hey!
so i want to hear your thoughts on this and if this is possible or not but
do you think they could maybe upgrade and update the tramlink in Croydon
seeing how it is still the same and as it was in 1997 when it was first constructed to take over Coombe Road and Addiscombe railway services (whatever it's called)
and also seeing how it's been untouched since then besides some altercations to the stock itself and engineering works etc. etc. (not going into detail)
i thought they could upgrade the tracks that are single (if possible) and update plaforms to accomodate maybe 4 or 6 car trams and that flyover bit where southern trains go under as soon as leaving West Croydon and also making it like Sheffield (where trains share platforms with trains even in places like Rotterdam where trains also share platforms with trams) between Arena - Beckenham Junction where it branches off from the line to Elmers End (if that's the correct station)
so in short terms anything that is possible with trams to make sure there is frequent trains lots of capacity high capacity too and maybe update and upgrade the signalling
anyways images are below and let me know what you guys think
would you say it's possible?
do you think it should be allowed?
and if not could this be used for any possible future projects like the proposed Watford & Croxley - St Albans Abbey tram thing? or the one for crossing from Darford and Grays to Gravesend? or crossrail extension to Gravesend?
That's All
Would Be Much Appreciated if you gave a good reason and also back up your answer so we don't have any problems where someone clashes with someone else over a point you get the jist of it anyway i trust you
Thanks!
Image 1 - Rotherham Central Station
Image 2 - A Station In Rotterdam Owned By Randstad Rail (other lines owned by RET do not share platforms with trams and only with Randstad Rail Trains)
That's All
Thanks!
