Current location of 60009
Discussion in 'Railtours & Preservation' started by silverfoxcc, 11 Jun 2019.
  1. silverfoxcc
    silverfoxcc Member
    302
    17 Apr 2012
    Heard rumours it will be working the Windsor trips this summer, but Main line steam doesn't any motive power at all. nor there is any mention of LE movements
    Need to measure the cabside numbers! and as i am 6 miles away it would be an easy trip for me
    Rail Forums
  3. Controller1701
    Controller1701 Member
    92
    7 Dec 2012
    60009 is shown as having a current location of Toton Holding Sidings on an enquiry timed at 0743 this morning
  4. matt
    matt Moderator Staff Member Moderator
    6,294
    30 Jun 2005
    Rugby
    The other 60009 A4 Union of South Africa rather than the class 60.
    Don't think it will be on the Windsor trips as that is Mayflower with a black 5 as back up
  5. Peter Mugridge
    Peter Mugridge Established Member
    10,012
    8 Apr 2010
    Epsom
    Try searching 98809 on TOPS...
  6. alexl92
    alexl92 Established Member
    1,625
    12 Oct 2014
    It has been on the East Lancs recently but not sure if it is still there.
  7. silverfoxcc
    silverfoxcc Member
    302
    17 Apr 2012
    Peter
    As a non rail employee cannot access TOPS unless you know different! but thanks for the TOPS ref
  8. BigB
    BigB Member
    18
    20 Dec 2018
    Last movement shows it on 05:09 5Z81 Bishops Lydyard to Southall WCR - this did run but shows no further movement, so can only assume it is still at Southall, but anyone passing can probably confirm that easily enough.
    And I'm not a rail employee anymore, but you can access some data through the excellent RailCam
  9. Peter Mugridge
    10,012
    8 Apr 2010
    Epsom
    There's quite a few on here who can, though. Might be worth your while posting that number on the TOPS requests thread if you're searching for it on a specific date.
  10. Alan Warren
    Alan Warren New Member
    2
    22 Mar 2019
    60009 will be at the Mid Norfolk Railways steam gala from 28th to 30th June - if you can wait that long!
  11. jamieP
    jamieP Member
    204
    27 Feb 2012
    60009 is at Southall. She currently has no booked work until she moves to the MNR railway.
Share This Page
