devon_metro
I've got a case a bit like that, but red. Loads of LEDs
XP can't do SATA? You've gotta be kidding.
My mac is almost two years old and came with SATA...
I've decided to build my own, as long as it's all plug-in (using gentle force (he says ) it shouldn't be too hard.
What I'm going to do is buy a part of the PC every Month, leaving the graphics and Sound cards late, so they are in date longer. WISH ME LUCK (I'm going to need it)
Got a picci?
You're not saying you're going to be buying components months before you're going to actually use them, surely? Or do you mean you are going to buy components and put them in an old PC initially and then move them into a new PC? (the latter is unlikely to work as the old PC won't support the latest technology). If the former, then that's a waste of money as you are paying for the cost of depreciation months before you even get to use the components!I've decided to build my own, as long as it's all plug-in (using gentle force (he says ) it shouldn't be too hard.
This suggests that SATA was heard of in other uses, e.g. servers, but this was not (and is still not) the case (Servers generally use SCSI).Well XP was designed in 2001, and IDE was still the main interface back then because SATA was still unheard of in a desktop or laptop.
I think there is a misuderstanding here. Motherboards are hardware devices, so cannot have device drivers 'installed'. A driver is software that provides a means for hardware to be used transparently.SATA came into wide-spread use after XP was developed and as such XP has never had the proper support for SATA, I believe that XP still needs the drivers installing via a floppy disk, although I also believe that some motherboards have the drivers pre-installed.
