Derailment at Paddington - 2017-08-20
Discussion in 'UK Railway Discussion' started by TheNewNo2, 20 Aug 2017.
  1. TheNewNo2
    TheNewNo2 Member
    1,006
    31 Mar 2015
    Canary Wharf
    Rail Forums
  3. Agent_Squash
    Agent_Squash Member
    685
    22 Jul 2016
    Don’t forget the SN 377 on fire!
  4. 221129
    221129 Established Member
    4,431
    21 Mar 2011
    Sunny Scotland
    Been 4 derailment this week No?
  5. plymothian
    plymothian Member
    647
    26 Sep 2010
    Plymouth
    The leading bogie of the rear power car of 1C81 derailed whilst leaving platform 2. The train had moved 1 power car length along the platform and stopped with the trailing power car resting against the platform.
  6. Gemz91
    Gemz91 Member
    560
    1 Feb 2013
    Garden Shed
  7. causton
    causton Established Member
    5,401
    4 Aug 2010
    There was also a derailment at Daventry IRFT this week, if people are counting ;)
    Not a good week at all...!
  8. swt_passenger
    swt_passenger Veteran Member
    21,458
    Tempting fate, perhaps I shouldn't have posted last week that the number of railway breakdown cranes had massively reduced since BR days, because derailments were so rare now...
  9. Mag_seven
    Mag_seven Established Member
    5,597
    1 Sep 2014
    here to eternity
  10. eastdyke
    eastdyke Established Member
    1,698
    25 Jan 2010
    East Midlands
    Probably because the pic has been sold.
  11. DackandBlecker
    DackandBlecker Member
    61
    17 Jul 2017
    Where the 456 "crashed" in to the barrier train, and became "partially derailed" at Waterloo, I'd imagine.
  12. Mag_seven
    5,597
    1 Sep 2014
    here to eternity
    I thought that was covered as one of the "two derailments", the other derailment being the freight at Ely?
    EDIT: OK I should have realised that you were including today's derailment as one of the two. :D
  13. Darandio
    Darandio Established Member
    7,613
    24 Feb 2007
    It did, it was basically the same as the other picture but from a slightly different angle.
    As said above, probably been sold.
  14. 221129
    4,431
    21 Mar 2011
    Sunny Scotland
    Neville Hill as well.
  15. D1009
    D1009 Established Member
    3,166
    22 Feb 2012
    Stoke Gifford
  16. Sleepy
    Sleepy Member
    972
    15 Feb 2009
    East Anglia
    What is dispatch position for guard/TM at Pad for HST ?
  17. DackandBlecker
    61
    17 Jul 2017
    Well
    Waterloo
    Ely
    Paddington
    Kings Cross
  18. Marklund
    Marklund Member
    827
    18 Nov 2010
    Lots of tie bars.
    Hasn't there been a gauge spread derailment at Paddington with a HEX before?
    Ahh a combination of track defect and unit.
  19. 221129
    4,431
    21 Mar 2011
    Sunny Scotland
    Missing out Neville Hill and Daventry
  20. DackandBlecker
    61
    17 Jul 2017
    I was clarifying the original post. :)
  21. ScouserGirl
    ScouserGirl Member
    189
    28 Dec 2015
    Tm is at the back of the set so in the first class carriage if in normal formation
  22. westcoaster
    westcoaster Established Member
    3,822
    4 Dec 2006
    DTOS A or B
    Didn't a hex train derail in there before.
  23. Tom Quinne
    Tom Quinne Established Member
    1,175
    8 Jul 2017
    The TM would have noticed the derailment and signalled one bell to the driver to stop, which would have been significantly quicker than the despatcher making a call to control, control to the TVSC and TVSC to the driver.
    It'll be okay though DOO is 100% safe after all....
  24. wensley
    wensley Established Member
    2,026
    29 Jun 2008
    On a train...somewhere!
    It certainly hasn't been a good week, although thankfully there seems to have been no notable injuries in any of the incidents.
    Regarding stopping dispatch, the Guard is undoubtedly the fastest means of stopping the train in these circumstances. However, with GSM-R and the REC facility, it takes one call from Dispatcher to Signaller and the entire area can be brought to the stand at the push of a button. I am by no means an advocate for DOO, but stopping trains in an emergency is easier now than it ever has been!
  25. 43096
    43096 Established Member
    6,194
    23 Nov 2015
    TGS at the rear on this occasion. No different for dispatch though.
  26. BestWestern
    BestWestern Established Member
    6,736
    6 Feb 2011
    Nevertheless, had this train been stopped by a REC it would have travelled significantly further, with the potential for a significantly worse outcome.
  27. tsr
    tsr Established Member
    7,369
    15 Nov 2011
    Between the parallel lines
    Unless I've missed a really big development, dispatch staff are not routinely equipped with GSM-R handsets, and therefore it is likely that an emergency call to the signaller will need to take place over whatever the nearest handset is (which could involve running down to the end of the platform or to a control panel half way along).
    It is only after the relevant information is relayed that the signaller will then be able to make a decision to use their GSM-R terminal to stop trains, which whilst relatively simple, will probably (by that point) happen after the derailed train has caused quite a lot more damage, may have injured people, and other services may be affected. Indeed, a derailed DOO service could well have been stopped by a passenger alarm eventually, or by the brake lines being damaged, but neither is going to be as rapid as somebody being able to look out of the window and stop the job immediately.
  28. Nippy
    Nippy Member
    442
    13 Aug 2013
    Not in platform 2, a 360 Connect derailed in one of the other platforms reasonably recently.
  29. Mag_seven
    5,597
    1 Sep 2014
    here to eternity
    See link in post 17.
  30. Tom Quinne
    1,175
    8 Jul 2017
    I trust you have witnessed the "quality" of some station staff.....
    Not to mention the drummed in mentality to not delay trains which puts significant doubt and worry of being bollocked for stopping the job.
  31. wensley
    2,026
    29 Jun 2008
    To clarify, I was pointing out that it would have been quicker than inferred in the original post. As I also said, the Guard was certainly in the best position to stop the train in this circumstance. Also, I am aware that it would require one emergency call Dispatcher to Signaller from the nearest telephone and one REC broadcast.
    In terms of the 'quality' and mindset of platform staff, those who are safety critical and are actually concerned in the train dispatch process should know that safety takes priority over performance and will have had he various means of stopping trains in an emergency drilled into them, assessed and re-assessed.
Share This Page
