crewe - Chester shuttle), which means they can introduce "Gerald 3" now
...There's twenty five car Voyagers that (plus a couple of "spare" cabs)...
Or from Birmingham/London via Chester and Rock Ferry to the presently unused 130metre Platform 2 at Liverpool James Street.... Euston - Chester & Liverpool 1tph
Hmm, there's now the potential for dual voltage EMUs to run direct services from the Wirral peninsula to Birmingham/ London. ...
I'm not sure how else you could get an electric train from London to Liverpool via Chester.
What alternative is there to more pendos or mini-pendos, you can't run stock on the WCML without EPS...
Yes you can. You are just limited to 110 mph. That's why the original IEP programme included some trains to run the Northampton fasts vice 350s. At 110 mph they use up comparatively less paths than the 350s.
I'm not signed up to the idea of mini-Pendolinos. Virgin would have three different lengths of Pendolino, bringing the same complications of stock rostering as they have with having a fleet of 221s on specific routes, and why order new trains that have the existing poor capacity of the ones they replace when those services are already overcrowded?
There's better economies of scale to be had from having fewer different lengths of Pendolinos: Order up to 390073 as eleven carriage Pendos as well as adding the extra carriages into 390001-390031, giving 51 eleven carriage Pendolinos covering all the current Pendolino operated routes and 21 nine carriage Pendolinos to replace a similar number of VT 221s on Birmingham-Scotland and London-Chester/Holyhead. The main West Coast services are all in need of lengthening above their current nine carriage capacity, and the Voyager operated services definitely need to be longer than they currently are.
Failing that, then adding a pair of pantograph cars into the existing 221s, to make seven carriage trains, would be a step in the right direction, but I'm keen to see the 221s go to Crosscountry.
I agree with others who feel that there is currently a lot of pressure from the DfT for the WAG to provide the capital for electrification into Wales: If they want to be devolved, then they can pay for infrastructure improvements themselves!
If northern where working it they'll be flush with 4 carrage dual voltage EMUs soon that would be able to work the route. And continue to Birkinhead, if so desired. An increase in frequency to half hourly may be on the cards for the shuttle too, but it should be operated by either LM or Northern, proberbly Northern, as there is little point in ATW having a single EMU diagram.
