You don't say?158 said:Photoshopped. :P
Coxster said:It's one of those pictures that you just wish Yorkie was doing heads-out in onboard LHCS![]()
Chaz said:I can picture a Pacer been hit by a wave, it would be completely crushed and thrown into the wall.![]()
*Waits for the usual post about "DON'T HATE PACERS!!!" from a Mr X"
I've heard Network Rail are looking into a diversion route away from the Sea Wall as Climate Change happens. Just look at -15 C...
--- edited ---
He should be in a advert... "You've been Tangoed",![]()
Didn't a 143 once do a Bristol to Penzance service? I seem to recall reading about it in RAIL?Jim said:There is NO evidence to SUGGEST that a Pacer would make it, after all, they have no turns in D&C, nearest youl'l normally fine a Pacer is Taunton
oh MML!Chaz said:He should be in a advert... "You've been Tangoed",![]()
Coxster said:Didn't a 143 once do a Bristol to Penzance service? I seem to recall reading about it in RAIL?
Chaz said:I've heard Network Rail are looking into a diversion route away from the Sea Wall as Climate Change happens. Just look at -15 C...
spm_43030 said:I havent laughed once in this thread!
Ok, the yorkie comment brought a slight grin, but really, you lot seem to have a bad habbit of turning something light hearted into a debate :banghead:![]()
The picture has been photoshopped and come one........if the weather was that bad do you think the voyager woud have made it to Dawlishhock:. It would have ground to a halt just after Dawlish Warren instead
THINDERBIRDS ARE GO!
