Crews Hill Travelcard Query
Gathursty
31 May 2011
Wigan
According to the Internet, Crews Hill is both unstaffed and without a ticket machine.
I'm considering the 0520 service into Moorgate. I require a Travelcard. What is the correct thing to do as the train approaches?
I'm from Wigan so am familiar with paying on the train in such a circumstance, but in London, isn't everything DOO? I wouldn't like to have a chat with an RPI at 6am in Moorgate at the wrong side of the ticket gate.
Ianno87
3 May 2015
It's in Travelcard Zone 6, so could you use Oyster or a Contactless Debit/Credit card for your journeys instead?
GatwickDepress
14 Jan 2013
Great Northern services are all DOO so the first opportunity to pay is at Moorgate. Explain it to the gateline staff and they should let you through.
Alternately you could use Oyster from Crews Hill, buy a ticket in advance at a booking office, or book online and collect from a ticket machine at a different station.
crehld
1 Nov 2014
Norfolk
If Gathursty wants a travelcard (I'm assuming he's after a paper one) then using Oyster would add an unnecessary expense. As GatwickDepress suggests the only viable options which do not incur a needless additional expense are to either simply board the train and buy at the first available opportunity at Moorgate, or buy the travelcard in advance.
Worth pointing out that the NRE pages (if you've used these) can be out of date, so there may well be facilities in existence. But to be quite frank I'm astonished that a station within the London zones with 200,000 passengers a year has no facilities whatsoever.
MikeWh
15 Jun 2010
Crayford
It's in the middle of nowhere - almost. It just happens to be the first station within zone 6 so probably attracts a lot of commuters. I understand anything which holds money gets vandalised quite quickly.
Gathursty
31 May 2011
Wigan
Thanks for the quick replies.
I posted a thread a couple of weeks ago which gave me the conclusion that for bashing in the London area, a Travelcard is more appropriate than an Oystercard.
I probably will be using Stratford as a base but I noticed Crews Hill was by the M25 and got curious.
I could avoid hassle altogether by buying an all Zones Travelcard the day before (I think I can do this...) in Wigan.
crehld
1 Nov 2014
Norfolk
Yes, if you're on the bash and going to make lots of short journeys without any long gaps between them then a paper travel card is the way to go - it'll save a lot of hassle with out of station interchanges and maximum journey times (Mike's excellent website explains all).
paddington
19 Feb 2013
How are you getting to Crews Hill at 0520?
It's unlikely that there will be an RPI at Moorgate at 0600.
It's more likely that the barriers will be open (I'd say 25% chance)
Clip
28 Jun 2010
The poster you quoted using contactless card which you failed to address which then can also be used as a tc without any of the unessecary expense that you claimed
MikeWh
15 Jun 2010
Crayford
Except the OP really wants a travelcard. He doesn't want to use Oyster or contactless because of the difficulties which may be encountered by making lots of journeys, either exceeding maximum journey time if he forgets to leave the system regularly, or having two or more journeys joined by OSIs and again falling foul of MJTs.
gray1404
3 Mar 2014
Merseyside
As far as I can see, there are no ticket issuing facilities at that station and it is not a PF station. So you can simply board and get a ticket at the first opportunity. An RPI could not issue you with a PF as you have come from that station.
I have just had a look on the Virgin Trains website (WC) and that will sell you the travelcard you need. You can collect that before travel from another station if you wish.
crehld
1 Nov 2014
Norfolk
Gathusty wants to spend a day riding the trains around London, likely involving a number of short journeys without breaks between them. There are a number of situations where a paper travel card is better than using oyster or CPC, and this is one of them due to the nature of the oyster system which is really only designed to cope with single journeys. As I said this is explained in detail on Mike's excellent website:
http://www.oyster-rail.org.uk/when-not-to-use-oyster/
So of Gathursty buys a paper travel card for the day but also used oyster/CPC between Crews Hill and Moorgate the latter constitutes an unnecessary additional expense, given the paper travel card includes validity between Crews Hill and Moorgate.
hairyhandedfool
14 Apr 2008
....Alternately you could .... book online and collect from a ticket machine at a different station.
Please remember when doing this that it is the passenger's responsibility to collect the ticket before boarding a train. A list of stations where tickets can be collected at any time is available when you book the ticket.
Clip
28 Jun 2010
Nowhere in the first post did they claim they 'really' wanted a TC which is why Ianno87 suggested both Oyster and contactless to which the reply at the time from crehld replied as they did saying Oyster would be an unnecessary expense ignoring the option of contactless. It appears it was only later that they confirmed that they wanted a paper TC but at that time the advice was correct and did not constitute any further expense as claimed by a claimed fares advisor as they had overlooked contactless, as I rightly pointed out.
IanD
18 Sep 2011
Newport Pagnell
Crews Hill appears on this list of stations.
PeterC
29 Sep 2014
Unless the OP can obtain a paper travelcard in advance he is stuck with using a contactless card for the initial journey from Crews Hill.
crehld
1 Nov 2014
Norfolk
Gathursty was quite explicit in the opening post that he required a travelcard:
The advice to therefore purchase a travelcard if no facilities are available at Crews Hill at the first available opportunity at Moorgate, or to purchase one in advance, and further to avoid oyster or CPC was correct. It was also correct to assert that using oyster or CPC would add an unnecessary additional expense on top of the required travelcard, given said travelcard is valid between Crews Hill and Moorgate.
I apologise if I cannot express this point with greater clarity. And I further apologise if giving out correct and factual advice to save passengers avoiding paying for their journey twice offends you in any way.
No. If there are no ticket issuing facilities at Crews Hill (something the OP has been advised to check when 'on the ground') then the OP can obtain a travelcard at the first available opportunity, which will probably be at Moorgate station. Purchasing a travelcard in advance is of course another option available.
Hadders
27 Apr 2011
I know it doesn't really answer the question but wouldn't the OP be better off travelling from Cuffley or Gordon Hill. Admittedly a travelcard from Cuffley or Potters Bar is a £1.90 more but comes without potential hassle.
crehld
1 Nov 2014
Norfolk
The OP has said they are going to purchase their travelcard in advance at Wigan, so I think there's no problem or scope for hassle.
Ianno87
3 May 2015
Thank you. I suspected it was a possibility that the OP may have wanted a Travelcard specifically for bashing purposes, but that wasn't explicit in the first post - they may have just wanted to make a number of 'simple' journeys in the day making a Travelcard sufficient value for money.
Hence I was just making sure that the existence of Oyster/Contactless as an option had occured to them, particarly as they do not appear to be from anywhere near London (Smart Ticketing in Greater Manchester has barely progressed on from the 1980s GM Transport Clippercard)
I'll refrain from trying to be helpful in future if it just sends the thread into this forum's usual pointless bickering.
crehld
1 Nov 2014
Norfolk
I wasn't criticising / having a go at you at all (and there is no possible way my initial reply to you can be interpreted in this way whatsoever), and it was fine to raise the option of oyster / CPC as a possible option. But given Gathursty's explicitly stated requirement for a travelcard in his opening post...
... I merely pointed out Gathursty would be better off not using oyster / CPC if they would be using a travelcard for the day as it would be adding an unnecessary additional expense.
You are not alone in your frustration about pointless bickering on the forum, usually instigated by a small minority of posters who seemingly go out of their way to find something objectionable with even the most sound and sensible of advice or discussions.
Hassocks5489
2 Feb 2014
Hove, Sunny Sussex by the Sea
My own lists of ticket issuing locations indicate that Crews Hill has not had a TVM since mid-2009, when a short-lived Shere FASTticket machine was removed (I think due to vandalism, as alluded to earlier).
Hadders
27 Apr 2011
That's incorrect. If there are no ticket issuing facilities when you start your journey then you can pay on board or at your destination.
CyrusWuff
20 May 2013
Haven't been there recently, but the "Stations Made Easy" map on NRE shows that Crews Hill did have a TVM at one point, though on the day they went to take the photos it was out of service due to vandalism. The photo in question can be found here.
Parking wise, there are only 14 spaces in the car park, one of which is a Disabled bay, and whilst the station is physically close to the M25, it's about 3 miles from Junction 25.
How exactly would one collect a ticket from a station with no ticket office and no ticket machine ? This may be an error in that list.
Sometimes it's an error with the list, sometimes it's an error with NRE. I don't know Crews Hill - does anyone know for definite if it has a TVM?
PeterC
29 Sep 2014
Interesting point, where there is a facility to use PAYG and you have an appropriate card can you legally claim that there is "no ticket issuing facility"?
The OP's desire to go train spotting isn't relevant to this question.
As an aside and a fallback if the ticket can't be obtained in advance, if both Crews Hill journeys are off peak and he doesn't plan to go outside zone 4 otherwise, then, by rebooking at Finsbury Park the additional cost is a massive 30p
Hadders
27 Apr 2011
There is no compulsion to use Oyster or a Contactess Payment card. Cash is a perfectly valid form of payment and the railway must make arrangements for it to be accepted.
If the arrangements for passengers boarding at Crews Hill are to purchase on-board or at their destination then so be it.
Obviously in the real world GTR's RPIs might take a different view but that does not make them right and I would expect any formal action to be quickly dropped.
IanD
18 Sep 2011
Newport Pagnell
520am unlikely to be full particularly if it's a Saturday.
Drove past yesterday about 7pm, would've checked if I'd known!
But if you're told by the vendor that can collect a ticket from a station then what are your rights if that turns out to be false? Remember it's "Ticket on Departure" not "Ticket two or three days before departure".
