DfT: South Western Railway NOT Financially Sustainable
Discussion in 'UK Railway Discussion' started by KashmireHawker, 22 Jan 2020.
Thread Status:
  1. KashmireHawker
    KashmireHawker Member
    304
    25 Jan 2016
    Sheffield / Wolverhampton
    That is the view, of Transport Secretary Grant Shapps, who has released the following statement this morning:
    https://www.gov.uk/government/speeches/rail-update-on-south-western-railway
    Rail Forums
  3. HamworthyGoods
    HamworthyGoods Member
    542
    15 Jan 2019
  4. krus_aragon
    krus_aragon Established Member
    5,281
    10 Jun 2009
    North Wales
    And all the while the Government is sitting on the Williams Rail Review... I wonder what their plans are?
  5. DelW
    DelW Member
    1,045
    15 Jan 2015
    They've failed to meet most of their other commitments though. (OK, the Desiro refurbs are finished at last, but around a year late).
    I imagine the business driven away by the endless guards strikes is a significant part of the problem, so the RMT may feel they've "won" in possibly breaking another franchise. Long term, it may look different though.
  6. Nicholas Lewis
    Nicholas Lewis Member
    194
    9 Aug 2019
    Its pretty evident OLR cannot handle all the TOCs either failing or in financial distress so this will be driven by political merits ie Northern to OLR and the rest through a multiplicity of direct awards to manage the transition to the new operating model for passenger services. With the concession model surely now seen as the best way forward i would suggest direct awards also allows the DofT, or whoever Williams promotes to administer the process, the base information to go out to the market for suppliers.
  7. Monty
    Monty Established Member
    2,228
    12 Jun 2012
    The strikes are a symptom rather than a direct cause, when you discount them the punctuality is still horrendous. Most of it is because the infrastructure is in a right state, the South Western Division needs billions invested for upgrades and basic maintenance. Scheduling isn't great either, they are trying to squeeze more and more services on a network that just can't handle it. In addition they underestimated the numbers of staff they would need to implement their new timetable as well as the time it takes to train them.
  8. Nicholas Lewis
    194
    9 Aug 2019
    PPM on the floor again today due in part due to failed signalling at Hilsea which is relatively modern!
  9. Monty
    2,228
    12 Jun 2012
    It failed quite badly on Monday evening too causing all kinds of trouble. To my knowledge while the signaling down there isn't ancient it's not exactly cutting edge either. NR is struggling to keep up with all the issues we've been having and it shows.
  10. pdeaves
    pdeaves Established Member
    2,861
    14 Sep 2014
    Gateway to the South West
    That is true. If experienced teams are, apparently, no good at running one TOC there is no way inexperienced teams can handle multiple TOCs and achieve the utopia required of them. I predict a muddled mess as reality dawns and DfT et al try to make inconsistent decisions (required to make 'something' work) look fair and consistent. The trains will still run because those focused on making them run still get on with it despite, rather than because of, the political masters.
  11. HH
    HH Established Member
    4,161
    31 Jul 2009
    Essex
    Not according to those in OLR. Theoretically I would agree with that...
  12. HH
    4,161
    31 Jul 2009
    Essex
    The teams running the TOCs would be just as experienced as those running them today; indeed it is likely that some of the same people would be running them. The difference would be that they reported to the OLR rather than the rail board of the owning group. And, of course,the driving force would be good news for the politicos rather than maximising shareholder benefit.
  13. thenorthern
    thenorthern Established Member
    3,566
    27 May 2013
    Given how many operators seem to be failing at the moment I think the DfT is making unrealistic expectations of train operating companies and something has to change there.
  14. hwl
    hwl Established Member
    5,047
    5 Feb 2012
    There isn't just one OLR - DfT have many OLR companies set up...
  15. HH
    4,161
    31 Jul 2009
    Essex
    The DfT has not put a gun to their head and told them to submit unrealistic bids. You could argue that DfT ought to reject those bids, but the problem is that if they do, then they get taken to court!
    I do think that DfT is over-specifying and also requiring far too much from the bids, but then not allowing bidders either enough time or enough words to go into depth (this is a big issue - while the requirements have exponentially increased, the length of what can be submitted has shrunk considerably). This makes it very difficult to evaluate the bids and this in turn makes DfT even more nervous of challenging them.
  16. HH
    4,161
    31 Jul 2009
    Essex
    Yes, but having companies set up is not the same as having people to run them. Apart from a core group, these have to be hired as required.
  17. hwl
    5,047
    5 Feb 2012
    "Hired as required" - And that is where I suspect there may effectively be some double+ counting /assuming that most franchises can't be in trouble at once going on!
  18. HH
    4,161
    31 Jul 2009
    Essex
    DfT will absolutely not have assumed that so many TOCs could be in trouble at once. Of course that causes issues about having the requisite number of suitable, senior OLR staff. Of course, if the department took decisions in a more timely manner, then the issue wouldn't be quite so large - e.g. Northern have been clearly failing for some time, and why did it take so long to cancel the SEF competition? When it cmes to making decisions the DfT's motto appears to be, never do today what you can put off until next quarter.
  19. Socanxdis
    Socanxdis Member
    32
    27 Aug 2017
    What impact will it have on staff?
  20. greaterwest
    greaterwest Member
    1,071
    23 Nov 2014
    Today is the third day in a row the same three signals have failed on the up line at Hilsea, with no resolution in sight.
  21. DarloRich
    DarloRich Veteran Member
    23,342
    Work - Fenny Stratford(MK) Home - Darlington
    More Williams review wicket rolling.........................
    None, outside of the most senior executives
  22. infobleep
    infobleep Established Member
    9,350
    27 Feb 2011
    The Office of Rail and Road criticised Network Rail for problems in the north. Are those worse than in the SWR region as I'm not aware of them critising Network Rail for this area, unless they already did so previously?
  23. infobleep
    9,350
    27 Feb 2011
    They have located the cable at fault, so I suspect there will be a resolution.
  24. Monty
    2,228
    12 Jun 2012
    I can't comment on the state of the rail network in the North, but what I do know is that it's bad on the SWD.
  25. JonathanH
    JonathanH Established Member
    3,685
    Yet again, a situation where we are going to have to stifle demand.
  26. thenorthern
    3,566
    27 May 2013
    I would imagine very little, South Western Railway like many other "Essential services" is too big and important to fail, even if the company is taken over by the Department for Transport I can't see any redundancies happening as a result.
  27. Bletchleyite
    Bletchleyite Veteran Member
    46,893
    Up and down the south WCML (mostly)
    There's a definite undertone, if you read it all, of "we'll put the anti-strike law in place and then it'll be DOO for breakfast, lunch and dinner".
  28. Dr Hoo
    Dr Hoo Established Member
    1,465
    10 Nov 2015
    Hope Valley
    The ORR did a review of South Western performance as recently as July 2018. See Review of Network Rail's performance delivery to South Western Railway services
  29. Nicholas Lewis
    194
    9 Aug 2019
    Dont worry the Aventras are designed for to accommodate more standing in comfort
  30. dctraindriver
    dctraindriver Member
    250
    9 Jan 2017
    New uniform....
  31. dctraindriver
    250
    9 Jan 2017
    I sense this too
Thread Status:
Share This Page
