Hyphen
Hi all,
I shan't go into explicit details here, unless a mod states it's OK - just in case this is a "loophole"... (but can answer on PM)
I am looking to book a weekday off-peak return ticket to a London Terminal. No issues outbound.
On the return journey, the restriction text states two different "via" options, for which there are different restriction times published. The issue is, the "unpublished restrictions" on BRFares, and hence the Journey Planners, only appear to match the first option.
I wish to make a journey via the second listed station (which is also the more obvious route), but I cannot get a JP to give me an itinerary on this, even if I explicitly state a travel-via of the second listed station.
As it's an off-peak ticket I can still buy it without reservations, so no issue there - but am I likely to face issues as a result? As the "unpublished" restrictions are just that - is it safe to assume a printout from NRE's own version of the restriction text would suffice?
Many thanks for any insight!
