The National Rail Conditions of Travel (NRCoT) Condition 14 clearly permits the use of two or more tickets for one journey
The rail industry does not make tickets available for all journeys; some journeys require a combination of tickets.
Many staff employed in the rail industry also encourage the use of combination of tickets under various circumstances, including (but not limited to):
Furthermore, train companies are required to assist any passenger who would otherwise risk being stranded, as Condition 28.2 of the NRCoT states:
There is no reduction in rights when using a combination of tickets whatsoever.
For example, a passenger may hold any of the following tickets between Sheffield and London:
http://www.brfares.com/#faredetail?orig=SHF&dest=KGX&rte=576&tkt=GCU
Route: GC & XC ONLY
http://www.brfares.com/#faredetail?orig=SHF&dest=KGX&rte=431&tkt=USG
AP HULTRNS & TPE
http://www.brfares.com/#faredetail?orig=SHF&dest=KGX&rte=565&tkt=GCT
GC & NTH VIA DON
http://www.brfares.com/#faredetail?orig=SHF&dest=EUS&rte=370&tkt=OPR
LNR AND XC ONLY
It is great that such a wide range is available, however this does not cater for all the potential possibilities, such as via Northern & Hull Trains, or any other combination.
Passengers may alternatively mix and match by using any operator, by any route they wish, by purchasing a combination of tickets.
Absolutely no rights are lost when holding any combination of tickets, compared to the equivalent validity that would be made available by the use of any equivalent through fare.
Edit: see also this thread https://www.railforums.co.uk/thread...-of-number-of-tickets-held-mythbuster.198338/
...you may use a combination of two or more Tickets to make a journey...
- where the passenger wishes to book far in advance, and only one leg is open for booking (e.g. a journey such as Edinburgh to Newbury booked 20 weeks in advance);
- where the passenger wishes to travel in 1st class, and there is no through 1st class fare (e.g. Hull to Burnley);
- where there is no through Advance fare (e.g. Stafford to York)
Normally the customer would be expected to use the same company, though discretion can be shown to allow the use of other companies; to give just one example if a Hereford to London Paddington service is cancelled, a long-standing local instruction exists to redirect passengers to travel via Newport, even though this involves the use of another company's train.If the passenger is delayed and the rail industry or its partners (as shown below) is at fault, which should be checked with your Control Office, change to another train of the same company is allowed to get them to their destination with the least delay.
This is irrespective of combinations of rail tickets held.
Where disruption prevents you from completing the journey for which your ticket is valid and is being used, any Train Company will, where it reasonably can, provide you with alternative means of travel to your destination, or if necessary provide overnight accommodation for you.
Route: GC & XC ONLY
AP HULTRNS & TPE
GC & NTH VIA DON
LNR AND XC ONLY
Rail Delivery Group (RDG) issued a staff brief regarding "split ticketing" on 10th January; included in this brief was the following clarification:
Some train companies (e.g. GWR, SWR) make this explicitly clear in their Passenger Charters.
If you are incorrectly denied a legitimate Delay Repay claim, I would quote this to the relevant company. If they continue to refuse, you can refer them to the Rail Ombudsman.
Delay Repay claims go to the company who caused the delay; if you are further delayed later in the journey, this does not transfer the Delay Repay liability to a different company.
