Crewe-London
eddygrim
27 Apr 2010
Bristol
hello i was wondering can you go crewe to derby then derby to london st pancras instead of london euston or crewe to york and then york to london kings cross i tried the internet but all i get r pdf files which my computer doesnt load??? can anybody help. :|
tony_mac
25 Feb 2009
Do you want some help getting the pdf files to load? You won't be able to check properly without the pdf files.
You can do a quick check using nationalrail.co.uk. Put in the journey you want to do, with the 'via' option. Then check the fares, and when you select one it shows you in the box below how many tickets you need. If it's one, you are fine, if not, then it is best to check the routeing guide.
I can have a look at it a bit later, but it can be a bit time consuming, so it's better if you can do it yourself.
b0b
25 Jan 2010
Crewe to London is only allowed to Euston, Marylebone and Paddington I'm afraid.
A routing points: [Routing Point CREWE]
B routing points: [Routing Point LONDON GROUP]
ROUTING Station CREWE TO Station LONDON EUSTON
3 routes found
route [Map CS]
route [Map CM, Map GC]
Map CM to Map GC via [Routing Point BIRMINGHAM GROUP, Routing Point COVENTRY, Routing Point SMETHWICK GROUP]
route [Map LC]
eddygrim
27 Apr 2010
Bristol
how do you get to paddington??? by crewe i may be intrested thanks for the support everybody :D
b0b
25 Jan 2010
Map CS allows Crewe to Birmingham to Banbury to Oxford to Didcot Parkway to Reading to London Paddington.
CM+GC allows Crewe to Birmingham to West Ruislip to Paddington via Greenford.
