ValleyLines142
Surprised they haven't closed the station and declared a 10 mile exclusion zone.
And where else do you propose every other train that has arrived today terminate?
I don't think any of our rec calls have been text book, especially as they are the only type of calls that you only get to practice with when it's a live incident, unlike the old CSR that if you had a some willing drivers you could go through all the different scenarios.
Why couldn't the guard intervene in that case?EMT had a 222 derail some years back, at the time they were having regular issues with false TMS alarms and so the Driver disregarded it. Eventually he had warnings going off for all manner of things, including numerous passenger alarms, and finally opted to stop the train. The distance travelled while derailed was quite vast! A Driver will know if a warning or particular selection of warnings are routine issues, or something more concerning.
Lucky you then. My LOM was incredibly strict over it, and was willing to downgrade you for the slightest "misdemeanor".
Surely the driver would have noticed the jolt when it happened and stopped anyway.
Edit: by jolt I mean train suddenly not accelerating.
True, if the guard and platform staff are aware at the same time. There are circumstances where the platform staff may spot the problem before a guard would be aware.
Upside of droplight windows: platform staff see something, raise arms in the air at the TM who then responds to this by giving one on the bell and/or pulling a passcomm.
The immediate cause of the derailment of the trailing three axles (assuming all derailed) was gauge spread. It is likely that this is also responsible for the derailment of the first axle, but it is not impossible for the gauge spread to be the consequence of the leading axle derailing. I do not know in which order the axles derailed.
The track here is supported by chairs on longitudinal timber bearers. Approximately where (or very shortly ahead of where) the inner (leading on departure) bogie of the power car came to a stand on arrival on the previous journey, the timber bearer supporting the right (platform side) rail gave way. It is believed (but not proven) that this was the or at least a causal factor. All the investigation activity was focused on the track, and almost all around the point of the bearer damage.
Mag_seven was being sarcastic I think....
Hi Dan, I was being sarcastic but not without reason - there have been incidents in the past where the authorities have gone a little OTT after a derailment.
Indeed, and the only practice you have of using the rec call facility is in a simulator environment. Whilst this should emulate a real experience as close as possible it can be hard to imagine using it for real the same way.Bad coms will get you marked down and put on an action plan, but it's a bit harsh if the first time you take a rec call "ever" it is because some women has jumped in front of a train will her child in a push chair, no theoretical training is going to prepare you for that and come out with perfect coms with half a dozen drivers butting in because they have forgotten their training as well.
The hardest part of any of the rec calls that have come into my signalling centre is to silence the non effected drivers so you can actually talk to to the driver involved. I know as the software patches come through they are slowly locking everyone out to just listening, apart from the lead signaller and the driver who sends a rec call. But receive one in any of the London area boxes and it's a complete and bloody mess to start with so many drivers involved on parallel, adjacent, diverging, converging routes on the lines that criss cross London.
"This is a Railway Emergency Call, stop all traffic Paddington Station "
Siggie then hits the GSM-R Red Button.....Job Stopped.
In fact the REC button would be almost fully pressed by the siggie on the first 3 words !
The REC will stop everything in and around the station for some distance
When we, as drivers, press the red emergency button on GSM-R it automatically broadcasts a stop message to all other trains within the GSM-R cell - no need for the the signaller to send any emergency call broadcasts. All trains within approx. 5km radius of the affected train receive the emergency stop message.
I thought it was your cell + adjacent. 18km potential radius ?
Will trains on unconnected routes (eg GWML out of Paddington and SWML out of Waterloo be on different frequencies to prevent an e-stop broadcast message on 1 causing everything to stop on the other one when there'll be no danger on the other?
This is what we've been told our end but it seems very hit and miss as to the actual distance.
Just out of interest - do your company instructions say for you to stop immediately on receipt of a REC call? (I've never got a clear answer...)
GSM-R has it's advantages but from a signaller's perspective (well, mine...) I'd love to be able to press a button and you just got a 'STOP' message with an audible alarm (i.e CSR-like) rather than having to launch into the whole spiel verbally. The problem then is you'd get all the drivers calling in at once wondering what's going on (understandably!) which would then engulf the GSM-R terminal with calls, which it doesn't seem to like very much...
And those berth triggered messages/cautions...
The short answer is no! They are working to 'unpick' the cells but there's so many and they're so close together it's a very difficult job.
On a couple of points about comms. First. Totally agree about the end of a REC. You still want that confirmation. Mainly because moving off after a emergency stop doesn't feel natural. Its still new so it will get better/easier. ITs also because the calls are very confusing. In the metro area they are truly a real mess. If the do block out the calls to listen only it will be game changing.
On bad comms.... Signaller called me a dummy the other day
On the derailment. I've always wondered what the Driver experiences. Pulling away from a station is low speed so why don't Drivers feel the unit dragging. The Drivers I've spoken with about their derailments absolutely knew when the unit hit the dirt. Maybe they were just lucky.
I doubt the driver would have felt the wheels come off from right up the other end, but I'm wondering, what (if any) alarms / anomalies could potentially have come to his attention in the cab to tell him the other PC had gone to ground?
Also while we're at it with alarms, can someone solve a mystery for me - what on earth is that 4-tone fanfare at Southern stations? I hear it all the time when I'm on their metals!
Lots of tie bars.
Hasn't there been a gauge spread derailment at Paddington with a HEX before?
Ahh a combination of track defect and unit.
As an outsider, I'd expect that stations will be given Big Red Buttons to allow them to stop the job in an emergency without having to place a call to the signallers. Though, admittedly, that still involves a delay in getting the button pressed.
Would the TM have immediate access to either an emergency stop button/handle or to the passcomm from where they'd be on the train to dispatch from Paddington?
