Suraggu
7Z15 has 7 wagons derailed at east somerset junction.
... has deployed to a freight train derailment at East Somerset Junction to start gathering evidence on site .
All GWR HSTS are being diverted via Bristol and Swindon.
On that map, where are points 943B?
Figure 2 at the top of page 9 of the RAIB report (link above) is a diagram of the junction with the points and signals labelled. Assuming the track layout hasn't changed since, 943B protect the mainline from trains leaving the branch to the quarry.On that map, where are points 943B?
A freight train carrying stone and ballast which partially derailed, will cause disruption for at least 48 hours between the West country and London.
The train is blocking the line between Castle Cary, Somerset, and Westbury, Wiltshire, following the incident at 17:50 GMT, Network Rail said.
No-one was injured but there has been significant damage to track and equipment.
Services between London Paddington and Bristol Temple Meads are affected.
GWR also confirmed that services to Frome and Bruton were also affected by the incident.
The freight train was pulling 38 wagons, when seven of them partially derailed.
A Network Rail spokesman added: "We are working closely with GWR and South West Trains to put in place contingency plans for tomorrow including diverting London-West of England services via Bristol.
"No injuries have been sustained but there is significant damage to track and equipment.
"The derailment is significant with the line currently blocked and likely to remain out of use for at least the next 48 hours."
The locomotive wasn't derailed, was it?
Try getting from Maiden Newton to Taunton (to select but one example) today. There are some amazing tours of the West Country for pax today, including non-stop journeys through BRI (Temple Meads); now there's a rare opportunity! Pity is, they can't take the SPM avoiding line there, because some far-sighted person allowed a Krispy Kreme and a multiplex cinema to be built across it (near Bristol East Depot).
A new gallery of daylight images here:
https://twitter.com/networkrail/status/844115991403646976
Shows the derailed wagons are in the middle of the train, suggesting points may have moved under the train, unlike the 2008 incident where a signaller, attempting to move traffic during a total signalling systems breakdown, had verbally authorised a movement over an incorrectly set trap point. In that case the two locomotives and first few wagons ended up in the ballast.
Pure speculation....
