Are there whistleboards at Dent foot crossing?
Shaw S Hunter
21 Apr 2016
Sunny South Lancs
It's an awful long time since I was last there. But a check of the Sectional Appendix reveals that the crossing is not marked in that document. It would therefore be logical to assume that there are no whistle boards provided. That does not mean that drivers do not sound their horns there. Doubtless someone will be along eventually with a definitive answer.
Kurolus Rex
1 Mar 2019
Found an image while looking around and it would appear there is one right at the start of the platform ramp of the up platform. Not sure about the down platform, could maybe make one out a little bit before the station after the 30 limit but not 100% sure.
ComUtoR
13 Dec 2013
The Sectional Appendix isn't required to show all crossings. (I spoke to them last month) I also checked our local ones and also doesn't show whistle boards.
Shaw S Hunter
21 Apr 2016
Sunny South Lancs
Which begs the question: what type of crossing might require whistle boards without actually appearing in the SA? Presumably there is a RSSB standard...
ComUtoR
13 Dec 2013
I have no idea. We have one that is missing from the SA and I queried it recently. I was informed that they do not need to put them all in and the one I questioned was ok to miss. It has a whistle board and is in frequent use. Table A Diagrams are a list of running lines. I would guess (I know its bad) that 'Level Crossings are probably required but foot crossings, not so much.
The SA is notorious for its 'accuracy'
Tomnick
10 Jun 2005
Footpath crossings or even user worked (vehicle) crossings without telephones don't tend to appear in the SA (which I do think is a problem especially on the TOC side!).
Dieseldriver
9 Apr 2012
Just because a crossing has whistle boards, they aren't an indicator of its importance. You could have a little used foot crossing with whistle boards because it's on a curve without the required sighting time of trains. On the other hand, you could have a highly used crossing on a dead long straight with no requirement for whistle boards.
Shaw S Hunter
21 Apr 2016
Sunny South Lancs
Oh I totally agree, hence my query about RSSB standards. Unless of course the responsibility for the appropriate risk assessment has been "devolved"...
NI 271
10 Sep 2012
The Doghouse
Thanks! Do you know where these are located exactly? (i appreciate this may not be easy to find out!)
On the up, it's directly in front of the bridge before the platform in the direction of travel, on the down it's about 25-30 yards after the board for the 30 PSR.
Don't worry, it wasn't difficult to find out, I drive past them several times most weeks...;)
Kurolus Rex
1 Mar 2019
Thanks!
