De-icing/anti-icing equipment mounting on trains
Vectus
14 Feb 2018
Does anyone know supplier of de-icing/snowing equipment mounting on trains?Similar de-icing equipment installed on D S7/S8 of London over ground,but also suitable for normal 2 tracks rail projects
Vectus
14 Feb 2018
Thanks a lot for your info, Randy,
I will try and get back to you if they are suitable.
randyrippley
21 Feb 2016
just use google to search: there are many others listed.
However I suspect you'd do better to turn your question on its head and fully explain what it is you're trying to do. Better chance then that someone here with the experience can put you in the right direction.
Looks to me that there are numerous answers to your original request, but many may not be the right answers. Post more detail and you'll probably find someone who knows....
Vectus
14 Feb 2018
@randyrippley
I am looking for similar de-icing equipment installed on D S7/S8 of London over ground. I get the impression that is for third track project. But the project i am working on is for normal 2 track metro/suburb trains.
Arrowvale one is seemed only for 3 track project.
Google search resulting in too many unrelated links, not very precise as what i am looking for.
Thanks a lot for your support
randyrippley
21 Feb 2016
I think you need to explain more.
Track deicing?
Third rail deicing?
OHLE deicing?
Vectus
14 Feb 2018
@Dstock7080 @Randrippley
Thanks for your support.
I am working on a project need the following solutions:
1. Approved De-icing/anti-icing equipment/solution for rail points in winter. How is the situation of DS7/8 of London overground?
2. Approved De-icing/anti-icing equipment/solution for third rail project. Less priority than 1.
3. Any equipment can be amounted on operating train for this purpose
In case in winter time, the train is left in open track and be iced on the track (the wheel of train), any efficient solution to remove it?
Nor for OHLE De-icing at the moment.
best regards
Elecman
31 Dec 2013
Lancashire
Fixed points heating equipment deals with Points on Network a Rail, also some sites are now fitted with fixed heaters on the 3rd Rail.
Dstock7080
17 Feb 2010
West London
London Underground rolling Stock only have the facility to de-ice the traction current rails.
Apart from the point heaters (now electric on LU) mentioned above, it is not felt necessary to de-ice running rails.
Vectus
14 Feb 2018
@ Dstock7080, @ Elecman @randyrippley
Thanks for your comments. The project I am working is for winter weather similar to London. As there is normally no heavy snow in the winter, they think maybe it is not worthy of implementing fixed point heaters.
Do you have experience of de-icing/snowing for points with efficient temporary solutions?
1. for example, to spray a layer of anti-icer like kilfrost to prevent icing
2. once there is ice on the points, an efficient way to remove it with de-icing equipment?
Highlandspring
14 Oct 2017
Network Rail Scotland have a train specifically set up to remove ice and snow from points; it doesn't need to be used very often but is very effective when it is. It features in this video -
