JackWheeler79
Message Removed
Could I suggest you also read some of the threads on here which discuss the issue of convictions and DBS checks - I hope that will reassure you.My job is reliant on integrity and any criminal conviction which implies this could be damaging if not ending. This isn't a case of intentionally not wishing to pay the fare it is a genuine and honest mistake.
If this is a first offence and a genuine mistake (I had tickets, although I appreciate not valid etc) what would be their reason to pursue a conviction as opposed to an out of court settlement?
I am very worried about all of this.
In this section of the forum I feel it is important to be 100% accurate so I need to raise a couple of points with this.There are two different offences for travelling without a valid ticket, one of which is a criminal offence, the other a by-law offence. Because you have shown no intent to avoid paying a fare — i.e. it's clearly an honest mistake — if SWR does choose to proescure then it will most likely be the latter.
As long as you engage with them, cooperate and take responsibility for your actions it is more likely than not that you will be offered an out of court settlement. If you lie, come across aggressive and try to blame others then that is when you are likely to end up infront of the magistrates.Thanks for the reply and I will do this.
I have never been in trouble before.
Thanks for clarifying.In this section of the forum I feel it is important to be 100% accurate so I need to raise a couple of points with this.
Both of the offences mentioned above namely S.5 of the Regulation of Railways Act and Bylaw 18 of the National Railway Bylaws are considered criminal offences. The difference that you tried to point out are that one is recordable (s.5 RoRA) and will result in a criminal record upon conviction and the other (Bylaw offence) is not.
Secondly, intent in law is judged on actions and behavior, presenting an out of date railcard especially one that is significantly out of date would likely be used to demonstrate intent in law.
